3 Replies Latest reply on Jun 12, 2013 7:33 AM by Jim_Simon
    Which Premiere Pro (CS6) project settings should I be using?
    Goodpractice Level 1
      Hi there
      I am currently trying to use Premiere Pro CS6 to edit a Skype video call I recorded using Super Tintin, and I'm not sure what project settings I should l be using.
      At the moment I am selecting HDV/HDV1080i25 (50i) when I set up the project, but when I come to add the video file to the project timeline, I am told that the file settings do not match the sequence settings and I am prompted to either change the settings, or keep the existing ones.
      When I select 'keep existing settings' the video appears in a very small box in the centre of a large black screen, which obviously isn't what I'm looking for. When I select 'change sequence settings', however, the video fills the screen, which is great, but the video and audio are out of synch (when I play the file outside of CS6, they are in synch). Any idea what I'm doing wrong?
      If it helps, here is some info regarding the file I'm currently working with:
      MP4, 9MB
      Frame width: 320
      Frame height: 240
      Frame rate: 14 frames/second
      Data rate: 529 kbps
      Any advice or guidance would be greatly appreciated! Many thanks.
