1. Re: Header Rows in Tables
[Ariel] Jun 13, 2013 4:21 AM (in response to HSGROW_HK)No, there isn't.
But if you take the table heading outside the table as a separate
paragraph, you won't have a problem.
Ariel
2. Re: Header Rows in Tables
HSGROW_HK Jun 13, 2013 4:27 AM (in response to [Ariel])Hi Ariel,
That's what I have at the moment, however we need to change the layout of the document and put all the tables in the centre. Thus by leaving the caption outside of the table as it is now, it will not wrap properly - I have tried doing seperate frames but it messes up the table of contents listing :-( hence, by putting the caption in the header it works beautifully. Unless you can think of a work around for that?
3. Re: Header Rows in Tables
[Ariel] Jun 13, 2013 4:30 AM (in response to HSGROW_HK)Sorry - I'm not understanding what you're saying. Where are you putting
the tables? What won't wrap properly? Why does separate frames mess up
the TOC?
Ariel
6. Re: Header Rows in Tables
[Ariel] Jun 13, 2013 5:14 AM (in response to HSGROW_HK)Well, why not just center the table heading? And add left and right indent if you need it to be no wider than the table...
7. Re: Header Rows in Tables
HSGROW_HK Jun 14, 2013 6:56 PM (in response to [Ariel])Hi Ariel,
Sorry for late reply - no internet access :-(
OK, Yes that's a good idea - is there a way of snapping the indent to the edge of the table, so that all headers can be consistent rater that a hit-and-miss affair?
