3 Replies Latest reply on Jun 13, 2013 11:45 AM by MarkWalsh
    Acrobat Scripting Open EPS Files Failed
    trundo Level 1
      Trying to open am .EPS file using AcroPDDoc and it is not working.  Any ideas?
      Using VS 2010
           Reference COM Object Adobe Acrobat 9.0 Type Library
      C# code
           AcroPDDoc testDoc = new AcroPDDoc();
           bool c = testDoc.Open(filepath);
           string t = testDoc.GetInfo("Author");
      I get nothing, even the boolean c is not even set.
      What I am trying to do is find out what application was used to create the .EPS file (i.e. Illustrator C2, Illustrator C6, CorelDRAW x5, etc.)?
      Any ideas?
      Tom
        • 1. Re: Acrobat Scripting Open EPS Files Failed
          MarkWalsh Level 4
          Can you read the binary data for the file in Visual Studio? If so, look for a line starting with '%%Creator'. The rest of the line should be the application and version info (at least it is with the various EPS files I checked; don't have CorelDraw to test)
          • 2. Re: Acrobat Scripting Open EPS Files Failed
            trundo Level 1
            Mark,
            OK I understand where you are going.
            Now here is one issue.
            I can open 1 EPS file in Acrobat and in the properties it shows Application is CorelDraw x5.
                 Looking at the binary it shows Creator as
                      /CreationDate (D:20130612013722-04'00')
                      /ModDate (D:20130612013722-04'00')
                      /Producer           <feff0043006f00720065006c002000500044004600200045006e00670069006e006500200056006500720073 0069006f006e002000310035002e0032002e0030002e003600360031>
                      /Author <feff004e006900670068007400200049006e007300740072007500630074006f0072>
                      /Creator <feff0043006f00720065006c0044005200410057002000580035>
                      /Title <feff00630068006500650072>
                 This file would be a problem since I can't get the Creator.
            I can open other .EPS files in Acrobat in the properties it shows Application is Illustrator.
                 Looking at the binary it shows Create as:
                      <xmp:CreatorTool>Adobe Illustrator CS6 (Macintosh)</xmp:CreatorTool>
                 This file would not be a problem at all.
            And opening a CorelDraw file (.CDR) is all binary and no text that is understandable.
            • 3. Re: Acrobat Scripting Open EPS Files Failed
              MarkWalsh Level 4
              Don't look for 'Creator', look for '%%Creator' -include the %% in the search (there may be several lines which include 'Creator', but should only be one that starts with '%%Creator'). Again, not sure if the CorelDraw files conform to this or not.
              Edit: that assumption may not be accurate, there may be multiple lines which start with %%Creator - but those lines should contain the application info.
