1. Re: make text watermark on top of background image
abeddie Jun 17, 2013 4:43 AM (in response to Ayman..)BeginPage executes at the beginning or before your image. Change it to EndPage which executes after.
2. Re: make text watermark on top of background image
Ayman.. Jun 17, 2013 6:56 AM (in response to abeddie)thank u ,
i tried to replace BeginPage with EndPage
but it doesnt work , i got an error when opening the file using ghostview
here is the log
--- Begin offending input ---
72 ,1 \344\350\351\361\370\341\351\360\345\340\344 \352\370\343)SH
1203 194 1111 53 CL
2024 237 MT
(4353701 \344\360\360\362\370)SH
1203 247 1111 53 CL
2000 290 MT
(09-7780778 :\354\350)SH
46 141 1315 53 CL
46 188 MT
%%IncludeResource: font David-Bold-ISOLatinHebrew
/David-Bold-ISOLatinHebrew 11 1 FN
(1 University Road, POB 808)SH
SHP
%%PageTrailer
EP
%%Trailer
restore
%%Pages: 1
%%EOF
--- End offending input ---
file offset = 0
gsapi_run_string_continue returns -101
Unrecoverable error: typecheck in if
Operand stack:
--nostringval-- 2 --nostringval--
3. Re: make text watermark on top of background image
abeddie Jun 17, 2013 8:25 AM (in response to Ayman..)<<
/EndPage
pop pop save initgraphics
/Times-Roman 140 selectfont
200 100 moveto
60 rotate
(DRAFT) show restore
true
>> setpagedevice
.9 0 0 setrgbcolor
72 72 500 600 rectfill
showpage
Instead of an image there is a red rectangle
4. Re: make text watermark on top of background image
Ayman.. Jun 17, 2013 9:06 AM (in response to abeddie)thank u very much
but i still have 2 problems
1. the text is not transparent
i wrote "0.9 setgray (DRAFT) show restore"
but it show a light gray not transparent
2. when i print the document its print 5 blank docs with DRAFT watermark ?!
thanks
5. Re: make text watermark on top of background image
abeddie Jun 17, 2013 11:21 AM (in response to Ayman..)PostScript used an opaque write so the light gray on top knocked out
what was underneath. The following requires setoverprint and setoverprintmode which may not be supported in a very old printer. Also cmyk colorspace is needed so the is used in place of setgray and setrgbcolor. This
printed page 1 with a cyan rectangle with the text DRAFT in light gray but that
text is still mostly cyan. It is not light gray and white as it did not knock out the
cyan. It also prints page 2 with just a light hray DRAFT and no rectangle. Try
this standalone to seee if setoverprint setoverprintmode works on your printer.
/EndPage
true dup setoverprint setoverprintmode
200 100 moveto
60 rotate
.9 setgray
0 0 0 .1 setcmykcolor
true
>> setpagedevice
1 0 0 0 setcmykcolor
showpage
showpage
6. Re: make text watermark on top of background image
Ayman.. Jun 18, 2013 1:13 AM (in response to abeddie)first of all i want to thank u that u r helping me , for me this PS language is like chinease there is no chance that i can learn it
regarding the last sample that u sent , in ghostview i am still seeing the gray text covering the cyan and when i try to print the file it didnt printed !
if there is not transparent text in PS , can the text be with pattern that doesnt cover the text underneath or can the text be hollow for example ? or if u have any bettter idea to deal with this problem ?
i have a solution but its not practical : i changed the PS to PDF using ps2pdf and i have a code that add the watermark perfectly to the PDF the problem is when converting the PDF back to PS using pdf2ps the file size is very large !!
7. Re: make text watermark on top of background image
abeddie Jun 18, 2013 4:56 AM (in response to Ayman..)This one does the text outline allowing what is underneath to show.
