9 Replies Latest reply on Jun 15, 2013 4:10 AM by lewis_cooper
    Modification Needed to Jongware's CopyCutter
    lewis_cooper
      Hi all,
      I've tried and failed to do this myself so I'm hoping that someone or even Jongware himself can help me out. I'd previously asked this question: http://forums.adobe.com/message/2865783#2865783 and I ended up with a modified version of Jongware's CopyCutter.
      Unfortunately the formatting of my document has changed so I need to modify the script to take these changes in to account. Could someone please help me?
      Here is how my copy currently looks:
      This is what I want to select and apply the script to:
      And this is the result I'm hoping to get (Note the missing \n\n at the beginning too):
      Bonus points: I'd quite like the resulting text boxes to be given an object style that I could define.
      And for reference here is the script that I currently have (link at beginning of post my provide more context):
      if (app.selection.length == 1 && app.selection[0].hasOwnProperty("baseline") && app.selection[0].length > 1)
       app.selection[0].insertionPoints[0].contents = "\r";
       app.selection[0].insertionPoints[-1].contents = "\r";
       app.findGrepPreferences = null;
       app.changeGrepPreferences = null;
       app.findGrepPreferences.findWhat = " +";
       app.changeGrepPreferences.changeTo = "\\r";
       app.selection[0].changeGrep();
       p = app.selection[0].parentTextFrames[0];
       lh = (p.lines[-1].baseline - p.lines[0].baseline) / (p.lines.length-1);
       top = app.selection[0].lines[0].baseline - lh;
       while (app.selection[0].length > 0)
        f = app.activeDocument.layoutWindows[0].activePage.textFrames.add ({geometricBounds:[top, p.geometricBounds[3]+2*lh, top+lh, 2*(lh+p.geometricBounds[3])-p.geometricBounds[1] ]});
        app.selection[0].lines[0].move (LocationOptions.AFTER, f.texts[0]);
        top += lh;
       app.selection[0].insertionPoints[-1].contents = "";
      } else
       alert ("please select some text to shred");
        • 1. Re: Modification Needed to Jongware's CopyCutter
          Jump_Over Level 5
              mObjSt = app.activeDocument.objectStyles.item("your oSt_name");
              app.findGrepPreferences = app.changeGrepPreferences = null;
              app.findGrepPreferences.findWhat = "(\\u)(?=~s)";
              app.changeGrepPreferences.changeTo = "\\r\$1";
              app.findGrepPreferences.findWhat = "\\n\\n\\r";
              app.changeGrepPreferences.changeTo = "";
                top += lh;
                f.appliedObjectStyle = mObjSt;
               p.characters[-1].contents = "";
          } else
          did it?
          (edit objectStyle name in 2nd line)
          Jarek
          • 2. Re: Modification Needed to Jongware's CopyCutter
            lewis_cooper Level 1
            Hi, thank you very much for your help. Unfortunately this error message was returned:
            • 3. Re: Modification Needed to Jongware's CopyCutter
              Jump_Over Level 5
              It works on my empty 1-frame doc...
              before line 13 insert alert to check an error source:
              alert(p.isValid);
              alert(p.lines[-1].baseline);
              what they show?
              Jarek
              • 4. Re: Modification Needed to Jongware's CopyCutter
                Forgive me, it is now working! I forgot to select the first two \n\n before executing the script .
                The result gives me this:
                How can I have the "\r" removed from the end of each line?
                Thank you by the way!
                • 5. Re: Modification Needed to Jongware's CopyCutter
                  Jump_Over Level 5
                  last line inside a while loop:
                  if (f.lines[-1].contents.indexOf("\r") != -1) f.characters[-1].contents = "";
                  Jarek
                  • 6. Re: Modification Needed to Jongware's CopyCutter
                    Hmmmm, doesn't seem to work for me. Although I'm not sure I understand 'while loop'.
                    I did it like this:
                        mObjSt = app.activeDocument.objectStyles.item("Colour Label Grey");
                        app.findGrepPreferences.findWhat = ", ";
                          top += lh;
                    } else
                    • 7. Re: Modification Needed to Jongware's CopyCutter
                      Jump_Over Level 5
                      I ment this part of code:
                           top += lh;
                      last line added here
                      Jarek
                      • 8. Re: Modification Needed to Jongware's CopyCutter
                        Hi Jarek,
                        Thank you very much, this is now quite simply perfect! I really appreciate your help with this.
                        Lewis
                        • 9. Re: Modification Needed to Jongware's CopyCutter
                          Hi Jarek,
                          Sorry to dig this up again! The script is working great but if I try to execute it without extending the bottom of the text frame down, I get an error message.
                          For example;
                          If execute the script when the text frame is 'tight' to the copy like this:
                          I get this error message:
                          However, if I drag the base of the text frame down to give more space like this:
                          The script executes without a problem. Is there something I can do to stop this??
