2 Replies Latest reply on Jun 12, 2013 11:59 PM by RNI76
    Title attribute for links in the Rich Text Editor
    RNI76
      Our editors would like to make our site WCAG compatible, but are having problems setting title attributes for hyperlinks.
      Is there any way to allow an editor to set the title attribute when creating a link in the Rich Text Editor?
        • 1. Re: Title attribute for links in the Rich Text Editor
          andyshreve Level 1
          Here is one method to allow adding link titles in the RTE. The RTE uses a plugin named "LinkDialog" located here:
          /libs/cq/ui/widgets/source/widgets/form/rte/plugins/LinkDialog.js
          This dialog appears when you edit a link in the RTE. You can add a "Title Attribute" field to your own custom version of this dialog. In your app create a new folder named "clientlib" with these properties and values:
          • jcr:primaryType  = cq:ClientLibraryFolder
          • sling:resourceType = widgets/clientlib
          • categories = cq.wcm.edit
          In this clientlib folder create a new nt:file named "js.txt" that contains this single line: LinkDialogOverride.js
          In this clientlib folder create a new nt:file named "LinkDialogOverride.js" with the code below:
          * @class CQ.form.rte.plugins.LinkDialogOverride
          * @extends CQ.form.rte.ui.BaseWindow
          * @private
          * The LinkDialogOverride is a dialog for creating a link.
          * It overrides /libs/cq/ui/widgets/source/widgets/form/rte/plugins/LinkDialog.js
          * to let us add a title attribute to a link within the RTE.
          * The primary customizations are in: constructor, dlgFromModel, & dlgToModel.
          * @constructor
          * Creates a new LinkDialogOverride.
          * @param {Object} config The config object
          CQ.form.rte.plugins.LinkDialogOverride = CQ.Ext.extend(CQ.form.rte.ui.BaseWindow, {
              constructor: function(config) {
                  config = config || { };
                  var defaults = {
                      "title": CQ.I18n.getMessage("Hyperlink"),
                      "modal": true,
                      "width": 700,
                      "height": 300,
                      "dialogItems": [ {
                              "itemId": "href",
                              "name": "href",
                              "parBrowse": true,
                              "anchor": CQ.themes.Dialog.ANCHOR,
                              "fieldLabel": CQ.I18n.getMessage("Link to"),
                              "xtype": "pathfield",
                              "ddGroups": [
                                  CQ.wcm.EditBase.DD_GROUP_PAGE,
                                  CQ.wcm.EditBase.DD_GROUP_ASSET
                              "fieldDescription": CQ.I18n.getMessage("Drop files or pages from the Content Finder"),
                              "listeners": {
                                  "dialogselect": {
                                      "fn": this.selectAnchor,
                                      "scope": this
                                  "render": this.initHrefDragAndDrop
                              "validator": this.validateLink.createDelegate(this),
                              "validationEvent": "keyup",
                              "escapeAmp": true
                              "itemId": "title",
                              "name": "title",
                              "xtype": "textfield",
                              "fieldLabel": "Title Attribute",
                              "fieldDescription": "Add text that describes this link",
                              "width": 450,
                              "regexText": "Please no quotes in this field",
                              "regex": /^[^'"]*$/
                              "itemId": "targetBlank",
                              "name": "targetBlank",
                              "xtype": "checkbox",
                              "boxLabel": CQ.I18n.getMessage("Open in new window"),
                              "value": "targetBlank"
                  CQ.Util.applyDefaults(config, defaults);
                  CQ.form.rte.plugins.LinkDialog.superclass.constructor.call(this, config);
               * @private
              selectAnchor: function(pathfield, path, anchor) {
                  // custom path + anchor handling
                  path = CQ.HTTP.encodePath(path);
                  // encodePath will not encode '&', so we're doing it here, as other callees of
                  // encodePath might rely on that documented behaviour - see bug #30206
                  path = path.replace(/&/g, "%26");
                  if (anchor && (anchor.length > 0)) {
                      path += ".html#" + anchor;
                  pathfield.setValue(path);
               * <p>Note that this method is executed in the scope of the pathfield.</p>
