3 Replies Latest reply on Jun 15, 2013 4:03 PM by kglad
    Script slowing computer message
    JonnyDL Level 1
      I had written a script a while ago, that I got to work with no problems, I wanted to make it a bit better/dynamic (boxes can transition left to right or top to bottom), but Im having a problem. I start the script and the tweens start, but I get the error waring me the script wil slow down my computer. I hadn't change the script that drastically so Im not sure why its not working. I tried removing clips, different test but I can't see/trace the problem.
      can anybody help?
      stop();
      import mx.transitions.Tween;
      import mx.transitions.easing.*;
      Block = new Array();
      var Xposition:Number = 0;
      var Yposition:Number = 0;
      var verticalCount:Number=Math.ceil(Stage.height/30);
      var horizontalCount:Number=Math.ceil(Stage.width/30);
      var fadeit:Tween;
      var scaleitx:Tween;
      var scaleity:Tween;
      var n:Number = 0;
      var valueFromArray:Number
      var arrayToRandom:Array = new Array();
      var nextSet:Number = 0;
      this.createEmptyMovieClip("mcholder", this.getDepth());
      //mcholder.swapDepths(1000);
      /////places them onto the stage this configuration is sky skyscraper/ reverse for leader
      function leftToright ()
                for (r=0; r<(verticalCount); r++)
                          for (c=0; c<(horizontalCount); c++)
                                    var particle = mcholder.attachMovie("block","block_"+r+c ,mcholder.getNextHighestDepth());
                                    particle._y = Yposition
                                    particle._x = Xposition
                                    Block[n] = particle;
                                    //trace(particle._name)
                                    Xposition = Xposition + 30;
                                    n++
                          Xposition = 0;
                          Yposition=Yposition+30;
                          for(var i:Number = 0; i<=horizontalCount-1; i++)
                          arrayToRandom.push(i);
                //RandomArrayToTween ()
      function topTobottom ()
                for (r=0; r<(horizontalCount); r++)
                          for (c=0; c<(verticalCount); c++)
                                    Yposition = Yposition + 30;
                                    n++
                          Yposition = 0;
                          Xposition=Xposition+30;
                ///builds an array with a given number of empty pockets to use as a recrence for random numbers
                //not repeating
                for(var i:Number = 0; i<=verticalCount-1; i++)
      //leftToright ()
      topTobottom ()
      trace(arrayToRandom.length)
      trace(arrayToRandom[2])
      function randomarray (u)
      for(var i:Number = 0; i<=numOfChoices-1; i++)
                          arrayToRandom.push( (i+u));
      function RandomArrayToTween ()
                if (arrayToRandom.length > 0)
                          var randomPos:Number = Math.floor( Math.random() * arrayToRandom.length );
                          var valueFromArray = arrayToRandom.splice(randomPos, 1);
                          var numberRand = parseInt(valueFromArray);
                          tweenblock(numberRand);
                          else
                          nextSet=nextSet+arrayToRandom.length
                          stop();
                          randomarray(nextSet);
      function tweenblock(n):Void
                var fadeit = new Tween(Block[n], "_alpha", Strong.easeInOut, 100, 0, .5, true);
                var scaleitx = new Tween(Block[n], "_xscale", Strong.easeInOut, 100, 0, .5, true);
                var scaleity = new Tween(Block[n], "_yscale", Strong.easeInOut, 100, 0, .5, true);
                fadeit.onMotionChanged = function() {
                          onEnterFrame = function ()
                                    if (n !== Block.length)
                                              delete onEnterFrame;
        //removeMovieClip.Block[n];
                                    //else
                                              //delete onEnterFrame;
                                              //stop();
                                              //gotoAndPlay(2);
