4 Replies Latest reply on Jun 18, 2013 9:06 AM by Cooroo
    AS: Export error in CS6, worked in CS5
    Cooroo
      The following script snippet opens an image file, and saves out a thumbnail for use in a database.
      It works fine in Photoshop CS5 but in CS6 it errors on the 'export' command, with the message 'can't get current document'.
      Checking the CS6 dictionary I can't see anything wrong. I've tried 'document 1' etc but have the same problem. Any ideas? It's a crucial script that I use daily, but will soon lose access to CS5...
      tell application "Adobe Photoshop CS6"
      set myExportOptions to {quality:0}
                          set ruler units of settings to pixel units
        open file the_file
                          tell current document
                                    set image_height to the height as pixels
                                    set image_width to the width as pixels
                                    if image_height is greater than image_width then
        resize image height 300
        resize canvas width 300
                                    else
        resize image width 300
        resize canvas height 300
                                    end if
                                    set thumb to thumbs_path & the_filename & ".gif" as string
        export in file (thumb) as save for web with options myExportOptions
                                    close without saving
                          end tell
                end tell
        • 1. Re: AS: Export error in CS6, worked in CS5
          Muppet Mark Level 5
          You are missing a little code…? Where have you defined your variables thumbs_path & the_filename
          As is it don't work in CS5 for me… Sorry but NOT got CS6 to tinker with
          • 2. Re: AS: Export error in CS6, worked in CS5
            Cooroo Level 1
            Yes, it's just a snippet - the other parts of the script take place in FilemakerPro, so I didn't want to confuse the issue by including that.
            thumbs_path is just the path to a folder called 'Thumbnails' on our server, and the_filename is the number of the record in Filemaker.
            I'll post an adapted version that should work as a standalone. But I don't want to complicate the issue - the problem is really with the 'export' line. Everything else works.
            When you get a dialog, choose a single image file, and click cancel when it asks you for another:
            copy {} to doclist
            repeat
                      try
                                choose file with prompt "Choose an image file:"
                                copy doclist & (the result as string) to doclist
                      on error
                                exit repeat
                      end try
            end repeat
            tell me to open (doclist)
            on open image_list
                      set thumbs_path to path to desktop
                      repeat with the_image in image_list
              open file the_image
                                                    else
                                                    end if
                                                    set thumb to thumbs_path & "1.gif" as string
                                          end tell
                                end tell
                      end repeat
            end open
            • 3. Re: AS: Export error in CS6, worked in CS5
              Muppet Mark Level 5
              I may be that it does not like your options…? Have you tried without those…?
              Quality is not one thats available for GIF I would use that when saving in JPEG.
              I would also tell it what format I wanted… {web format:CompuServe GIF}
              • 4. Re: AS: Export error in CS6, worked in CS5
                Cooroo Level 1
                Took out the option and it worked! TBH this was a script I'd lifted from elsewhere and adapted for my needs, and the line was probably never necessary.
                Thanks so much!
