I have developed a course (I'm just using 2 slides to test) where I have Captivate reporting using Scorm 1.2...I use Slide Views and have slide views as 1 slide in order to complete. The system works just fine and reports complete to the Saba LMS but, it shows the cmi.core.exit = suspend, thus it will not move it to the completed area of Saba. I developed a button for the last slide with javascript to try to cover everything where I give 100 points for reporting and use the following JS listed here:
var retval = g_objAPI.LMSSetValue('cmi.core.lesson_status', 'completed');
var retval = g_objAPI.LMSSetValue('cmi.core.exit', 'logout');
var retval = g_objAPI.LMSCommit('');
var retval = g_objAPI.LMSFinish('');
The system registers the completed and logs out, but, doesn't change the cmi.core.exit to logout (keeps suspend). I'm losing my mind trying to figure this out....HELP!
One other thing, when I finish the course in Saba, it closes the Captivate project window, but Saba still has a window open that says Please choose a navigation action......you have to press the X in the top right corner to close the window.....
Does anyone have a button that they've developed with Saba or JS I could place inside the button to get everything to work......or any ideas?
Jerry
I am having this same problem. I have a simple "Finish" button at the end that scores 100. I am losing my mind trying to figure this out. This was never a problem with our LMS until we upgraded to Captivate 9. Did this ever get an answer?
I am having same issue. Has anyone solved it?
This is still an issue in Captivate 10. Did anyone find a solution?
In Quiz Preferences > Advanced, do you have 'Set Exit to Normal after completion' checked?
If not, try that.
Can you use SCORM 2004 instead of 1.2?
We only have Set Exit to Normal when using SCORM 2004. Captivate 8 and lower had that for SCORM 1.2, which is the bulk of what we publish for content. I was hoping there was an alternative option for SCORM 1.2, since that setting is now gone.
We got this to work in SABA LMS (SEC 7.5) using Captivate 2017 by using SCORM 2004 v3 and most important, the "Set exit to normal after completion" is only available in SCORM 2004, so this should trigger the cmi.core.exit to normal.
