Hi All,
I am also facing the issue where i am running publisher author is starting in up.
I am trying to install both author and publisher CQ5.6 installations in linux machine. the steps which i folled is below
1> i created an folder author and copied the quickstart.jar and licence porperties into it
2) i renamed the file to aem5.6-author-p4502.jar and unpacked it using java -jar aem5.6-author-p4502.jar -unpack
3)once it got unpacked succesfully i went inside /crx-quickstart/bin and ran ./start . the CQ author instance ran succesfully and i am able to see the login page on browser
4) next i created one publish folder and inside it i copied the jar and licence properties.
5)after that i renamed the jar to aem5.6-publish-p4503.jar and unpacked it and went inside /crx-quickstart/bin and started the publish server by ./start
interestingly publisher started running on port 4502 and when i check the browser http://localhost:4503/ dosent come up only author is running. I am doing this in Red Hat Linux and I am using AEM 5.6.
Please let me know if i am missing any confguration.
may you check: ps -ef |grep java if the publisher is running?
also check error.log, stdout.log and log under logs/crx and server/logs to see if any issue. e.g. port is in use. try to run: netstat -an | grep 4503
to check also if there is listening on port 4503
paste the error you see in this forum for us to check.
thanks!
In the publisher start up script have you change runmode to publish ?
