5 Replies Latest reply on Oct 15, 2007 4:35 PM by ZakNinja
    accessing variables and functions between loaded external swfs?
    ZakNinja
      Using AS 3.0: Say I have a menu.swf that loads a content.swf below it using the following
      var newContent:Loader = new Loader();
      newContent.load(new URLRequest("fowContent.swf"));
      addChildAt(newContent,0);
      Now say I have a frame label in newContent that is an animation ending the display of that swf. Upon clicking of another menu button in menu.swf, can I access the content's ending sequence by:
      newContent.gotoAndPlay(newContent.endingSequence);
      Also can you use while loops in AS 3.0? I would like to have a boolean variable "ended" in the newContent that becomes true after the ending animation has played.
      while ( newContent.ended != true)
      //wait
      then have it run the function to load and display the new content.swf
        • 1. Re: accessing variables and functions between loaded external swfs?
          use the content property of your loader's contentloaderinfo property to access the main timeline in fowContent.swf. you'll need to cast it as a movieclip or the compiler will complain.
          • 2. Re: accessing variables and functions between loaded external swfs?
            ZakNinja Level 1
            quote:
            that one went a little over my head. I think I get what you're saying in the first part, what does such a statement look like? also how would I cast it as a movieclip?
            • 3. Re: accessing variables and functions between loaded external swfs?
              p.s. you can't use a for-loop and you can't use a while-loop to effect any time delays. they both execute from beginning to end before anything is updated on-stage and no other code can execute outside of those loops (unless called from within the loop).
              • 4. Re: accessing variables and functions between loaded external swfs?
                ZakNinja Level 1
                Thank you very much for the help.
                Would I need to declare a MovieClip variable before using that statement or does that automatically cast newContent as a movieclip and go to the frame?
                So in order to achieve the flow I'm looking for.
                I'll have this in the menu.swf looking for clicks. It will run a function in the content.swf that runs the ending sequence and receives a string variable which is a concatenation of the buttonclicked (which is also the filename of next content) and .swf. (can I cast the event.target.name into a string the same way you casted the other into a movieclip?)
                function buttonClick(event:MouseEvent):void //in the menu.swf
                var nextFile:string = string(event.target.name) + ".swf";
                MovieClip(newContent.contentLoaderInfo.content).endSequence(nextFile)
                fowContent.addEventListener(MouseEvent.CLICK, buttonClick);
                In the content.swf I will have a public variable nextContent and the function that the menu.swf calls, which begins the ending sequence.
                public var nextContent:string;
                function endSequence(nextFile:string)
                nextContent = nextFile;
                gotoAndPlay(endingSequence);
                Then at the end of the movie sequence I could call this function that passes back the variable that was modified by the previous function and runs the loader.
                parent.loadNext(nextContent) //in the content.swf
                function loadNext(nextContent:string) //function in menu.swf
                newContent.load(new URLRequest(nextContent));
                I'm sure theres a better way to do this, and I don't even know if this will work. But I'd like to make sure it makes sense before I try to implement it.
                • 5. Re: accessing variables and functions between loaded external swfs?
                  ZakNinja Level 1
                  I'm sorry my knowledge is about a week old. I bought a hands on training book and I'm just kind of winging it.
