1 2 3 4 Previous Next 136 Replies Latest reply on Sep 23, 2015 7:07 AM by kleaferreira Go to original post Branched to a new discussion.
      • 80. Re: InDesign CC crashes - Lauch/Text tool
        tugfoot88
        Help I am having the same problem!
        I have just bought the Indesign CC & need it urgently. Everytime I click on it it just shows the splash page & then as it is about to load it crashes.
        I have deleted all my downloaded fonts, but kept my windows fonts.
        I have also done this but for some reason the CopyPLugins won't open on my computer?
        Help me please!!!
        Mac OS:
        1. Download CopyPlugins_Mac.zip
        2. Extract the contents of the zip to a folder
        3. Launch the app
        4. Select the “Adobe InDesign CC.app” or “Adobe InCopy CC.app” in the dialog that comes up
        Note: If there is a security warning, go to System Preferences > Security & Privacy > General. Under 'Allow applications downloaded from:' change the option to “Anywhere.”
        *For security purposes, please changed back the setting after the plug-in has been updated.
        • 81. Re: InDesign CC crashes - Lauch/Text tool
          cynglas Level 1
          Presumably if you have bought InDesign CC you are signed up for a Creative Cloud account. If you need to get something done urgently, download CS6 from the Cloud download menu (see a few posts above for how to do that). It works fine. Then you can sort out CC at your/Adobe's leisure.
          • 82. Re: InDesign CC crashes - Lauch/Text tool
            sdcsusanne
            I updated from CS6 to CC without any problems - being still one of 'those' who use a separate font manager program, which I still highly recomend.
            My only problem was with one of our Editors in our InCopy/InDesign workflow: every time she updated an assignment file InDesign would crash on my side when I tried to update. After cleaning up her font folder(s) the problem disapeared and I can update assignments now without problems.
            Hope this helps someone in publishing workflows!
            • 83. Re: InDesign CC does not work properly - Text tool
              PabloRovalo
              Just upgraded and still: Open Indesign CC - new document - command-T - Crash!
              here is the log http://pastebin.com/qcGTy0mZ
              BR
              - P
              • 85. Re: InDesign CC does not work properly - Text tool
                Jonathan Pickett
                Well I found a work around all I did is save my work as a .idml and reinstalled InDesign CS6 from the Creative Cloud. Opened the file in the CS6 version and was able to make changes to the text feild and table cell without it crashing. I guess until this issue is resolved in the CC version I'll be using CS6 for awhile.
                • 86. Re: InDesign CC crashes - Lauch/Text tool
                  grabart1
                  AMXYZ please can you specify, for windows users, exactly how to identify the correct file to upload to fix into please.
                  I'm trying to follow the fix but keep getting an error saying error add to file "IndesignCC64bit", and I find the file, select it,  but the error comes back. I realise I am probably looking at the wrong file, but there is only one indesign program file to see....
                  • 87. Re: InDesign CC crashes - Lauch/Text tool
                    Are you running 32-bit or 64-bit Windows 7?
                    On 64-bit systems you should find ID CC installations in both Program Files and Program Files (x86). The first one is the 64-bit version and the second is the 32-bit version. On a 32-bit Windows system there is only a Program Files folder, and you will have only the 32-bit version of ID (and only need the 32-bit patch).
                    • 88. Re: InDesign CC crashes - Lauch/Text tool
                      grabart1 Level 1
                      Untitled.pngthanks Peter, as you can see on the left, the pop up window comes up after launching 'CopyPlugins.vbs script' as per the instructions, but there is no way to browse for 'programme files', the window just takes me directly to 'programme files (86)' and there is only one IDCCfile to chose from. I think this must be that the temporary fix is not designed for 64bit windows. I have a technician from Adobe working on this and will post here for others in the same boat, if any solution arises, meantime I think the idea to go back to CS6 for a while is the quickest solution.
                      • 89. Re: InDesign CC crashes - Lauch/Text tool
                        grabart1 Level 1
                        additional instructions for fix for Windows 64 bit users.
                        * make sure, when you download the fix from
                          http://helpx.adobe.com/indesign/kb/indesign-cc-crashing-launch.html
                           that you extract the folder from a zip file to another location FIRST before trying to use the fix.
                        My mistake was leaving it in the zip folder and trying to run it from there, it wasn't detecting the correct programme files to run the fix. Hope this helps someone else!
                        • 90. Re: InDesign CC does not work properly - Text tool
                          Robert at Dig Level 1
                          I wish everyone would stop wingeing!
                          On a PC, copy all of your unhidden fonts to a folder on your desktop and delete them from your Fonts folder. Then just put them back in a letter at a time, each time opening CC to test. It doesn't take long, probably less time than it takes to moan.
                          • 91. Re: InDesign CC does not work properly - Text tool
                            cynglas Level 1
                            Well that's a workaround in the first instance, but it means that certain fonts are out of use, which can be a show stopper for revisting projects or ongoing work for some clients. Adobe's temporary patch is essential for many of us.
                            • 92. Re: InDesign CC does not work properly - Text tool
                              Out of 2994 fonts I found 1 conflict, and that was a font I had never even used or heard of. Try it, you never know it might fix the problem and you can get on with using the program. I'm not sure Adobe are going to fix it any time soon.
                              • 93. Re: InDesign CC does not work properly - Text tool
                                cynglas Level 1
                                OK, true for some not for others ( I had mission critical Chinese fonts that didn't work), but Adobe have issued a fix that does work. It's just that it needs manually applying that some people seem to be struggling with. I agree that a fully integrated bug fix may have to wait some time. It still isn't great that this happened - font handling is fairly fundamental to what ID is about.
                                • 94. Re: InDesign CC does not work properly - Text tool
                                  Having said all this, I'm only using InDesign because I have to for two jobs in. I'm a Quarkman and there still is no comparisson from a handling point of view! Mind you Quark still crashes occasionally and you have to keep on top of fonts in the same way.
                                  • 95. Re: InDesign CC does not work properly - Text tool
                                    cynglas Level 1
                                    I began with Quark years ago (didn't we all?), but the intercompatibility of the Adobe Suite won us over. Actually previous verions of ID have not had a problem with font handling, so having to nursemaid CC has come as an unwelcome intrusion.
                                    • 96. Re: InDesign CC crashes - Lauch/Text tool
                                      mazinaus
                                      ID CC crashing on start up. Cannot open my files in CS6. I have an urgent deadline today. Attached is a copy of the crash report
                                      Process:          Adobe InDesign CC [1837]
                                      Path:          /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/Adobe InDesign CC
                                      Identifier:          com.adobe.InDesign Version:          9.0.0.244 (9000)
                                      Code Type:          X86-64 (Native) Parent Process: launchd [194] User ID:                    501
                                      Date/Time:          2013-08-14 13:22:55.734 +1000 OS Version:          Mac OS X 10.8.4 (12E55)
                                      Report Version: 10
                                      Interval Since Last Report:          89817 sec Crashes Since Last Report:                    27
                                      Per-App Interval Since Last Report: 58312 sec Per-App Crashes Since Last Report:  6
                                      Anonymous UUID:          57CC21C3-2F59-1EBB-CB88-B10A49BBE13B
                                      Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_CRASH (SIGSEGV)
                                      Exception Codes: 0x0000000000000000, 0x0000000000000000
                                      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                                      0  libsystem_kernel.dylib          0x00007fff8e622d46    kill + 10
                                      1  PublicLib.dylib          0x0000000101108e84  ProtectiveShutdown::~ProtectiveShutdown()  + 276
                                      2  ObjectModelLib.dylib          0x0000000104aeb1e8 0x104ab4000 + 225768
                                      3  ObjectModelLib.dylib          0x0000000104ae71f4 0x104ab4000 + 209396
                                      4  ObjectModelLib.dylib          0x0000000104ad4827 0x104ab4000 + 133159
                                      5  ObjectModelLib.dylib          0x0000000104ad3b1b 0x104ab4000 + 129819
                                      6  ObjectModelLib.dylib          0x0000000104ae62fc 0x104ab4000 + 205564