               * @private
              initHrefDragAndDrop: function() {
                  if (this.ddGroups) {
                      if (typeof(this.ddGroups) == "string") {
                          this.ddGroups = [ this.ddGroups ];
                      var field = this;
                      var target = new CQ.wcm.EditBase.DropTarget(this.el, {
                          "notifyDrop": function(dragObject, evt, data) {
                              if (dragObject && dragObject.clearAnimations) {
                                  dragObject.clearAnimations(this);
                              if (dragObject.isDropAllowed(this)) {
                                  if (data.records && data.single) {
                                      var record = data.records[0];
                                      var path = record.get("path");
                                      // again, '&' needs to be encoded explicitly - see bug #30206
                                      evt.stopEvent();
                                      return true;
                                  return false;
                      var dialog = this.findParentByType(CQ.form.rte.plugins.LinkDialog);
                      dialog.on("activate", function(dialog) {
                          if (dialog && dialog.el && this.highlight) {
                              var dialogZIndex = parseInt(dialog.el.getStyle("z-index"), 10);
                              if (!isNaN(dialogZIndex)) {
                                  this.highlight.zIndex = dialogZIndex + 1;
                      }, target);
                      dialog.on("deactivate", function(dialog) {
                      }, target);
                      var editorKernel = dialog.getParameter("editorKernel");
                      dialog.on("show", function() {
                          editorKernel.fireUIEvent("preventdrop");
                          CQ.WCM.registerDropTargetComponent(field);
                      }, target);
                      dialog.on("hide", function() {
                          CQ.WCM.unregisterDropTargetComponent(field);
                          editorKernel.fireUIEvent("reactivatedrop");
                      }, target);
                      for (var i = 0; i < this.ddGroups.length; i++) {
                          target.addToGroup(this.ddGroups[i]);
                      target.removeFromGroup(CQ.wcm.EditBase.DD_GROUP_DEFAULT);
                      this.dropTargets = [ target ];
               * Gets a field with the provided key from this panel.
               * @param key Field name
              getField: function(key) {
                  var items = this.find("name", "./" + key);
                  if( (CQ.Ext.isArray(items)) && (items.length > 0) )
                      return items[0];
              preprocessModel: function() {
                  var showAdvanced = false;
                  if (this.objToEdit && this.objToEdit.dom) {
                      this.objToEdit.href = CQ.form.rte.HtmlRules.Links.getLinkHref(
                              this.objToEdit.dom);
                      var com = CQ.form.rte.Common;
                      var attribNames = com.getAttributeNames(this.objToEdit.dom, false,
                          function(dom, attribName, attribNameLC) {
                              // exclude href, rte_href & target from generic attribute handling, as
                              // they are handled explicitly and not genrically
                              return attribNameLC == com.HREF_ATTRIB || attribNameLC == "href"
                                      || attribNameLC == "target";
                      for (var i = 0; i < attribNames.length; i++) {
                          var attribName = attribNames[i];
                          var value = com.getAttribute(this.objToEdit.dom, attribName);
                          if (typeof value !== 'undefined') {
                              this.objToEdit.attributes[attribName] = value;
                      if (this.objToEdit.attributes.onclick) {
                          showAdvanced = true;
                  var advancedField = this.getField("linkdialog/cq:adhocLinkTrackingTab");
                  if (advancedField) {
                      if (showAdvanced) {
                          advancedField.expand(false);
                      } else {
                          advancedField.collapse(false);
              /* dlgFromModel fires when dialog opens. Sets the values in the dialog fields. */
              dlgFromModel: function() {
                  /* HREF ATTRIBUTE */
                  var hrefField = this.getFieldByName("href");
                  if (hrefField) {
                      var value = "";
                      if (this.objToEdit) {
                          var href = this.objToEdit.href;
                          if (href) {
                              value = href;
                      hrefField.setValue(value);
