1 Reply Latest reply on Jun 14, 2013 5:34 PM by Genevieve Laroche
    how do i expand a field in a line with 3 other fields when forms design will not allow
    nelson871
      how do i expand a field in a line with 3 other fields when forms design will not allow it? I also want to shrink one of the fields and cannot do so.
        • 1. Re: how do i expand a field in a line with 3 other fields when forms design will not allow
          Genevieve Laroche Adobe Employee
          It is possible that all there is not enough room on your line to grow the field. You can try a few things :
          - Make the form width wider by dragging the right edge of the form or via the Form Setup dialog (File > Form Setup... and change the Form Width)
          - You can make other field on the row narrower (if they are not already at their minimum width).
          Each field type has a minimum width. What field type are you trying to make smaller?
          For example : Text and Multiline can go down to a width of 30. Dropdown min width depends on the length of the long item in the dropdown list.
          Hope this helps
          Gen