                                      1. ObjectModelLib.dylib          0x0000000104ae168c ShuksanInit(IStartupScreen* (*)(), IPlugIn*) + 6956
                                      2. com.adobe.InDesign          0x0000000100001c7e main + 94
                                      3. com.adobe.InDesign          0x0000000100001bb4 start + 52 Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                                      Thread 2:
                                      0
                                      0x00007fff8e6230fa    psynch_cvwait + 10
                                      1
                                      libsystem_c.dylib
                                      0x00007fff95544023 _pthread_cond_wait + 927
                                      1. com.apple.CoreServices.CarbonCore 0x00007fff8d5bb406 TSWaitOnConditionTimedRelative +
                                      163
                                      1. com.apple.CoreServices.CarbonCore 0x00007fff8d51da98 MPWaitOnQueue + 252
                                      4  PMRuntime.dylib          0x000000010165ebe1 0x10165d000 + 7137
                                      1. com.apple.CoreServices.CarbonCore 0x00007fff8d5927e0 PrivateMPEntryPoint + 58
                                      2. libsystem_c.dylib          0x00007fff9553f7a2 _pthread_start + 327
                                      3. libsystem_c.dylib          0x00007fff9552c1e1 thread_start + 13
                                      Thread 3:
                                      0
                                      0x00007fff8e6236d6    workq_kernreturn + 10
                                      1
                                      libsystem_c.dylib
                                      0x00007fff95541f4c _pthread_workq_return + 25
                                      2
                                      libsystem_c.dylib
                                      0x00007fff95541d13 _pthread_wqthread + 412
                                      3
                                      libsystem_c.dylib
                                      0x00007fff9552c1d1 start_wqthread + 13
                                      Thread 4:
                                      0
                                      1
                                      libsystem_c.dylib
                                      2
                                      libsystem_c.dylib
                                      3
                                      libsystem_c.dylib
                                      Thread 5:
                                      0
                                      1
                                      libsystem_c.dylib
                                      2
                                      libsystem_c.dylib
                                      3
                                      libsystem_c.dylib
                                      Thread 6:
                                      0
                                      0x00007fff8e621686 mach_msg_trap + 10
                                      1
                                      0x00007fff8e620c42 mach_msg + 70
                                      2  com.apple.CoreServices.CarbonCore  0x00007fff8d5b83dd TS_exception_listener_thread + 67
                                      3
                                      libsystem_c.dylib
                                      4
                                      libsystem_c.dylib
                                      Thread 0 crashed with X86 Thread State (64-bit):
                                      rax: 0x0000000000000000 rbx: 0x000000010a470040 rcx: 0x00007fff5fbfec58 rdx: 0x0000000000000000
                                      rdi: 0x000000000000072d rsi: 0x000000000000000b rbp: 0x00007fff5fbfed00 rsp: 0x00007fff5fbfec58
                                      r8: 0x000000010a4708f0  r9: 0x0000000003cfaa65 r10: 0x00000000004ec280 r11: 0x0000000000000206
                                      r12: 0x0000000109052040 r13: 0x000000010a551e20 r14: 0x00007fff5fbfed60 r15: 0x0000000000000000
                                      rip: 0x00007fff8e622d46 rfl: 0x0000000000000206 cr2: 0x000000011a0c9018
                                      Logical CPU: 0
                                      Binary Images:
                                      0x100000000 -          0x100005fff +com.adobe.InDesign (9.0.0.244 - 9000) <2F683D4B-
                                      A144-3E91-A0CA-3F9B6B1DA676> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/ Contents/MacOS/Adobe InDesign CC
                                      0x10000c000 -          0x10000eff7 +com.adobe.InDesign.InDesignModelAndUI (9.0 - 0)
                                      <7EAF82B5-D2A0-3E46-96B1-61E4A9D819C9>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
                                      0x100014000 -          0x10001cfff  +com.adobe.coretech.adobesplashkit  (AdobeSplashKit  Version
                                      1.0 - 1.0) <65BFDA83-4121-3D12-9BBE-9F4FF1DB3D6A> /Applications/Adobe InDesign CC/Adobe InDesign     CC.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
                                      0x100025000 -          0x10002ffff  +ASLSupportLib.dylib  (1)  <37C5A821-5118-3BCF-AC5E-
                                      F9C4FAE123A8> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ ASLSupportLib.dylib
                                      0x100037000 -          0x10012bff7 +DV_WidgetBinLib.dylib (1) <6A40E798-D47A-3959-
                                      A04E-9361B010FAE3> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ DV_WidgetBinLib.dylib
                                      0x1001bf000 -          0x100204ff7  +TextPanelLib.dylib  (1)  <F06B61DF-F7D5-37AA-B1F5-
                                      BB5FA3737E62> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ TextPanelLib.dylib
                                      0x100221000 -          0x100382fff +WidgetBinLib.dylib (1) <7D51BAC1-7061-36C1-8C0E-
                                      CBF411371A56> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ WidgetBinLib.dylib
                                      0x100433000 -          0x1005fcff7 +com.adobe.owl (AdobeOwl version 5.0.13 - 5.0.13)
                                      <E9BEFE93-8AB5-3EF9-B59E-69208015C7FA>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                                      0x10063f000 -          0x100883ff7 +com.adobe.dvacore.framework (7.0.849323 - 7.0.849323.0)
                                      <63BF29D6-62ED-3026-B93D-96CC42F4CF9E>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                                      0x10094a000 -          0x100dd7ff7 +com.adobe.dvaui.framework (7.0.849323 - 7.0.849323.0)
                                      <6C4C227F-A5D6-3B4D-AD39-4B3C97D32440>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                                      0x10106d000 - 0x10106dfff +com.adobe.InDesign.InDesignModel (9.0 - 0) <5A3F239E- E40A-3876-8DD9-0E5AEDB58098> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/ Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
                                      0x101072000 -          0x101080fff +com.adobe.boost_threads.framework (7.0.847203 - 7.0.847203.0)  <A0AE19A9-2B8E-310A-8AC1-0E2E026E7A40>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads 0x101096000 -          0x10109cff7  +com.adobe.boost_date_time.framework  (7.0.847203  -
                                      7.0.847203.0)  <F30F59C3-41C0-3DB1-899A-E2491EA25263>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/ boost_date_time
                                      0x1010ab000 -          0x101513fff +PublicLib.dylib (1) <9C2969EC-46E7-3AC9-
                                      ADDE-45951D87A220> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ PublicLib.dylib
                                      0x10165d000 -          0x101667fff +PMRuntime.dylib (1) <E2DF4211-4A31-32BB-87F5-
                                      F0ADFFBFACE8> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ PMRuntime.dylib
                                      0x101670000 -          0x101687ff7 +com.adobe.AFL (AdobeAFL 1.5.0 - 1.5)
                                      <1C46F2BE-2E4D-3E25-ACDF-85E2962B92DF>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
                                      0x101696000 -          0x1019a6ff7 +com.adobe.CoolType (AdobeCoolType 5.13.00.30830 - 5.13.00.30830)  <BBF1FCF6-523A-3E24-967A-10EA909DF89B>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/ AdobeCoolType
                                      0x1019ee000 -          0x101a0bfff +com.adobe.BIB (AdobeBIB 1.2.03.30830 - 1.2.03.30830)
                                      <A69D3AA0-9248-3B77-991B-89B2B7FE46BB>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                      0x101a13000 -          0x101b57fff +com.adobe.ACE (AdobeACE 2.20.02.30830 - 2.20.02.30830)
                                      <73C9699B-5EDC-3FDC-82FF-738C99AA840F>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                      0x101b6a000 -          0x10213bfff +com.adobe.AGM (AdobeAGM 4.30.19.30830 - 4.30.19.30830)
                                      <9062D763-4040-3F8C-8FF3-23876F112FB8>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                      0x1021d8000 -          0x102215fff +com.adobe.ARE (AdobeARE 1.5.02.30830 - 1.5.02.30830)
                                      <73174C59-1DDC-3416-A0AD-4D70930ABA60>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                                      0x10221d000 -          0x102243fff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01)
                                      <FA20BCA0-05BF-35ED-95B7-5775B8310D12>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                                      0x10224b000 -          0x1027e4fff +com.adobe.MPS (AdobeMPS 5.8.1.30604 - 5.8.1.30604)
