1 Reply Latest reply on Jun 12, 2013 9:31 AM by jcanepa
    Help text
    TdM17
      I made an PDF Form (local) and add some help text in the form and some obligatory fields. However in the concerning fields I don't see any message or help text. For example the fields "datum" and so on ar obliged. but still i can save the file whitout filling it in.
      Kind regards
      TdM
        • 1. Re: Help text
          jcanepa Adobe Employee
          The help text is in tooltips in the PDF file.  You need to hover your cursor over the field in question and you will see the tooltip with the help text.  As for marking fields as required, the check for if a required field is filled out occurs on data submit (after you click the Submit button).  Hope this helps.
          Jeff Canepa
          Software Quality Engineer
          Adobe Systems, Inc.
          jcanepa@adobe.com
