1 Reply Latest reply on Jun 17, 2013 6:46 AM by Willam van Weelden
    Assigning Screen Layout to Screen Profile
    Ofer Goren
      I am a RH10 user.
      I am trying to generate a help file for a specific screen (resolution).
      How do I set up RH to do this, when facing the following "predicaments":
      • In the Projects Setup pod, I have defined 2 new objects:
        • Screen Profile
        • Screen Layout
              How do I get RH to assign one to the other?
      • When I get to the generating stage, I select Multiscreen... or do I...?
        What do I do to generate a file for ONLY that specific screen?
      TIA,
      O. Goren
        • 1. Re: Assigning Screen Layout to Screen Profile
          Willam van Weelden Adobe Community Professional & MVP
          You assign Screen Layouts to Screen Profiles during generation. (In the Single Source layout)
          In the Single Source Layout, go to the entry Screen Profiles. You can add and remove Screen Profiles. And you also select a Screen Layout for every profile there.
          If you want to generate output for only that specific screen, only add a single Screen Profile in the SSL.
          Greet,
          Willam