                                      <70CBC6A8-2740-37AB-964E-484096A1BF8A>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                                      0x102861000 -          0x10287eff7 +com.adobe.dvaflashview.framework (7.0.849323 - 7.0.849323.0)  <727F09EC-0D75-3C41-8553-54585B9408BB>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview 0x102895000 -          0x102899ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366)
                                      <B9447EE8-6F91-9E85-C163-96600BF70764>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                                      0x1028a0000 -          0x102962fff +com.adobe.exo.framework (7.0.849323 - 7.0.849323.0)
                                      <60261EFB-3EF3-3201-9BE7-3CC7235B523B>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/exo.framework/Versions/A/exo
                                      0x1029ff000 -          0x102aadfff +com.adobe.dvaworkspace.framework (7.0.849323 - 7.0.849323.0)  <412D9508-51FD-34D9-8B3E-FE9BD1EAC107>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace 0x102b30000 -          0x1031adfcf +com.adobe.PlugPlug (4.0.0.172 - 4.0.0.172) <1B15941F-
                                      D885-3AC5-880F-D513DA868B00> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/ Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                                      0x103494000 -          0x1034c0ff7 +libtbb.dylib (0) <64B7013E-D548-3F7B-
                                      A2FB-28B7B932275C> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/
                                      Frameworks/libtbb.dylib
                                      0x1034db000 -          0x1034fafe7  +libtbbmalloc.dylib  (0)  <6887ED68-67ED-3748-82DA- B39A3EB210BB> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ libtbbmalloc.dylib
                                      0x10351f000 -          0x104264fff +com.adobe.ICUData (4.0 - 3.61)
                                      <01D90725-4B10-312C-9546-9C0CCCA1B7BB>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
                                      0x104278000 -          0x1043a9ff7 +com.adobe.ICUInternationalization (4.0 - 3.61)
                                      <CD4AD967-00CD-3979-8F82-1166E2058FA6>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/libicui18n.40.0 .dylib
                                      0x1043fd000 -          0x1044f3ff7 +com.adobe.ICUUnicode (4.0 - 3.61)
                                      <2352E6C8-3431-3A99-92B9-382E85A018AC>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
                                      0x10452b000 -          0x104659fff +com.winsoft.wrservices (WRServices 7.0.0 - 7.0.0)
                                      <0853A41B-A14A-37B7-B27F-457F87865EAD>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                                      0x1046b4000 -          0x1047a3fff +com.adobe.amtlib (7.0.0.169 - 7.0.0.169) <A9A9F814-
                                      FF1F-3182-992C-395E5BC52481> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/ Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                                      0x1047b6000 -          0x1047b8fff +com.adobe.AdobeCrashReporter (7.0 - 7.0.1)
                                      <B68D0D42-8DEB-3F22-BD17-981AC060E9D7>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                                      0x1047be000 -          0x104875ff7 +com.adobe.boost_regex.framework (7.0.847203 - 7.0.847203.0)  <F1C659D9-D3E8-3ACE-8368-9161529A6A66>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex 0x1048df000 -          0x10494eff7 +com.adobe.adobe_caps (adobe_caps 7.0.0.21 - 7.0.0.21)
                                      <CE3C6356-9EE2-3B88-8261-8612A0743F56>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                                      0x104959000 -          0x104964fff +com.adobe.boost_signals.framework (7.0.847203 - 7.0.847203.0)  <E0B3BB47-4294-3D65-8979-29B2D6C5DD2E>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals 0x104973000 -          0x104977fff +com.adobe.boost_system.framework (7.0.847203 -
                                      7.0.847203.0)  <70F73B9F-8416-37BF-9294-086AE475B743>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system 0x10497d000 -          0x104a1efff +com.adobe.ICUConverter (4.0 - 3.61) <46764474-111C-3B13-
                                      AF62-002B71877405> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/ Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
                                      0x104a3e000 -          0x104aa0ff7 +DataBaseLib.dylib (1)
                                      <F2D6864D-0813-3833-96A5-9D256A00375D>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/DataBaseLib.dylib
                                      0x104ab4000 -          0x104b20fff +ObjectModelLib.dylib (1) <FDA08F73-D9C2-303E-
                                      AB18-564E50554517> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/MacOS/ ObjectModelLib.dylib
                                      0x104b3d000 -          0x104b61fff  +com.adobe.AXE8SharedExpat  (AdobeAXE8SharedExpat 3.8.0.30807  -  3.8.0.30807)  <16FF5E16-19E0-3CE1-A68E-27567234429F>  /Applications/Adobe
                                      InDesign  CC/Adobe  InDesign  CC.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/ Versions/A/AdobeAXE8SharedExpat
                                      0x10892f000 -          0x108930ff7 +com.adobe.InDesign.Metadata Database Filter (9.0.0.244 - 0)
                                      <B6CEE02B-979B-385E-A393-FF3D08525330>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Metadata  Database  Filter.InDesignPlugin/Metadata  Database Filter
                                      0x108935000 -          0x10894fff7 +com.adobe.InDesign.IME (9.0.0.244 - 0)
                                      <3A6C88D6-84BF-3A12-992B-ABBE1C4F5EBB>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
                                      0x108ec5000 -          0x108f03fff    +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 7.0.1.102 - 7.0.1.102) <75ADE364-1107-3DA7-84A2-26C6874EB881> /
                                      Applications/Adobe InDesign CC/Adobe InDesign CC.app/Contents/Frameworks/ UpdaterNotifications.framework/Versions/A/UpdaterNotifications
                                      0x108ff5000 -          0x108ff8fff +com.adobe.InDesign.Global Preferences Panel (9.0.0.244 - 0)
                                      <41190407-7FB7-3A06-BE40-5A815559E124>  /Applications/Adobe  InDesign  CC/Adobe  InDesign
                                      CC.app/Contents/MacOS/Required/Global  Preferences  Panel.InDesignPlugin/Global  Preferences Panel
                                      0x10988c000 -          0x1098ddfff +com.adobe.InDesign.Linguistics (9.0.0.244 - 0) <DF732142- A8C5-3AC1-905F-819D82E36525> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/ Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
                                      0x10a057000 -          0x10a0bcfff +com.adobe.InDesign.Text Panel (9.0.0.244 - 0) <D85A6FE1- E185-3B5B-A5FE-6512189E9AC5> /Applications/Adobe InDesign CC/*/Text Panel
                                      0x10a840000 -          0x10aa04fff +com.adobe.InDesign.AppFramework (9.0.0.244 - 0)
                                      <80012E50-E7D9-31B8-8E64-F9A7FF3D65DD>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
                                      0x10b25b000 -          0x10b3e2ff7 +com.adobe.InDesign.SettingsInCloud (9.0.0.244 - 0)
                                      <2E718598-B183-3EB6-88BF-516A57533D99>  /Applications/Adobe  InDesign  CC/*/SettingsInCloud 0x10b838000 -          0x10b884ff7 +com.adobe.InDesign.Spelling Panel (9.0.0.244 - 0)
                                      <5003DC67-9AE6-3261-8577-D91DA1DF1455>  /Applications/Adobe  InDesign  CC/*/Spelling  Panel 0x10b89e000 -          0x10b8cbfff +com.adobe.InDesign.Utilities (9.0.0.244 - 0)
                                      <CC5A6B18-66A1-366D-AFBB-436154AA8468>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
                                      0x10ba00000 -          0x10bbbeff7 +com.adobe.InDesign.Text Walker (9.0.0.244 - 0)
                                      <C6F0355F-1526-3CF9-AC1C-934D73987067>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Text  Walker.InDesignPlugin/Text  Walker
                                      0x10bc16000 -          0x10be79fff +com.adobe.InDesign.Package and Preflight (9.0.0.244 - 0)
                                      <056ABF0A-3875-30B9-8D40-0491E8E75708>  /Applications/Adobe  InDesign  CC/*/Package  and Preflight
                                      0x10bebf000 -          0x10bf2cfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.5 -c 14 - 79.151481)  <BCDB9366-EDB3-3FEA-854D-3D2C72D48781>  /Applications/Adobe  InDesign  CC/ Adobe   InDesign   CC.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                                      0x10bf37000 -          0x10c009fff +com.adobe.InDesign.Text Editor (9.0.0.244 - 0) <9729FF78- BBAA-3E08-863C-AA8302451331> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/ Contents/MacOS/Required/Text  Editor.InDesignPlugin/Text  Editor
                                      0x10c038000 -          0x10c243fff +com.adobe.InDesign.Layout UI (9.0.0.244 - 0)
                                      <D4273B5E-641B-356A-BB4C-792F32ECB7C3>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Layout  UI.InDesignPlugin/Layout  UI
                                      0x10c2a2000 -          0x10c312fff +com.adobe.InDesign.Import Export UI (9.0.0.244 - 0)
                                      <1B080B9A-59BC-32B4-A311-BC30CB9246D7>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
                                      0x10c339000 -          0x10c442ff7 +com.adobe.InDesign.Hyperlinks (9.0.0.244 - 0)
                                      <0C445B20-2A85-33E0-BD59-68D34BE61917>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
                                      0x10c46d000 -          0x10c511fff +com.adobe.InDesign.Master Page (9.0.0.244 - 0)
