This content has been marked as final.
Show 1 reply
1. Re: Annotating or animating freeze frames
aronbothman Aug 16, 2013 2:15 PM (in response to raman108)Hi Raman,
One approach to the "live drawing" problem could be:
1. Pre-plan the drawing. Put this in gray on a layer in Photoshop.
2. Take a screen recording, using Quicktime 7 or some other program. Start a screen recording, then trace your drawing plan using the Brush tool in Photoshop in some color that is different from the cursor or the drawing plan, say in blue.
3. Import the screen recording into After Effects and use Color Key effects to remove the colors of the underdrawing and the Brush cursor. You will then have the "live drawing" which you can incorporate into your freeze-frame image using whatever method you want.
Hope this helps!
