11 Replies Latest reply on Jun 18, 2013 8:28 AM by Test Screen Name
    how to stop PDF from saving
    rufeelelnucky79
      i have a script to check the fields in a document to see if they are filled out or not.
      it returns the fields that are incomplete. the full code is:
      var emptyFields = [];
      for(var i = 0;i<this.numFields;i++)
      {var f = this.getField(this.getNthFieldName(i));
      if(f.type!="button"&&f.required)
      {if((f.type=="text"&&f.value==""))emptyFields.push(f.name);}}
      if(emptyFields.length > 0)
      {app.alert("You Must Fill In The Following Required Fields:\n" + emptyFields.join("\n"));}
      else f.readonly = true;
      now, what i want it to do is, if there are any missing fields, it will stop the document from saving/save as/print.
      and if everything is filled out, it will save/save as/print as a read only document.
      right now, i have this code under "Document will save"
      currently, the alert pops up, but still saves the document anyway.
      on a side note, is it possible to make the red borders on the required fields dissappear?
      any and all help would be appreciated.
      thanks!