                                      <05781E24-8DB4-3A6A-AE44-9B0026D41F52>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Master  Page.InDesignPlugin/Master  Page
                                      0x10c52b000 -          0x10c628fff +com.adobe.InDesign.Color Management (9.0.0.244 - 0)
                                      <4FAB3398-0B48-3B98-A21D-BC213733F5E5>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Color   Management.InDesignPlugin/Color   Management
                                      0x10c655000 -          0x10c864fff +com.adobe.InDesign.Application UI (9.0.0.244 - 0) <33F8AB75- D5D6-3A7E-ACD2-16515C049877> /Applications/Adobe InDesign CC/Adobe InDesign CC.app/ Contents/MacOS/Required/Application  UI.InDesignPlugin/Application  UI
                                      0x10c8fa000 -          0x10cc18fff +com.adobe.dvaadameve.framework (7.0.849323 - 7.0.849323.0)  <D4BF8D91-C86E-3E9E-9551-99E55C9C06ED>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve 0x10ceee000 -          0x10cf3dfff  +com.adobe.headlights.LogSessionFramework  (2.1.2.1756)
                                      <BD518257-970F-344A-92B8-B8BE1A8EB4D8>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                                      0x10cf63000 -          0x10d021ff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.5 - 4.5.5.30772)  <4FC0039A-A770-3A51-9D7A-D24167344540>  /Applications/Adobe  InDesign  CC/ Adobe   InDesign   CC.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/ AdobeExtendScript
                                      0x10d049000 -          0x10d0f4ff7 +com.adobe.AdobeScCore (ScCore 4.5.5 - 4.5.5.30772)
                                      <5DE0B54D-CDAE-3146-904F-72CBC5C89FA7>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                                      0x10d11e000 -          0x10d268fff +com.adobe.dvascriptui.framework (7.0.6 - 7.0.6.0)
                                      <906D3438-0978-35E9-B772-BB99D2A87446>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
                                      0x10d382000 -          0x10d394fff +com.adobe.boost_filesystem.framework (7.0.847203 - 7.0.847203.0)  <B0F56E9F-BAAB-34C5-93C4-C713203AB0DF>  /Applications/Adobe  InDesign  CC/
                                      Adobe   InDesign   CC.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/ boost_filesystem
                                      0x10d3a5000 -          0x10d580fff +com.adobe.InDesign.Document Framework (9.0.0.244 - 0)
                                      <A1F4B954-3E60-3EA3-AE62-AF8B305154D1>  /Applications/Adobe  InDesign  CC/Adobe  InDesign CC.app/Contents/MacOS/Required/Document   Framework.InDesignPlugin/Document   Framework
                                      0x7fff6352a000 -          0x7fff6355e93f dyld (210.2.3) <36CAA36E-72BC-3E48-96D9-
                                      B96A2DF77730>  /usr/lib/dyld
                                      0x7fff8a363000 -          0x7fff8a382ff7 libresolv.9.dylib (51) <0882DC2D-A892-31FF- AD8C-0BB518C48B23>   /usr/lib/libresolv.9.dylib
                                      0x7fff8a5f9000 -          0x7fff8a606fff libbz2.1.0.dylib (29) <CE9785E8-B535-3504- B392-82F0064D9AF2>   /usr/lib/libbz2.1.0.dylib
                                      0x7fff8a607000 -          0x7fff8a6c4ff7 com.apple.ColorSync (4.8.0 - 4.8.0) <6CE333AE-
                                      EDDB-3768-9598-9DB38041DC55>     /System/Library/Frameworks/ApplicationServices.framework/ Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
                                      0x7fff8a6c5000 -          0x7fff8a6c5fff com.apple.ApplicationServices (45 - 45) <A3ABF20B- ED3A-32B5-830E-B37831A45A80>     /System/Library/Frameworks/ApplicationServices.framework/ Versions/A/ApplicationServices
                                      0x7fff8a70d000 -          0x7fff8a70efff liblangid.dylib (116) <864C409D-D56B-383E-9B44- A435A47F2346>  /usr/lib/liblangid.dylib
                                      0x7fff8a70f000 -          0x7fff8a8bdfff com.apple.QuartzCore (1.8 - 304.3)
                                      <F450F2DE-2F24-3557-98B6-310E05DAC17F>    /System/Library/Frameworks/ QuartzCore.framework/Versions/A/QuartzCore
                                      0x7fff8a947000 -          0x7fff8aa44fff libsqlite3.dylib (138.1) <ADE9CB98-D77D-300C- A32A-556B7440769F>   /usr/lib/libsqlite3.dylib
                                      0x7fff8aa45000 -          0x7fff8aa46ff7 libSystem.B.dylib (169.3) <9089D72D- E714-31E1-80C8-698A8E8B05AD>   /usr/lib/libSystem.B.dylib
                                      0x7fff8aa82000 -          0x7fff8aaaeff7 libRIP.A.dylib (332) <D26BC320-B415-3C4D-B57F- D525FC361BB2>     /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                                      0x7fff8aad7000 -          0x7fff8aad7fff com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <B5A18EE8- DF81-38DD-ACAF-7076B2A26225>     /System/Library/Frameworks/Accelerate.framework/Versions/A/ Frameworks/vecLib.framework/Versions/A/vecLib
                                      0x7fff8aad8000 -          0x7fff8aaedff7 libdispatch.dylib (228.23) <D26996BF-FC57-39EB-8829- F63585561E09>   /usr/lib/system/libdispatch.dylib
                                      0x7fff8b2d4000 -          0x7fff8b46ffef com.apple.vImage (6.0 - 6.0)
                                      <FAE13169-295A-33A5-8E6B-7C2CC1407FA7>     /System/Library/Frameworks/Accelerate.framework/ Versions/A/Frameworks/vImage.framework/Versions/A/vImage
                                      0x7fff8b470000 -          0x7fff8b4b4fff libcups.2.dylib (327.6) <9C01D012-6F4C-3B69- B614-1B408B0ED4E3>   /usr/lib/libcups.2.dylib
                                      0x7fff8b50c000 -          0x7fff8b512ff7 libunwind.dylib (35.1) <21703D36-2DAB-3D8B-8442- EAAB23C060D3>   /usr/lib/system/libunwind.dylib
                                      0x7fff8b513000 -          0x7fff8b610ff7 libxml2.2.dylib (22.3) <47B09CB2- C636-3024-8B55-6040F7829B4C>   /usr/lib/libxml2.2.dylib
                                      0x7fff8b611000 -          0x7fff8b65dff7 libauto.dylib (185.4) <AD5A4CE7- CB53-313C-9FAE-673303CC2D35>   /usr/lib/libauto.dylib
                                      0x7fff8b65e000 -          0x7fff8b77efff com.apple.desktopservices (1.7.4 - 1.7.4)
                                      <ED3DA8C0-160F-3CDC-B537-BF2E766AB7C1>     /System/Library/PrivateFrameworks/ DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
                                      0x7fff8b77f000 -          0x7fff8b79cff7 com.apple.openscripting (1.3.6 - 148.3)
                                      <C008F56A-1E01-3D4C-A9AF-97799D0FAE69>     /System/Library/Frameworks/Carbon.framework/ Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
                                      0x7fff8ba62000 -          0x7fff8bb00ff7 com.apple.ink.framework (10.8.2 - 150)
                                      <84B9825C-3822-375F-BE58-A753444FBDE2>     /System/Library/Frameworks/Carbon.framework/ Versions/A/Frameworks/Ink.framework/Versions/A/Ink
                                      0x7fff8bb01000 -          0x7fff8bb0fff7 libsystem_network.dylib (77.10) <0D99F24E-56FE-380F-
                                      B81B-4A4C630EE587>    /usr/lib/system/libsystem_network.dylib
                                      0x7fff8bb1a000 -          0x7fff8bb1afff com.apple.Accelerate (1.8 - Accelerate 1.8)
                                      <6AD48543-0864-3D40-80CE-01F184F24B45>     /System/Library/Frameworks/Accelerate.framework/ Versions/A/Accelerate
                                      0x7fff8bb48000 -                    0x7fff8bb72ff7 com.apple.CoreVideo (1.8 - 99.4) <E5082966-6D81-3973- A05A-38AA5B85F886>     /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff8bef7000 -          0x7fff8bef8ff7 libsystem_sandbox.dylib (220.3) <B739DA63-B675-387A-
                                      AD84-412A651143C0>    /usr/lib/system/libsystem_sandbox.dylib
                                      0x7fff8befb000 -          0x7fff8bf69ff7 com.apple.framework.IOKit (2.0.1 - 755.24.1)
                                      <04BFB138-8AF4-310A-8E8C-045D8A239654>     /System/Library/Frameworks/IOKit.framework/ Versions/A/IOKit
                                      0x7fff8bfc2000 -          0x7fff8c044ff7 com.apple.Heimdal (3.0 - 2.0) <C94B0C6C-1320-35A1-8143- FE252E7B2A08>     /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                      0x7fff8c045000 -          0x7fff8c052fff com.apple.AppleFSCompression (49 - 1.0)
                                      <5508344A-2A7E-3122-9562-6F363910A80E>     /System/Library/PrivateFrameworks/ AppleFSCompression.framework/Versions/A/AppleFSCompression
                                      0x7fff8c07b000 -          0x7fff8c0fbff7 com.apple.ApplicationServices.ATS (332 - 341.1) <BD83B039- AB25-3E3E-9975-A67DAE66988B>     /System/Library/Frameworks/ApplicationServices.framework/ Versions/A/Frameworks/ATS.framework/Versions/A/ATS
                                      0x7fff8c0fc000 -          0x7fff8c13bff7 com.apple.QD (3.42.1 - 285.1) <77A20C25-EBB5-341C- A05C-5D458B97AD5C>     /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ Frameworks/QD.framework/Versions/A/QD
                                      0x7fff8c13c000 -          0x7fff8c23efff libcrypto.0.9.8.dylib (47.1) <72AA650B-0453-3BB4- BA03-824627BB199C>   /usr/lib/libcrypto.0.9.8.dylib
                                      0x7fff8c793000 -          0x7fff8c7a6ff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2F2694E9-
                                      A7BC-33C7-B4CF-8EC907DF0FEB>     /System/Library/Frameworks/ApplicationServices.framework/ Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
                                      0x7fff8c7b1000 -          0x7fff8c7b6fff libcompiler_rt.dylib (30) <08F8731D-5961-39F1- AD00-4590321D24A9>   /usr/lib/system/libcompiler_rt.dylib
