hi ;
I have one flash file & more of swf files which work with xml files .
when I load one swf file into my flash file and remove it and load anther one on the same movieclip in my flash file it load the old swf file.
when i load one on movieclip and remove it and load anther swf on anther movieclip the file doesn`t work and stoped.
when test my flash file to load and remove swf files without xml file it work fine but when repleaced the swf files with other work with xml files the problem hapend.
thanks;
YOu should trace the names of the files that are being targeted for loading to see if they agree with what you expect. If you want help with the coding you will need to show the code that is relevant to your problem (not all of it)
