7 Replies Latest reply on Jun 12, 2013 2:41 PM by Laubender
    [CS5.5][JS] How to get anchored object by text search result?
    JohnDevlon Level 1
      I need to get the anchored object by text search result. This can be an image, textframe, grouped objects...
      This is my code...
                  app.findTextPreferences = NothingEnum.nothing;
                  app.findTextPreferences.findWhat = "<FFFC>";
                  var myResults = app.activeDocument.findText();
                  var currentParagrapfNum = -1;
                  for (var n = 0; n < myResults.length; n++){
                              var currentResult = myResults[n];
                              currentParagrapfNum  = currentResult.paragraphs[0].index;
                              var currentAnchoredObject = ??? ;
                              currentAnchoredObject.anchoredObjectSettings.horizontalReferencePoint = AnchoredRelativeTo.TEXT_FRAME;
                              currentAnchoredObject.anchoredObjectSettings.verticalReferencePoint = VerticallyRelativeTo.LINE_BASELINE
      Can someone please help me?
      Thanx
        • 1. Re: [CS5.5][JS] How to get anchored object by text search result?
          Peter Kahrel Adobe Community Professional & MVP
          Look for ^a (which stands for anchored object). Something along the lines of
          app.findTextPreferences.findWhat = "^a";
              myResults[n].anchoredObjectSettings.horizontalReferencePoint = AnchoredRelativeTo.TEXT_FRAME;
              myResults[n].anchoredObjectSettings.verticalReferencePoint = VerticallyRelativeTo.LINE_BASELINE
          It's not clear what you want with currentParagrapfNum, by the way.
          Peter
          • 2. Re: [CS5.5][JS] How to get anchored object by text search result?
            JohnDevlon Level 1
            Hi Peter,
            Thanks for the "^a" tip.
            Unfortunately the anchoredObjectSettings property doesn't exists in the search result item.
            The item is a character object. Any suggestions?
            • 3. Re: [CS5.5][JS] How to get anchored object by text search result?
              Yes, true, ^a finds anchors but they're type character. What you need is
              myResults[n].pageItems[0].anchoredObjectSettings.horizontalReferencePoint = AnchoredRelativeTo.TEXT_FRAME;
              Peter
              • 4. Re: [CS5.5][JS] How to get anchored object by text search result?
                @John – yes, it's a character, but the character has a pageItems.length.
                Or a specific textFrames.length if the anchored object happens to be a textFrame. Or a rectangles.length, if it happens to be such an object, etc.pp.
                So myFoundCharacter.pageItems[0] is the anchored object.
                From that it's easy to get the anchoredObjectSettings:
                myFoundCharacter.pageItems[0].anchoredObjectSettings.properties.toSource();
                Uwe
                • 5. Re: [CS5.5][JS] How to get anchored object by text search result?
                  JohnDevlon Level 1
                  Hi Peter,
                  Thanks for your feedback. It works great.
                  John
                  • 6. Re: [CS5.5][JS] How to get anchored object by text search result?
                    JohnDevlon Level 1
                    Hi Laubender;
                    Thanks for your reply.
                    John
                    • 7. Re: [CS5.5][JS] How to get anchored object by text search result?
                      @John – it's a bit more tricky to find out what type of anchored object you have found.
                      E.g.:
                      myResults[n].pageItems[0].constructor.name
                      will always return [object PageItem] and not the specific: [object TextFrame] or [object Rectangle] or [object Group]…
                      I think you get the idea.
                      The problem with that is:
                      You get an error (even if you know the anchored object is a text frame!), if you ask for:
                      myResults[n].pageItems[0].insertionPoints.length;
                      PageItems have no property insertionPoints, TextFrames (among other objects) have!
                      One workaround would be to test for a specific string with the properties of pageItems[0] put toSource():
                      var myFoundCharacter = myResults[n];
                      var myAnchoredObject = myFoundCharacter.pageItems[0];
                      //Test for TextFrame:
                      var regExpression = /\/\/text-frame\[@id=/;
                      if(regExpression.test(myAnchoredObject.properties.toSource())){
                          //the variable "myAnchoredObject" previously points to a pageItem, now it points to a textFrame:
                          myAnchoredObject = myFoundCharacter.textFrames[0];
                          var insPointsLength = myAnchoredObject.insertionPoints.length;
                          alert("Anchored Object is: TextFrame"+"\t"+"Number of insertion points: "+insPointsLength);
                      else{alert("Found anchored object is not a text frame.")};
                      I came up with that spontaniously.
                      There might be better methods.
                      I think we have already discussed that here in this forum.
                      (But I'm too lazy to search for it right now ;-)
                      Time for me to go to bed here in Germany…)
                      Uwe