                                      0x7fff8c84c000 -          0x7fff8c857fff libsystem_notify.dylib (98.5) <C49275CC-835A-3207- AFBA-8C01374927B6>   /usr/lib/system/libsystem_notify.dylib
                                      0x7fff8cab9000 -          0x7fff8cb21fff libvDSP.dylib (380.6)
                                      <CD4C5EEB-9E63-30C4-8103-7A5EAEA0BE60>    /System/Library/Frameworks/ Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
                                      0x7fff8cc0c000 -          0x7fff8cc6fff7 com.apple.audio.CoreAudio (4.1.1 - 4.1.1)
                                      <9ACD3AED-6C04-3BBB-AB2A-FC253B16D093>    /System/Library/Frameworks/ CoreAudio.framework/Versions/A/CoreAudio
                                      0x7fff8cd05000 -          0x7fff8cd72ff7 com.apple.datadetectorscore (4.1 - 269.3)
                                      <5775F0DB-87D6-310D-8B03-E2AD729EFB28>     /System/Library/PrivateFrameworks/ DataDetectorsCore.framework/Versions/A/DataDetectorsCore
                                      0x7fff8ce9e000 -          0x7fff8cea1ff7 libdyld.dylib (210.2.3) <F59367C9-C110-382B- A695-9035A6DD387E>   /usr/lib/system/libdyld.dylib
                                      0x7fff8cea2000 -          0x7fff8cea6ff7 com.apple.TCC (1.0 - 1) <F2F3B753-
                                      FC73-3543-8BBE-859FDBB4D6A6>     /System/Library/PrivateFrameworks/TCC.framework/Versions/A/ TCC
                                      0x7fff8cea7000 -          0x7fff8cf10fff libstdc++.6.dylib (56) <EAA2B53E-EADE-39CF-A0EF- FB9D4940672A>  /usr/lib/libstdc++.6.dylib
                                      0x7fff8cf11000 -          0x7fff8cf54ff7 com.apple.bom (12.0 - 192) <0BF1F2D2-3648-36B7- BE4B-551A0173209B>     /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                                      0x7fff8cfa1000 -          0x7fff8cfd2ff7 com.apple.DictionaryServices (1.2 - 184.4)
                                      <054F2D6F-9CFF-3EF1-9778-25C551B616C1>    /System/Library/Frameworks/ CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/ DictionaryServices
                                      0x7fff8cfee000 -          0x7fff8cff5fff libGFXShared.dylib (8.9.2) <398F8D57-EC82-3E13-
                                      AC8E-470BE19237D7>     /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/ libGFXShared.dylib
                                      0x7fff8cff6000 -          0x7fff8cff8fff libquarantine.dylib (52.1) <143B726E-DF47-37A8-90AA- F059CFD1A2E4>   /usr/lib/system/libquarantine.dylib
                                      0x7fff8cff9000 -          0x7fff8d02ffff libsystem_info.dylib (406.17) <4FFCA242-7F04-365F-87A6- D4EFB89503C1>   /usr/lib/system/libsystem_info.dylib
                                      0x7fff8d030000 -          0x7fff8d0bdff7 com.apple.SearchKit (1.4.0 - 1.4.0) <C7F43889-F8BF-3CB9- AD66-11AEFCBCEDE7>     /System/Library/Frameworks/CoreServices.framework/Versions/A/ Frameworks/SearchKit.framework/Versions/A/SearchKit
                                      0x7fff8d0be000 -          0x7fff8d0e9fff libxslt.1.dylib (11.3)
                                      <441776B8-9130-3893-956F-39C85FFA644F>    /usr/lib/libxslt.1.dylib
                                      0x7fff8d1fa000 -          0x7fff8d1fafff com.apple.vecLib (3.8 - vecLib 3.8) <794317C7-4E38-338A- A874-5E18001C8503>     /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                      0x7fff8d50e000 -          0x7fff8d825ff7 com.apple.CoreServices.CarbonCore (1037.6 - 1037.6)
                                      <1E567A52-677F-3168-979F-5FBB0818D52B>    /System/Library/Frameworks/ CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
                                      0x7fff8d826000 -          0x7fff8d83dfff libGL.dylib (8.9.2) <B8E5948D-BCF2-3727-B74E- D74B8EDC82D6>     /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                      0x7fff8e164000 -          0x7fff8e1a1fef libGLImage.dylib (8.9.2) <C38649ED-E1C9-315E-9953- F33E8C6A3C89>     /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/ libGLImage.dylib
                                      0x7fff8e342000 -          0x7fff8e344fff com.apple.TrustEvaluationAgent (2.0 - 23)
                                      <A97D348B-32BF-3E52-8DF2-59BFAD21E1A3>     /System/Library/PrivateFrameworks/ TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
                                      0x7fff8e345000 -          0x7fff8e3e0fff com.apple.CoreSymbolication (3.0 - 117)
                                      <C304FDB8-2FF7-34BC-858A-2B96C2B039D5>     /System/Library/PrivateFrameworks/ CoreSymbolication.framework/Versions/A/CoreSymbolication
                                      0x7fff8e3e1000 -          0x7fff8e40fff7 libsystem_m.dylib (3022.6) <B434BE5C-25AB-3EBD- BAA7-5304B34E3441>   /usr/lib/system/libsystem_m.dylib
                                      0x7fff8e410000 -          0x7fff8e610fff libicucore.A.dylib (491.11.3)
                                      <5783D305-04E8-3D17-94F7-1CEAFA975240>    /usr/lib/libicucore.A.dylib
                                      0x7fff8e611000 -          0x7fff8e62cff7 libsystem_kernel.dylib (2050.24.15) <A9F97289-7985-31D6- AF89-151830684461>   /usr/lib/system/libsystem_kernel.dylib
                                      0x7fff8e695000 -          0x7fff8e6eaff7 libTIFF.dylib (850)
                                      <EDAF0D99-70AF-3B3F-9EFA-9463C91D0E3C>     /System/Library/Frameworks/ImageIO.framework/ Versions/A/Resources/libTIFF.dylib
                                      0x7fff8e6eb000 -          0x7fff8e791ff7 com.apple.CoreServices.OSServices (557.6 - 557.6)
                                      <1BDB5456-0CE9-301C-99C1-8EFD0D2BFCCD>    /System/Library/Frameworks/ CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
                                      0x7fff8e795000 -          0x7fff8e7cfff7 com.apple.GSS (3.0 - 2.0) <970CAE00-1437-3F4E- B677-0FDB3714C08C>     /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                      0x7fff8e85f000 -          0x7fff8e924ff7 com.apple.coreui (2.0 - 181.1)
                                      <83D2C92D-6842-3C9D-9289-39D5B4554C3A>     /System/Library/PrivateFrameworks/ CoreUI.framework/Versions/A/CoreUI
                                      0x7fff8e925000 -          0x7fff8e930fff com.apple.CommonAuth (3.0 - 2.0)
                                      <7A953C1F-8B18-3E46-9BEA-26D9B5B7745D>     /System/Library/PrivateFrameworks/ CommonAuth.framework/Versions/A/CommonAuth
                                      0x7fff8e979000 -          0x7fff8ebaeff7 com.apple.CoreData (106.1 - 407.7) <24E0A6B4-9ECA-3D12- B26A-72B9DCF09768>     /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                      0x7fff8ebe8000 -          0x7fff8ed6efff libBLAS.dylib (1073.4) <C102C0F6-8CB6-3B49-
                                      BA6B-2EB61F0B2784>     /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/ vecLib.framework/Versions/A/libBLAS.dylib
                                      0x7fff8ed81000 -          0x7fff8eda9fff libJPEG.dylib (850) <DC750E1E-BD07-339B-A4A6- D86BFE969F68>     /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/ libJPEG.dylib
                                      0x7fff8f0d1000 -          0x7fff8f0d3fff libCVMSPluginSupport.dylib (8.9.2) <EF1192AC-3357-3A0B- BFAF-6594D7737892>     /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/ libCVMSPluginSupport.dylib
                                      0x7fff8f0e0000 -          0x7fff8f1f9fff com.apple.ImageIO.framework (3.2.1 - 850) <C3FFCEEB- AA0C-314B-9E94-7005EE48A403>     /System/Library/Frameworks/ImageIO.framework/Versions/A/ ImageIO
                                      0x7fff8f1fa000 -          0x7fff8f262ff7 libc++.1.dylib (65.1) <20E31B90-19B9-3C2A- A9EB-474E08F9FE05>   /usr/lib/libc++.1.dylib
                                      0x7fff8f263000 -          0x7fff8f314fff com.apple.LaunchServices (539.9 - 539.9)
                                      <07FC6766-778E-3479-8F28-D2C9917E1DD1>    /System/Library/Frameworks/ CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/
                                      LaunchServices
                                      0x7fff8f354000 -          0x7fff8f4c9ff7 com.apple.CFNetwork (596.4.3 - 596.4.3)
                                      <A57B3308-2F08-3EC3-B4AC-39A3D9F0B9F7>    /System/Library/Frameworks/ CFNetwork.framework/Versions/A/CFNetwork
                                      0x7fff8f4ca000 -          0x7fff8f4d6fff com.apple.CrashReporterSupport (10.8.3 - 418) <DE6AFE16- D97E-399D-82ED-3522C773C36E>    /System/Library/PrivateFrameworks/ CrashReporterSupport.framework/Versions/A/CrashReporterSupport
                                      0x7fff8f4d7000 -          0x7fff8f4e6ff7 libxar.1.dylib (105) <370ED355-E516-311E-BAFD- D80633A84BE1>  /usr/lib/libxar.1.dylib
                                      0x7fff8f873000 -          0x7fff8f878fff libcache.dylib (57) <65187C6E-3FBF-3EB8- A1AA-389445E2984D>   /usr/lib/system/libcache.dylib
                                      0x7fff8f879000 -          0x7fff904a6fff com.apple.AppKit (6.8 - 1187.39) <199962F0-
                                      B06B-3666-8FD5-5C90374BA16A>     /System/Library/Frameworks/AppKit.framework/Versions/C/ AppKit
                                      0x7fff904a7000 -          0x7fff905a9fff libJP2.dylib (850)
                                      <2E43216C-3A5A-3693-820C-38B360698FA0>     /System/Library/Frameworks/ImageIO.framework/ Versions/A/Resources/libJP2.dylib
                                      0x7fff905aa000 -          0x7fff905cbfff com.apple.Ubiquity (1.2 - 243.15) <C9A7EE77-B637-3676- B667-C0843BBB0409>     /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                                      0x7fff905e1000 -          0x7fff9067bfff libvMisc.dylib (380.6) <714336EA-1C0E-3735-
                                      B31C-19DFDAAF6221>     /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/ vecLib.framework/Versions/A/libvMisc.dylib
                                      0x7fff9067d000 -          0x7fff90686ff7 com.apple.CommerceCore (1.0 - 26.1)
