4 Replies Latest reply on Jun 13, 2013 11:13 PM by vinoth_mannu
    Transform selection increase problem
    vinoth_mannu Level 1
      Hi ALL,
      I am trying to apply transform on some selected objects 10 % increase, i could see the part are moved from the orginal place.
      If we try to do select the individual object this works fine.
      Any idea
      var idTrnf = charIDToTypeID( "Trnf" );
          var desc6 = new ActionDescriptor();
          var idnull = charIDToTypeID( "null" );
              var ref3 = new ActionReference();
              var idLyr = charIDToTypeID( "Lyr " );
              var idOrdn = charIDToTypeID( "Ordn" );
              var idTrgt = charIDToTypeID( "Trgt" );
              ref3.putEnumerated( idLyr, idOrdn, idTrgt );
          desc6.putReference( idnull, ref3 );
          var idFTcs = charIDToTypeID( "FTcs" );
          var idQCSt = charIDToTypeID( "QCSt" );
          var idQcsa = charIDToTypeID( "Qcsa" );
          desc6.putEnumerated( idFTcs, idQCSt, idQcsa );
          var idOfst = charIDToTypeID( "Ofst" );
              var desc7 = new ActionDescriptor();
              var idHrzn = charIDToTypeID( "Hrzn" );
              var idRlt = charIDToTypeID( "#Rlt" );
              desc7.putUnitDouble( idHrzn, idRlt, 0.000000 );
              var idVrtc = charIDToTypeID( "Vrtc" );
              desc7.putUnitDouble( idVrtc, idRlt, 0.000000 );
          desc6.putObject( idOfst, idOfst, desc7 );
          var idWdth = charIDToTypeID( "Wdth" );
          var idPrc = charIDToTypeID( "#Prc" );
          desc6.putUnitDouble( idWdth, idPrc, 110.000000 );
          var idHght = charIDToTypeID( "Hght" );
          desc6.putUnitDouble( idHght, idPrc, 110.000000 );
          var idLnkd = charIDToTypeID( "Lnkd" );
          desc6.putBoolean( idLnkd, true );
      executeAction( idTrnf, desc6, DialogModes.NO );
      Regards,
      Vinoth
        • 1. Re: Transform selection increase problem
          pixxxel schubser MVP & Adobe Community Professional
          Does this works for you? (I hope, I understand you right)
          // CopyPasteResize.jsx
          // http://forums.adobe.com/thread/1230010?tstart=0
          // copy, paste and resize to 110%
          // a selection is necessary and the layer can not be blank
          var aDoc = app.activeDocument;
          var Sel = aDoc.selection;
          Sel.copy ();
          aDoc.paste();
          aDoc.activeLayer.resize(110,110, AnchorPosition.MIDDLECENTER)
          Have fun.
          • 2. Re: Transform selection increase problem
            Awesome!!!
            It works well and excellent thinking,
            When i run through ESTK it works fine. but when i created Panels through adobe configurator i could see error
            Regards,
            Vinoth
            • 3. Re: Transform selection increase problem
              Hmmh?
              You have not spoken of use in a panel previously.
              Some conjectures:
              Is "Transform" the correct adobe configurator syntax for "resize"? (I only have CS3 and that's why no configurator)
              And have you implemented a selection? Copy and paste are working in your panel (standalone)?
              • 4. Re: Transform selection increase problem
                Sorry, No idea on the above content.
                i could see the images when we paste it moves a little, but when i do it on individually this is perfect.
                I have also used cut and paste both gives me the same result.
                I think one solution, which is little bit over imagining.
                Step 1 -- Marquee tool selected first object are placed as layer 1, selected second object are placed as layer 2 and so on.
                Step 2  ---  "aDoc.activeLayer.resize(110,110, AnchorPosition.MIDDLECENTER)"
                Step3 --- flatten the document layer
                Step4 --- Close
                Can this be done through scripting.
                Regards,
                Vinoth
