1. Re: How to access renditions for smartimage?
rush_pawan Jun 11, 2013 3:21 PM (in response to Veena_07)Hi Veena,
I think there are multiple questions
# OOTB you can not drop a rendition (apart from original) of any image because the renditions are referenced copy of original image with set of extra property (like height, width etc...)
# Not sure why you want to drop a specific rendition on component. if it's only to display that specific rendition on component then you can achieve it via dropping the original image and through code prepare a call to specific rendition
For example: if you want to display a banner of /content/dam/geometrixx/banners/banner-mono.png with specific rendition of 140x100 the probably you have build the relative url as "/content/dam/geometrixx/banners/banner-mono.png/jcr:content/renditions/cq5dam.thumbnail. 140.100.png" whereas "/content/dam/geometrixx/banners/banner-mono.png" is your original image path you can get it from image node create inside the component and set as "fileReference" property & about height & width you can have custom size property similar to "image" component.
# You can access other image properties like roation, crop from image node itself which has been created inside your component node on page. it sets these property with name 'imageRotate', 'imageCrop' correspondingly.
I hope it clarifies your doubt. Let me know for more information
Pawan
2. Re: How to access renditions for smartimage?
Veena_07 Jun 12, 2013 12:15 AM (in response to rush_pawan)Hi pawan
I tried the same. But it was not bringing my other image properties; Thats why.
For eg:
I tuk the rendition image and set it to my image object as
image.setSrc(<rendition path>);
As per my knowledge this image object will contain all my properties for rotation crop and all. But it is giving me the rendition without croping or rotation.
If you try this you will come to know what i am actually trying to say.
Looking forward to hear from you soon
Veena
3. Re: How to access renditions for smartimage?
rush_pawan Jun 14, 2013 10:12 AM (in response to Veena_07)Hi Veena,
I think you have mixed the answers i provided above as you have asked multiple questions. So here is some more detail
1. When you crop/rotate or perform any other type of operation on image from component dialog it does not create a new rendition for image instead it sets those operations as property=value pair with image node (Do it by your self and check the properties set on image node as i mentioned above it sets these property with name 'imageRotate', 'imageCrop' correspondingly.)
Now to retreive the same image how its appearing on your dialog after performing all the operation first you need to have image resource object. I hope you have as you mentioned in your reply. so now perform this (as example)
Image image = new Image(resource); //if you already have image object then this step not require
image.addCssClass(DropTarget.CSS_CLASS_PREFIX + "image");
image.loadStyleData(currentStyle);
image.setSelector(".img"); // use image script
image.setDoctype(Doctype.fromRequest(request));
image.draw(out);
you need not require to set image source path to rendition path because you already have image object which has been built upon those set properties\
2. The rendition path will be used only when you have proper rendition available for that image and that time you will use
For reference you can look at /libs/foundation/components/image component and try to use it.
I hope it helps you.
Also let me know if your earlier post related to path field did not work out http://forums.adobe.com/message/5380319#5380319
Let me know for more information.
Pawan
4. Re: How to access renditions for smartimage?
Veena_07 Jun 17, 2013 10:40 PM (in response to rush_pawan)Hi pawan,
The issue here is , I want the rendition image to be displayed with all the image properties, suppose author has rotated it; i want the rendition image also to be rotated. Its not acheivable with above method.
Also the path field problem ; i didnt get time to check wince we tuk another approach. I will be checking it soon and will let you know soon
Veena