                                      <40A129A8-4E5D-3C7A-B299-8CB203C4C65D>     /System/Library/PrivateFrameworks/ CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/ CommerceCore
                                      0x7fff90687000 -          0x7fff90692ff7 com.apple.bsd.ServiceManagement (2.0 - 2.0)
                                      <C12962D5-85FB-349E-AA56-64F4F487F219>    /System/Library/Frameworks/ ServiceManagement.framework/Versions/A/ServiceManagement
                                      0x7fff90695000 -          0x7fff907e7fff com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9)
                                      <62770C0F-5600-3EF9-A893-8A234663FFF5>    /System/Library/Frameworks/ AudioToolbox.framework/Versions/A/AudioToolbox
                                      0x7fff907e8000 -          0x7fff907f0fff liblaunch.dylib (442.26.2) <2F71CAF8-6524-329E-AC56- C506658B4C0C>   /usr/lib/system/liblaunch.dylib
                                      0x7fff90841000 -          0x7fff9091bfff com.apple.backup.framework (1.4.3 - 1.4.3)
                                      <6B65C44C-7777-3331-AD9D-438D10AAC777>     /System/Library/PrivateFrameworks/ Backup.framework/Versions/A/Backup
                                      0x7fff90921000 -          0x7fff90d18fff libLAPACK.dylib (1073.4)
                                      <D632EC8B-2BA0-3853-800A-20DA00A1091C>     /System/Library/Frameworks/Accelerate.framework/ Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
                                      0x7fff90e9f000 - 0x7fff90efefff com.apple.AE (645.6 - 645.6) <44F403C1-660A-3543- AB9C-3902E02F936F> /System/Library/Frameworks/CoreServices.framework/Versions/A/ Frameworks/AE.framework/Versions/A/AE
                                      0x7fff90f04000 -          0x7fff90f26ff7 libxpc.dylib (140.43) <70BC645B-6952-3264-930C- C835010CCEF9>   /usr/lib/system/libxpc.dylib
                                      0x7fff90f5f000 -          0x7fff90f5ffff libkeymgr.dylib (25) <CC9E3394-BE16-397F-926B- E579B60EE429>   /usr/lib/system/libkeymgr.dylib
                                      0x7fff90f62000 -          0x7fff90f75ff7 libbsm.0.dylib (32)
                                      <F497D3CE-40D9-3551-84B4-3D5E39600737>    /usr/lib/libbsm.0.dylib 0x7fff911f8000 -          0x7fff91277ff7 com.apple.securityfoundation (6.0 - 55115.4)
                                      <8676E0DF-295F-3690-BDAA-6C9C1D210B88>    /System/Library/Frameworks/ SecurityFoundation.framework/Versions/A/SecurityFoundation
                                      0x7fff912bd000 -          0x7fff912bfff7 com.apple.print.framework.Print (8.0 - 258) <34666CC2- B86D-3313-B3B6-A9977AD593DA>     /System/Library/Frameworks/Carbon.framework/Versions/A/ Frameworks/Print.framework/Versions/A/Print
                                      0x7fff912c0000 -          0x7fff9161ffff com.apple.Foundation (6.8 - 945.18) <1D7E58E6-FA3A-3CE8- AC85-B9D06B8C0AA0>     /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                      0x7fff91620000 -          0x7fff91656fff com.apple.DebugSymbols (98 - 98)
                                      <14E788B1-4EB2-3FD7-934B-849534DFC198>     /System/Library/PrivateFrameworks/ DebugSymbols.framework/Versions/A/DebugSymbols
                                      0x7fff918cf000 -          0x7fff91912ff7 com.apple.RemoteViewServices (2.0 - 80.6)
                                      <5CFA361D-4853-3ACC-9EFC-A2AC1F43BA4B>     /System/Library/PrivateFrameworks/ RemoteViewServices.framework/Versions/A/RemoteViewServices
                                      0x7fff91a05000 -          0x7fff91a0afff com.apple.OpenDirectory (10.8 - 151.10)
                                      <CF44120B-9B01-32DD-852E-C9C0E1243FC0>    /System/Library/Frameworks/ OpenDirectory.framework/Versions/A/OpenDirectory
                                      0x7fff91a0b000 -          0x7fff91a1dff7 libz.1.dylib (43) <2A1551E8-A272-3DE5- B692-955974FE1416>  /usr/lib/libz.1.dylib
                                      0x7fff91a20000 -          0x7fff91a20fff com.apple.Carbon (154 - 155)
                                      <1B2846B1-384E-3D1C-8999-201215723349>     /System/Library/Frameworks/Carbon.framework/ Versions/A/Carbon
                                      0x7fff91a21000 -          0x7fff91a24fff com.apple.help (1.3.2 - 42)
                                      <343904FE-3022-3573-97D6-5FE17F8643BA>     /System/Library/Frameworks/Carbon.framework/ Versions/A/Frameworks/Help.framework/Versions/A/Help
                                      0x7fff91a25000 -          0x7fff91a3bfff com.apple.MultitouchSupport.framework (235.29 - 235.29)
                                      <617EC8F1-BCE7-3553-86DD-F857866E1257>     /System/Library/PrivateFrameworks/ MultitouchSupport.framework/Versions/A/MultitouchSupport
                                      0x7fff91a9a000 -          0x7fff91a9dfff libRadiance.dylib (850) <62E3F7FB-03E3-3937-A857- AF57A75EAF09>     /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/ libRadiance.dylib
                                      0x7fff91c6d000 -          0x7fff91cbcff7 libcorecrypto.dylib (106.2) <CE0C29A3-C420-339B- ADAA-52F4683233CC>   /usr/lib/system/libcorecrypto.dylib
                                      0x7fff91de5000 -          0x7fff91e0aff7 libc++abi.dylib (26) <D86169F3-9F31-377A-9AF3- DB17142052E4>  /usr/lib/libc++abi.dylib
                                      0x7fff91e0b000 -          0x7fff91e0fff7 com.apple.CommonPanels (1.2.5 - 94)
                                      <AAC003DE-2D6E-38B7-B66B-1F3DA91E7245>     /System/Library/Frameworks/Carbon.framework/ Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
                                      0x7fff91e10000 -          0x7fff91e10fff libOpenScriptingUtil.dylib (148.3) <F8681222-0969-3B10-8BCE- C55A4B9C520C>   /usr/lib/libOpenScriptingUtil.dylib
                                      0x7fff91e84000 -          0x7fff91ea6ff7 com.apple.Kerberos (2.0 - 1) <C49B8820-34ED-39D7-A407- A3E854153556>     /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                      0x7fff91f0b000 -          0x7fff9202392f libobjc.A.dylib (532.2) <90D31928- F48D-3E37-874F-220A51FD9E37>   /usr/lib/libobjc.A.dylib
                                      0x7fff92fe4000 -          0x7fff939744af com.apple.CoreGraphics (1.600.0 - 332)
                                      <5AB32E51-9154-3733-B83B-A9A748652847>    /System/Library/Frameworks/ ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/ CoreGraphics
                                      0x7fff93975000 -          0x7fff93996ff7 libCRFSuite.dylib (33) <736ABE58-8DED-3289-A042-
                                      C25AF7AE5B23>   /usr/lib/libCRFSuite.dylib 0x7fff93997000 -          0x7fff9399bfff libpam.2.dylib (20)
                                      <C8F45864-5B58-3237-87E1-2C258A1D73B8>    /usr/lib/libpam.2.dylib 0x7fff9399c000 -          0x7fff93b86ff7 com.apple.CoreFoundation (6.8 - 744.19)
                                      <0F7403CA-2CB8-3D0A-992B-679701DF27CA>    /System/Library/Frameworks/ CoreFoundation.framework/Versions/A/CoreFoundation
                                      0x7fff93d5f000 -          0x7fff93d86fff com.apple.framework.familycontrols (4.1 - 410)
                                      <50F5A52C-8FB6-300A-977D-5CFDE4D5796B>     /System/Library/PrivateFrameworks/ FamilyControls.framework/Versions/A/FamilyControls
                                      0x7fff93da0000 -          0x7fff93dadff7 com.apple.NetAuth (4.0 - 4.0) <F5BC7D7D-AF28-3C83-A674- DADA48FF7810>     /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                      0x7fff93db2000 -          0x7fff93dc0ff7 libkxld.dylib (2050.24.15) <A619A9AC-09AF-3FF3-95BF- F07CC530EC31>   /usr/lib/system/libkxld.dylib
                                      0x7fff93dfc000 -          0x7fff93e58ff7 com.apple.Symbolication (1.3 - 93) <97F3B1D2-
                                      D81D-3F37-87B3-B9A686124CF5>     /System/Library/PrivateFrameworks/Symbolication.framework/ Versions/A/Symbolication
                                      0x7fff93fa9000 -          0x7fff93fc0fff com.apple.GenerationalStorage (1.1 - 132.3)
                                      <FD4A84B3-13A8-3C60-A59E-25A361447A17>     /System/Library/PrivateFrameworks/ GenerationalStorage.framework/Versions/A/GenerationalStorage
                                      0x7fff93fc1000 -          0x7fff93fc5fff libCoreVMClient.dylib (32.3) <AD8391D9-56DD-3A78- A294-6A30E6ECE1A2>     /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/ libCoreVMClient.dylib
                                      0x7fff93fc6000 -          0x7fff93fc7ff7 libdnsinfo.dylib (453.19) <14202FFB- C3CA-3FCC-94B0-14611BF8692D>    /usr/lib/system/libdnsinfo.dylib
                                      0x7fff93fc8000 -          0x7fff93ff6fff com.apple.CoreServicesInternal (154.3 - 154.3) <F4E118E4- E327-3314-83D7-EA20B1717ED0>    /System/Library/PrivateFrameworks/ CoreServicesInternal.framework/Versions/A/CoreServicesInternal
                                      0x7fff93ff7000 -          0x7fff94003fff libCSync.A.dylib (332) <47466CF6-
                                      EB5C-3312-9E24-178F4410A92B>     /System/Library/Frameworks/ApplicationServices.framework/ Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
                                      0x7fff94004000 -          0x7fff94004fff com.apple.Cocoa (6.7 - 19) <1F77945C-F37A-3171-B22E-
                                      F7AB0FCBB4D4>     /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff94013000 -          0x7fff94017fff libGIF.dylib (850) <D4525F87-759C-338C-B283-
                                      BB8DE815D3D5>     /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/ libGIF.dylib
                                      0x7fff94018000 -          0x7fff9401aff7 libunc.dylib (25) <92805328- CD36-34FF-9436-571AB0485072>   /usr/lib/system/libunc.dylib
