1 Reply Latest reply on Jul 25, 2013 11:37 AM by Hibou
    mandatory field
    ashr1971
      Is there a way to set a field in a form that unless they fill out that field they cannot fill out the rest of the form?
      Thanks!!!
        • 1. Re: mandatory field
          Hibou
          2 ways of doing this:
          1. You make the rest of the fields wrapped in a subform and then set visibility of the subform so that only when field is non-empty the subform is visible, by setting property :
            • Subform.presence="visible".
          2. You can set the access levels of the fields initially to protected and later only in case field is non-null enable users to edit the fields, using the access property:
            • TextField.access="open";           //"open" to unprotect the fields
