2 Replies Latest reply on Jun 18, 2013 4:39 PM by elainecc
    Best way to determine if mouse is over menu item and store it in a var
    Marlene
      I have a list of menu items. I want them to change color when the user rolls over any of the six menu items. I want to write a function so it would be
      var = menuTarget;  (this is the item the user is currently mouseovering how do I define this?)
      menuTarget.mouseover(function(){
                $(this).css("color","red");
      menuTarget.mouseout(function(){
                $(this).css("color","green");
        • 1. Re: Best way to determine if mouse is over menu item and store it in a var
          AMULI Level 4
          Hi Marlene,
          Define the functions in your document.compositionReady event handler :
          sym.mouseOverMenu = function( eMenuItem)
              $(eMenuItem.target).css("color", "red");
          Then for each of the six menu item elements, you call the function in the menuItem<i>.mouseover event handler :
          sym.getComposition().getStage().mouseOverMenu( e);
          What you tried to express with var = menuTarget; is in fact captured by the target property (which one of the six) of the event object e that you pass as a parameter to the function.
          Gil
          • 2. Re: Best way to determine if mouse is over menu item and store it in a var
            elainecc Adobe Employee
            Another option is to set the following in each object's mouseenter (or mouseover) handler:
            sym.setVariable("currentSelection", "nameOfMyElement");
            // assuming each button has a Rectangle in it
            sym.getSymbol("myButton").$("Rectangle").css("background-color", "red");
            Or something of that sort... on the mouseout or mouseleave handler:
            sym.getSymbol("myButton").$("Rectangle").css("background-color", "blue");
            sym.setVariable("currentSelection", null);
            Hope that helps,
            -Elaine