                                      0x7fff940ab000 -          0x7fff940bafff com.apple.opengl (1.8.9 - 1.8.9) <6FD163A7-16CC-3D1F- B4B5-B0FDC4ADBF79>     /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                      0x7fff94107000 -          0x7fff94108ff7 libremovefile.dylib (23.2) <6763BC8E-18B8-3AD9-8FFA- B43713A7264F>   /usr/lib/system/libremovefile.dylib
                                      0x7fff94109000 -          0x7fff94113fff com.apple.speech.recognition.framework (4.1.5 - 4.1.5)
                                      <D803919C-3102-3515-A178-61E9C86C46A1>     /System/Library/Frameworks/Carbon.framework/ Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
                                      0x7fff94481000 -          0x7fff94485fff libCGXType.A.dylib (332) <17C8DD17-B3CB-3633-B252-
                                      C368AE51204C>     /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                                      0x7fff94486000 -          0x7fff9457bfff libiconv.2.dylib (34) <FEE8B996-EB44-37FA-B96E- D379664DEFE1>  /usr/lib/libiconv.2.dylib
                                      0x7fff945e8000 -          0x7fff945f0ff7 libsystem_dnssd.dylib (379.38.1)
                                      <BDCB8566-0189-34C0-9634-35ABD3EFE25B>     /usr/lib/system/libsystem_dnssd.dylib 0x7fff945f1000 -          0x7fff94606fff com.apple.ImageCapture (8.0 - 8.0) <17A45CE6-7DA3-36A5-
                                      B7EF-72BC136981AE>     /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ ImageCapture.framework/Versions/A/ImageCapture
                                      0x7fff94607000 -          0x7fff94937fff com.apple.HIToolbox (2.0 - 626.1) <656D08C2-9068-3532- ABDD-32EC5057CCB2>     /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ HIToolbox.framework/Versions/A/HIToolbox
                                      0x7fff94938000 -          0x7fff94989ff7 com.apple.SystemConfiguration (1.12.2 - 1.12.2) <A4341BBD- A330-3A57-8891-E9C1A286A72D>     /System/Library/Frameworks/SystemConfiguration.framework/ Versions/A/SystemConfiguration
                                      0x7fff9498a000 -          0x7fff94a0bfff com.apple.Metadata (10.7.0 - 707.11)
                                      <2DD25313-420D-351A-90F1-300E95C970CA>    /System/Library/Frameworks/ CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
                                      0x7fff94a48000 -          0x7fff94e65fff FaceCoreLight (2.4.1) <A34C9575-
                                      C4C1-31B1-809B-7751070B4E8B>     /System/Library/PrivateFrameworks/FaceCoreLight.framework/ Versions/A/FaceCoreLight
                                      0x7fff94e6b000 -          0x7fff94e6ffff com.apple.IOSurface (86.0.4 - 86.0.4) <26F01CD4-
                                      B76B-37A3-989D-66E8140542B3>     /System/Library/Frameworks/IOSurface.framework/Versions/A/ IOSurface
                                      0x7fff94ef3000 -          0x7fff94f49fff com.apple.HIServices (1.20 - 417) <A1129272-FEC8-350B- BA26-5A97F23C413D>     /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ Frameworks/HIServices.framework/Versions/A/HIServices
                                      0x7fff94f4a000 -          0x7fff94f50fff libmacho.dylib (829) <BF332AD9- E89F-387E-92A4-6E1AB74BD4D9>    /usr/lib/system/libmacho.dylib
                                      0x7fff94f51000 -          0x7fff94f71fff libPng.dylib (850) <203C43BF-FAD3-3CCB-81D5- F2770E36338B>     /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/ libPng.dylib
                                      0x7fff950e7000 -          0x7fff95141fff com.apple.print.framework.PrintCore (8.3 - 387.2)
                                      <5BA0CBED-4D80-386A-9646-F835C9805B71>    /System/Library/Frameworks/ ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintC ore
                                      0x7fff95436000 -          0x7fff95490ff7 com.apple.opencl (2.2.19 - 2.2.19) <3C7DFB2C-B3F9-3447- A1FC-EAAA42181A6E>     /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                      0x7fff95521000 -          0x7fff95527fff com.apple.DiskArbitration (2.5.2 - 2.5.2)
                                      <C713A35A-360E-36CE-AC0A-25C86A3F50CA>    /System/Library/Frameworks/ DiskArbitration.framework/Versions/A/DiskArbitration
                                      0x7fff95528000 -          0x7fff9552afff com.apple.securityhi (4.0 - 55002) <26E6D477-EF61-351F- BA8C-67824AA231C6>     /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ SecurityHI.framework/Versions/A/SecurityHI
                                      0x7fff9552b000 -          0x7fff955f7ff7 libsystem_c.dylib (825.26) <4C9EB006-FE1F-3F8F-8074- DFD94CF2CE7B>   /usr/lib/system/libsystem_c.dylib
                                      0x7fff95649000 -          0x7fff95657fff libcommonCrypto.dylib (60027) <BAAFE0C9- BB86-3CA7-88C0-E3CBA98DA06F>    /usr/lib/system/libcommonCrypto.dylib
                                      0x7fff9566c000 -          0x7fff95693ff7 com.apple.PerformanceAnalysis (1.16 - 16) <E4888388- F41B-313E-9CBB-5807D077BDA9>    /System/Library/PrivateFrameworks/ PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
                                      0x7fff95694000 -          0x7fff956a8fff com.apple.speech.synthesis.framework (4.1.12 - 4.1.12)
                                      <94EDF2AB-809C-3D15-BED5-7AD45B2A7C16>    /System/Library/Frameworks/ ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/ SpeechSynthesis
                                      0x7fff956a9000 -          0x7fff956b0fff libcopyfile.dylib (89) <876573D0-E907-3566- A108-577EAD1B6182>   /usr/lib/system/libcopyfile.dylib
                                      0x7fff956b4000 -          0x7fff956b5fff libDiagnosticMessagesClient.dylib (8) <8548E0DC-0D2F-30B6- B045-FE8A038E76D8>    /usr/lib/libDiagnosticMessagesClient.dylib
                                      0x7fff95f82000 -          0x7fff95f90fff com.apple.Librarian (1.1 - 1) <5AC28666-7642-395F-A923- C6F8A274BBBD>     /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
                                      0x7fff95f91000 -          0x7fff9609cfff libFontParser.dylib (84.6) <96C42E49-79A6-3475-
                                      B5E4-6A782599A6DA>     /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
                                      0x7fff960e8000 -          0x7fff96137ff7 libFontRegistry.dylib (100)
                                      <2E03D7DA-9B8F-31BB-8FB5-3D3B6272127F>    /System/Library/Frameworks/ ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ libFontRegistry.dylib
                                      0x7fff96138000 -          0x7fff96182ff7 libGLU.dylib (8.9.2) <1B5511FF-1064-3004-
                                      A245-972CE5687D37>     /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/ libGLU.dylib
                                      0x7fff96192000 - 0x7fff96436ff7 com.apple.CoreImage (8.4.0 - 1.0.1) <CC6DD22B-FFC6-310B- BE13-2397A02C79EF> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ CoreImage.framework/Versions/A/CoreImage
                                      0x7fff966e8000 -          0x7fff966e8ffd com.apple.audio.units.AudioUnit (1.9 - 1.9)
                                      <EC55FB59-2443-3F08-9142-7BCC93C76E4E>     /System/Library/Frameworks/AudioUnit.framework/ Versions/A/AudioUnit
                                      0x7fff966e9000 -          0x7fff966f0fff com.apple.NetFS (5.0 - 4.0) <82E24B9A-7742-3DA3-9E99-
                                      ED267D98C05E>     /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff966f1000 -          0x7fff966f1fff com.apple.CoreServices (57 - 57) <9DD44CB0-
                                      C644-35C3-8F57-0B41B3EC147D>     /System/Library/Frameworks/CoreServices.framework/Versions/ A/CoreServices
                                      0x7fff9672f000 -          0x7fff96801ff7 com.apple.CoreText (260.0 - 275.16)
                                      <5BFC1D67-6A6F-38BC-9D90-9C712684EDAC>     /System/Library/Frameworks/CoreText.framework/ Versions/A/CoreText
                                      0x7fff96802000 -          0x7fff96803fff libsystem_blocks.dylib (59) <D92DCBC3-541C-37BD-AADE- ACC75A0C59C8>   /usr/lib/system/libsystem_blocks.dylib
                                      0x7fff9682e000 -          0x7fff96affff7 com.apple.security (7.0 - 55179.13) <F428E306-C407-3B55- BA82-E58755E8A76F>     /System/Library/Frameworks/Security.framework/Versions/A/Security
                                      0x7fff96b00000 -          0x7fff96b17fff com.apple.CFOpenDirectory (10.8 - 151.10) <10F41DA4- AD54-3F52-B898-588D9A117171>     /System/Library/Frameworks/OpenDirectory.framework/Versions/ A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
                                      0x7fff96c77000 -          0x7fff96c96ff7 com.apple.ChunkingLibrary (2.0 - 133.3) <8BEC9AFB- DCAA-37E8-A5AB-24422B234ECF>    /System/Library/PrivateFrameworks/ ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                                      0x7fff97151000 -          0x7fff971a8ff7 com.apple.ScalableUserInterface (1.0 - 1)
                                      <F1D43DFB-1796-361B-AD4B-39F1EED3BE19>    /System/Library/Frameworks/ QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/
                                      External Modification Summary:
                                      Calls made by other processes targeting this process: task_for_pid: 2
                                      thread_create: 0
                                      thread_set_state: 0
                                      Calls made by this process: task_for_pid: 0
                                      thread_create: 0
                                      thread_set_state: 0
                                      Calls made by all processes on this machine: task_for_pid: 2353
                                      thread_create: 2
                                      thread_set_state: 0
                                      VM Region Summary:
