1 Reply Latest reply on Jun 15, 2013 2:34 AM by DriveFST
    remove subMenuItems from created menu
    DriveFST
      Hi Forum!.
      I have added menuItem("AUTOMATION") in menu and subMenuItem("selectImageParent"); (to run the script "selectImageParent" by selecting from menu:
      var myScript1 = new File(app.filePath + "~D:\Adobe\InDesign\Version 5.0\Scripts\Scripts Panel\selectImageParent");
      var myScriptAction1 = app.scriptMenuActions.add("selectImageParent");
      var myEventListener1 = myScriptAction1.eventListeners.add("onInvoke", myScript1, false);
         try{
          var myScriptMenu = app.menus.item("$ID/Main").submenus.item("AUTOMATION");
          myScriptMenu.title;
      catch (myError){
          var myScriptMenu = app.menus.item("$ID/Main").submenus.add("AUTOMATION");
         var myScriptMenuItem1 = myScriptMenu.menuItems.add(myScriptAction1);
      Thing is i, cant able to remove the add subMenuItem(selectImageParent) just keeping the menuItem("Automation") unremoved.
      HERE IT REMOVE THE ENTIRE MENU AND THE SCRIPT
      var myScriptMenu = app.menus.item("$ID/Main").submenus.item("AUTOMATION").remove();
      INSTEAD I WANT TO REMOVE ONLY THE subMenu "selectImageParent" under Automation.
      Any help on this please.
        • 1. Re: remove subMenuItems from created menu
          DriveFST Level 1
          Here in this way, that can i got it....
          app.menus.item("$ID/Main").submenus.item("Scripts").remove();
          Now when i adding one more submenu like this...
          var myScriptMenu = app.menus.item("$ID/Main").submenus.item("Scripts").submenus.add("Sub_script");
          Forum, after adding, when i try to select and run the script.... nothing found to be done.... i have saved the script here...
          var myScript1 = new File(app.filePath + "~D:\Adobe\InDesign\Version 5.0\Scripts\Scripts Panel\selectImageParent.jsx");
          var myScriptAction1 = app.scriptMenuActions.add("selectImageParent.jsx");
          Please help me to access the script through the submenus created....