/EndPage
200 100 moveto
60 rotate
.9 setgray
(DRAFT) false charpath
2 setlinewidth
stroke
restore
true
>> setpagedevice
showpage
8. Re: make text watermark on top of background image
Ayman.. Jun 18, 2013 5:42 AM (in response to abeddie)Hi ,
now its looks great and the underneath text is shown
but i still have the printing problem !!
when i print the file without ur code it prints 1 file but when i add urs code it prints 3 or 4 blank pages with DRAFT text ?!
i tried 2 printers and they did the same thing
im printing using the command
/usr/ucb/lpr -P printer_name file_name
9. Re: make text watermark on top of background image
abeddie Jun 18, 2013 6:07 AM (in response to Ayman..)%! new version
/EndPage
pop 0 eq
save initgraphics
200 100 moveto
60 rotate
.9 setgray
2 setlinewidth
stroke
restore
true
false
} ifelse
>> setpagedevice
showpage
10. Re: make text watermark on top of background image
Ayman.. Jun 18, 2013 8:24 AM (in response to abeddie)Hi ,
it seems that its working fine for ur sample , i printed it and its print one page
but the problem is with my files ?!
what could be the problem ?
here is a link to a sample file that when printed its print 3 extra blank pages
https://skydrive.live.com/redir?resid=10C4441C5F41E70E!269&authkey=!AOG2LeB53ZLNuNo
thanks
11. Re: make text watermark on top of background image
abeddie Jun 18, 2013 11:50 AM (in response to Ayman..)There are 2 device dependend level 1 command lines:
0 statusdict /setpapertray get exec
You can comment out both lines and try it. If you need those lines to select media from
a specific tray try moving the new EndPage code to after the second of those lines. Both
methods worked on my printer which gave 4 pages without the change.
12. Re: make text watermark on top of background image
Ayman.. Jun 19, 2013 8:40 AM (in response to abeddie)Hi ,
i tried ur suggestion of commenting out all the lines 0 statusdict /setpapertray get exe
but the problem now is when i have a report with more than one page its only show/print the first page ?!
i tried to put the code in many places after the 0 statusdict /setpapertray get exec but it doesnt work
i have for exmple a file with 5 pages and 5 sections as below ,
%%Page: 1 1
%%BeginPageSetup
%%BeginFeature: *PageSize Letter
%%EndFeature
%%BeginFeature: *InputSlot Upper
%%EndFeature
0 0.000 -3450.000 0 83.333 66.666 1.000 1.000 IP
%%EndPageSetup
initclip
%%PageTrailer
EP
%%Trailer
restore
%%Pages: 5
%%EOF
13. Re: make text watermark on top of background image
abeddie Jun 19, 2013 10:09 AM (in response to Ayman..)%!
% multi page test - add exch from prior version
/EndPage
exch pop 0 eq
save initgraphics
200 100 moveto
60 rotate
.9 setgray
2 setlinewidth
stroke
restore
true
false
} ifelse
>> setpagedevice
showpage
0 1 0 0 setcmykcolor
showpage
0 0 1 0 setcmykcolor
showpage
14. Re: make text watermark on top of background image
Ayman.. Jun 20, 2013 4:26 AM (in response to abeddie)Hi abeddie ,
thank u very much its working now perfectly ur answers were professional and helpful
can u tell me how to change the writing direction of the DRAFT word
coz for landscape file its not in the correct direction
is there a chance to write it from the upper left corner to the lower right corner ?!
15. Re: make text watermark on top of background image
abeddie Jun 20, 2013 6:40 AM (in response to Ayman..)Below is another sample you should be able to modify. It finds out what the page dimensions are
in points 1/72 of an inch and puts them in pw and ph with a currentpagedevice. Then if pagewidth is
greater thanpageheight (pw ph gt) it is landscape and uses a -30 degree rotate. If it is portrait the
60 degree is still used. You can go a step further and calculate angles based on pw and ph instead
of using fixed.
/EndPage
currentpagedevice /PageSize get aload pop /ph exch def /pw exch def
exch pop 0 eq
save initgraphics
pw ph gt
{ % landscape start 3 inches from top left
216 ph 216 sub moveto
-30 rotate
{ % portrait start 3 inches from bottom left
216 216 moveto
60 rotate
} ifelse
.9 setgray
2 setlinewidth
stroke
restore
true
false
} ifelse
>> setpagedevice
72 72 pw 144 sub ph 144 sub rectfill
showpage
showpage
showpage
