3 Replies Latest reply on Oct 17, 2007 7:56 AM by larksys
    cfinput autosuggest
    larksys Level 1
      I'm a little frustrated with CF8 and the new Spry functions. I'm trying to convert my old autosuggests to the cfinput and binding with a function in a cfc. I'm trying to follow the examples but getting the following error;
      Error invoking CFC /components/tsijobads cfc. Internal server error (enable debugging .......)
      The code is;
      <cffunction name="getCompanies" access="remote" returntype="array" output="false" description="Returns submission titles">
      <cfargument name="term" type="string" required="true">
      <cfset var CnameQry = "">
      <cfquery name="CnameQry" datasource="AS400" dbtype="ODBC" maxrows="50">
      SELECT rtrim(ltrim(csnam1)) as cname, rtrim(ltrim(csstat)) as state, rtrim(ltrim(cscity)) as city, csrec## as companyid
      FROM cstatic
      WHERE UPPER(csnam1) LIKE <cfqueryparam cfsqltype="cf_sql_varchar" value="#ucase(left(arguments.term,255))#%">
      order by csnam1,cscity
      </cfquery>
      <!--- Build result array --->
      <cfset Carray = listotarray(CnameAry.csnam1)>
      <cfreturn Carray>
      </cffunction>
      <cfinput name="sfCname#counter#" id="sfCname#counter#" autosuggest="cfc:400comps.tsijobads.getCompanies({cfautosuggestvalue})" maxResultsDisplay="50">
        • 1. Re: cfinput autosuggest
          Level 7
          > debugging .......)
          your error says your cfc is in /components/tsijobads
          your cfinput bind says it is in 400comps.tsijobads
          either on of them is a typo or you are trying to use a mapped cf folder,
          which is not allowed with ajax calls.
          Azadi Saryev
          Sabai-dee.com
          http://www.sabai-dee.com
          • 2. Re: cfinput autosuggest
            larksys Level 1
            This code works;
            <cfinput name="sfCname#counter#" id="sfCname#counter#" size="40" autosuggest="cfc:400comps.tsijobads.getCompanies({cfautosuggestvalue})" maxResultsDisplay="50">
            <cffunction name="getCompanies" access="remote" returntype="string">
            <cfargument name="term" type="any" required="false" default="">
            FROM cstatic
            </cfquery>
            <cfreturn ValueList(CnameQry.cname)>
            </cffunction>
            This code does not;
            <cfinput type="text" name="sfiname#counter#" id="sfiname#counter#" autosuggest="cfc:400comps.tsijobads.getIndividualsH({cfautosuggestvalue})" maxResultsDisplay="50">
            <cffunction name="getIndividualsH" access="remote" returntype="string">
            <cfset var IndivQry = "">
            <cfquery name="IndivQry" datasource="AS400" dbtype="ODBC" maxrows="50">
            SELECT rtrim(ltrim(isfnam)) as FNAME, rtrim(ltrim(islnam)) as LNAME, rtrim(ltrim(istitl)) as ITITLE, iswfon as WPHONE, isrec## as RECNUM
            FROM istatic
            WHERE UPPER(islnam) LIKE <cfqueryparam cfsqltype="cf_sql_varchar" value="#ucase(left(arguments.term,255))#%">
            ORDER by islnam,isfnam
            </cfquery>
            <cfreturn ValueList(IndivQry.isfnam)>
            </cffunction>
            I don't think the mapped folder is the problem. I solved part of the problem by changing the function output type to "string" and returning a list. Some of the examples and cfml ref are just plain wrong. Hard to believe, huh.
            I just noticed that I have a type of "text" on one cfinput and not the other. I just tested it without "text" and it didn't make a difference.
            • 3. Re: cfinput autosuggest
              larksys Level 1
              Started from scratch using cfinput and autosuggest. It works fine. I just can't find the error in the above code.
