2 Replies Latest reply on Jun 13, 2013 2:46 AM by DriveFST
    solution to using parent statement in CS3
    DriveFST
      Dear forum!.
      I have found trouble in using term "parent" in script esp. in CS3. wherelse in CS5.5 it works like a honey.
      And honestly to say, this taken from the discussion of Mr. Jump_over ...
      app.findTextPreferences.findWhat = "text";
      app.changeTextPreferences.changeTo = "Material";
      myFound = myFrame.findText();
      var k = myFound.length;
      while (k--)
      if (myFound[k].parent.constructor.name !== "Cell")
      myFound[k].changeText();
      It doesn't works in CS3. (ESTK highlights on if (myFound[k].parent.constructor.name !== "Cell") and says "undefined is not an object";
      I guess, the problem may because of the term Parent. Well in CS5.5 this error has not been encountered.
      thanks,
      @Chand...
        • 1. Re: solution to using parent statement in CS3
          Jump_Over Level 5
          I think is not about a "parent" but "constructor.name".
          I am not experienced with CS3 but you could try use this:
          while(k--) {
               try {
                    myFound[k].parent.parentStory;     // error if parent == "Cel" so omited
               catch (e) { continue }
          Jarek
          • 2. Re: solution to using parent statement in CS3
            DriveFST Level 1
            Fantastic Jarek!, The Genius work!
            Instead, i can able to do it,
            while(k--) {
            //     try {
                     // myFound[k].parent.parentStory;     // error if parent == "Cel" so omited
                      myFound[k].changeGrep();
            SPlendid, thanks to you.
            @Chand
