This content has been marked as final.
Show 1 reply
1. Re: CollateralNotFoundException from the DDX
sharoon23 Jun 18, 2013 10:57 PM (in response to amateur85)Hi,
This exception is coming beacuse you have not specified keys in the Input Document Map in Process Properties.
For every distinct value of source attribute (like /Applications/SampleApplication/1.0/form1.pdf or just form1.pdf) you have to enter this value as a key in Document map and also specify a value for it.
Value will be the location of the document that you want to pass.
Like in this case you can change your key value to be form1.pdf and form2.pdf. Enter these as separate keys in Input Document Map. When you enter one key like form1.pdf, then click on the selected key values area for that key and specify from to pick that document.
Please visit the following links for more details
Sufyan