                  /* TARGET ATTRIBUTE */
                  var targetBlankField = this.getFieldByName("targetBlank");
                  if (targetBlankField) {
                      var target = (this.objToEdit && this.objToEdit.target
                              ? this.objToEdit.target.toLowerCase() : null);
                      targetBlankField.setValue(target == "_blank");
                  /* TITLE ATTRIBUTE */
                  var titleField = this.getFieldByName("title");
                  if (titleField) {
                      var tval = "";
                          var title = this.objToEdit.attributes.title;
                          if (title) {
                              tval = title;
                      titleField.setValue(tval);
                  if (typeof CQ_Analytics !== 'undefined' && typeof CQ_Analytics.adhocLinkTracking !== 'undefined' && CQ_Analytics.adhocLinkTracking == "true") {
                      var enableField = this.getField("linkdialog/cq:adhocLinkTrackingEnableTracking");
                      var eventsField = this.getField("linkdialog/cq:adhocLinkTrackingEvents");
                      var evarsField = this.getField("linkdialog/cq:adhocLinkTrackingEvars");
                      if (eventsField && evarsField) {
                          var events = "", evars = "", enable = false;
                              var value = this.objToEdit.attributes.adhocevents;
                                  events = value;
                              value = this.objToEdit.attributes.adhocevars;
                                  evars = value;
                              value = this.objToEdit.attributes.adhocenable;
                                  enable = value == "true";
                          eventsField.setValue(events);
                          evarsField.setValue(evars);
                          enableField.setValue(enable);
                          this.enableSCFields(enable);
                  else {
                      var trackBox = this.getField("linkdialog/cq:adhocLinkTrackingTab");
                      if (trackBox) {
                          trackBox.hide();
              /* dlgToModel fires when OK btn is clicked. Puts field values back into the RTE. */
              dlgToModel: function() {
                      if (hrefField) {
                          var href = hrefField.getValue();
                          if (href) {
                              this.objToEdit.href = href;
                          if (targetBlankField.getValue()) {
                              this.objToEdit.target = "_blank";
                          } else {
                              this.objToEdit.target = null;
                      if (titleField) {
                          var title = titleField.getValue();
                          if (title) {
                              this.objToEdit.attributes.title = title;
                      if (enableField && eventsField && evarsField) {
                          this.objToEdit.attributes.adhocenable = enableField.getValue() ? "true" : "false";
                          this.objToEdit.attributes.adhocevents = eventsField.getValue() || "";
                          this.objToEdit.attributes.adhocevars = evarsField.getValue() || "";
                          if (enableField.getValue()) {
                              this.objToEdit.attributes.onclick = "CQ_Analytics.Sitecatalyst.customTrack(this)";
                          } else {
                              delete this.objToEdit.attributes.onclick;
                              if (this.objToEdit.dom && this.objToEdit.dom.attributes) {
                                  CQ.form.rte.Common.removeAttribute(this.objToEdit.dom, "onclick");
              enableSCFields: function(state) {
                  if(state) {
                      eventsField.enable();
                      evarsField.enable();
                  } else {
                      eventsField.disable();
                      evarsField.disable();
              postprocessModel: function() {
                  var linkRules = this.parameters.linkRules;
                  if (linkRules) {
                      linkRules.applyToObject(this.objToEdit);
              validateLink: function() {
                  var href = this.getFieldByName("href");
                  if (!href) {
                      return false;
                  href = href.getValue();
                  var linkRules = this.getParameter("linkRules");
                  if (!linkRules) {
                      return (href.length > 0);
                  return linkRules.validateHref(href);
          // register LinkDialogOverride component as xtype
          CQ.Ext.reg("rtelinkdialog", CQ.form.rte.plugins.LinkDialogOverride);
          • 2. Re: Title attribute for links in the Rich Text Editor
            RNI76 Level 1
            Thanks a lot, Andy!
