3 Replies Latest reply on Jun 19, 2013 3:48 PM by jbowden
    Why does this code not work on document.compositionReady
    Marlene Level 1
      I have a symbol called printMenu.
      Inside printMenu I have 5 text elements.
      The following code reports I have 0 elements in the printMenuChildren variable when it should be 5. Not sure why.
      var printMenuChildren = sym.getSymbol("printMenu").getChildSymbols();
      alert(printMenuChildren.length);
                for(var i=0; i<printMenuChildren.length; i++) {
                          alert (printMenuChildren[i]);
        • 1. Re: Why does this code not work on document.compositionReady
          Endoplasmic Level 2
          This was a super pain point for me, so I know your fustration.
          The problem is that creationComplete is fired before compositionReady (which is dumb).
          What I ended up doing was making each symbol have an "onInit" method that I called from my main compositionReady call like so:
          //loop through things that need to do things
          var elements = sym.getChildSymbols();
          var total = elements.length;
          var i = 0;
          for(i = 0; i < total; i++){
            if(typeof elements[i].onInit == 'function'){
              elements[i].onInit();
          edit: This was in Edge 1.0 and 1.5, this may have been fixed in CC
          • 2. Re: Why does this code not work on document.compositionReady
            jbowden Adobe Employee
            Hi Marlene,
            Your code actually works for me when I try it in the composiitionReady event.
            Are you certain that your printMenu symbol actually contains 5 symbol instances?
            hth,
            Joe
            • 3. Re: Why does this code not work on document.compositionReady
              Oh wait - after rereading your post, you did mention there were five text elements in the symbol. I'm afraid getChildSymbols won't work for that - it only gets the symbol instances within a symbol.
              Instead, use jQuery's children() method to get the child elements of the div (symbol instance). Like so:
              var printMenuChildren = sym.$("printMenu").children();
              And it will work just fine in the compositionReady handler.
              hth,
              Joe
