5 Replies Latest reply on Jun 11, 2013 1:03 PM by Pippa01
    How do I set a variable within a 'for' loop grid array
      I'm afraid I'm stuck again!
      The next stage in the animation that I'm working on,  is to set up a boolean, 'drilled = false', so that all instances of the attachMovie ('openCircle') have a boolean 'drilled = false' associated with them. Then when someone clicks on one of the instances of the attachMovie ('openCircle'), the boolean becomes 'drilled = true', but only for that instance that has been clicked.
      What I've done is to set the variable (boolean)(highlighted in bold below) within both 'for' loops within the grid array, but it just returns an undefined value. Do I need to setup a separate array? (see code below):-
      //set up grid for solid array
      var spacing:Number = 5.75;
      var cols:Number = 20; // number of columns in grid
      var rows:Number = 20; // number of rows in grid
      var leftMargin:Number = 154;
      var topMargin:Number = 169;
      var depth:Number = 100; // starting point for depth
      var drilled:Boolean;
      for (i=1; i<=rows; i++) {
      for (j=1; j<=cols; j++) {
                current = attachMovie("openCircle_mc", "openCircle_mc"+i+"_"+j, depth++);
                current._x = leftMargin + ((i-1) * (spacing + current._width));
                current._y = topMargin + ((j-1) * (spacing + current._height));
      //          current.oil = Math.floor(Math.random()*1.1);  // about 1/10 objects have oil=1, 9/10 oil=0
                //open circle initially invisible, visible on rollOver
                current._alpha = 0;
                          trace(this.row+" "+this.col);
         current.drilled = true;
                current.onRollOver = function() {
                                       this._alpha = 100;
                current.onRollOut = function() {
                                       this._alpha = 0;
      I'd be grateful for any help. Thanks.