                                      ReadOnly portion of Libraries: Total=248.0M resident=210.1M(85%) swapped_out_or_unallocated=37.9M(15%)
                                      Writable regions: Total=94.1M written=44.1M(47%) resident=55.8M(59%) swapped_out=0K(0%) unallocated=38.4M(41%)
                                      REGION TYPE          VIRTUAL
                                      CG backing stores          1936K
                                      CG shared images                    1184K CoreServices          4648K
                                      MALLOC          63.7M
                                      MALLOC guard page          48K
                                      MALLOC_LARGE (reserved)                    9.8M          reserved VM address space (unallocated) Memory tag=242          12K
                                      Memory tag=243          4K
                                      STACK GUARD          56.0M
                                      Stack          11.0M
                                      VM_ALLOCATE          2264K
                                         DATA          16.1M
                                         IMAGE          528K
                                         LINKEDIT          69.5M
                                         TEXT          178.5M
                                         UNICODE          544K
                                      mapped file          23.2M shared memory                    308K
                                      ===========                    ======= TOTAL          439.1M
                                      TOTAL, minus reserved VM space          429.3M
                                      Model: iMac10,1, BootROM IM101.00CC.B00, 2 processors, Intel Core 2 Duo, 3.06 GHz, 8 GB, SMC 1.53f13
                                      Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe, 256 MB Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54313235533642465238432D47372020
                                      Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1067 MHz, 0x80AD, 0x484D54313235533642465238432D47372020
                                      Memory Module: BANK 0/DIMM1, 2 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3031302E4130304C4620
                                      Memory Module: BANK 1/DIMM1, 2 GB, DDR3, 1067 MHz, 0x0198, 0x393930353432382D3031302E4130304C4620
                                      AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.72.0-P2P Bluetooth: Version 4.1.4f2 12041, 2 service, 18 devices, 1 incoming serial ports
                                      Network Service: AirPort, AirPort, en1
                                      Serial ATA Device: ST31000528AS, 1 TB
                                      Serial ATA Device: OPTIARC DVD RW AD-5680H
                                      USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0x26500000 / 4 USB Device: iPF8000, 0x04a9 (Canon Inc.), 0x140e, 0x26400000 / 3
                                      USB Device: My Book 1140, 0x1058 (Western Digital Technologies, Inc.), 0x1140, 0x26200000 / 2 USB Device: Built-in iSight, apple_vendor_id, 0x8502, 0x24400000 / 2
                                      USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000 / 2 USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x06110000 / 5 USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x04500000 / 3
                                      USB Device: HASP 2.17, 0x0529 (Aladdin Knowledge Systems), 0x0001, 0x04300000 / 2 FireWire Device: d2 quadra (button), LaCie, 800mbit_speed
                                      • 97. Re: InDesign CC crashes - Lauch/Text tool
                                        Scott Worthington Adobe Employee
                                        Mazinaus,
                                        Most times when I see a log like yours it's related to a few possibilities.
                                        1. Corrupt preferences. http://forums.adobe.com/thread/526990 - I always prefer the manual removal to the shortcut keys.
                                        2. Problems with SING - http://helpx.adobe.com/indesign/kb/hang-freeze-open-create-file.html
                                        3. Damaged installation
                                        It would not appear to be related to the issue within this thread.
                                        In the future, should you need to repost a crash log, please make use of Pastebin.  http://pastebin.com
                                        • 98. Re: InDesign CC crashes - Lauch/Text tool
                                          Send your file to someone who has CC and they can send you a small converter (.idml) file to allow you to open the CC file in CS6. I'm sure anyone on this forum would be more than happy to do it (me included). That would sort the deadline out and you can work on the font issue after....
                                          • 99. Re: InDesign CC crashes - Lauch/Text tool
                                            mazinaus Level 1
                                            Hi Scott and Robert, Thanks for your input. All fixed now. It just needed a restart on the mac, a clean up of my hard drive and all is well.
                                            • 100. Re: InDesign CC crashes - Lauch/Text tool
                                              edsto
                                              CS3 Indesign and photoshop are crashing after upgrading to OS 10.9
                                              FIXXXX ITTT !
                                              • 101. Re: InDesign CC crashes - Lauch/Text tool
                                                BobLevine MVP & Adobe Community Professional
                                                As I pointed out in your Creative Suite threadŠCS3 is not supported under
                                                10.9.
                                                • 102. Re: InDesign CC does not work properly - Text tool
                                                  nishwick
                                                  Hey Adobe.
                                                  At least you know the error, but we are paying you and not able to bill our clients, so hurry up.
                                                  • 103. Re: InDesign CC does not work properly - Text tool
                                                    This was addressed over a month ago in the 9.1 update. Did you install it?
                                                    • 104. Re: indesign cc does not work properly
                                                      cherylart2
                                                      I have tried downloading the copyplugin for Mac in both Firefox and Safari, both tell me it is corrupt. I have even uninstalled the program and re-installed it. It is not working. Help! I am on a Mac using Mavericks OS
                                                      • 105. Re: indesign cc does not work properly
                                                        Did you update to 9.1?
                                                        • 106. Re: indesign cc does not work properly
                                                          cherylart2 Level 1
                                                          yes, and I finally got the plugin installed, now when I go to open the program it tells me
                                                          Cannot load Adobe InDesign CC because it requires version 9.1 or later of the Font Manager.InDesignPlugin plug-in. Please contact vendor for compatible version of Font Manager.InDesignPlugin.
                                                          So I downloaded a trial version of Extensis- Suitcase fusion and installed it and it still does not work.
                                                          • 107. Re: indesign cc does not work properly
                                                            I believe that's an Adobe plugin, not something from Extensis, which implies that your install is damaged.
                                                            • 108. Re: indesign cc does not work properly
                                                              cherylart2 Level 1
                                                              I looked all over adobe for the plugin and found nothing- what do I do now?
                                                              • 109. Re: indesign cc does not work properly
        Uninstall and reinstall.
        • 110. Re: indesign cc does not work properly
        cherylart2 Level 1
        I did that yesterday and it did not work and so that is what started me looking for the plugin- so what do I do once I have uninstalled and reinstalled and it still doesn't work?
        • 111. Re: indesign cc does not work properly
        cherylart2 Level 1
        or can I just uninstall Suitcase?
        • 112. Re: indesign cc does not work properly
        I would definitely try that.
        • 113. Re: indesign cc does not work properly
        cherylart2 Level 1
        okay so now this is the error message I get
        btw, this is the version of Indesign I have 9.1.0.33
        • 114. Re: indesign cc does not work properly
        My inclination would be to uninstall all of CC, run the cleaner tool (CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3),
        restart the Mac holding downthe Shift key to stop extensions from loading, then reinstall first the Desktop Application, then let it reinstall the other applications.
        • 115. Re: indesign cc does not work properly
        cherylart2 Level 1
        not what I was hoping to hear. Thanks
        • 116. Re: indesign cc does not work properly
        cherylart2 Level 1
        This did not work. Have uninstalled Creative Cloud and Indesign CC and did the cloud cleaner. Re installed both programs and still Indesign does not open fully. I get a menu bar across the top. I try to start a new document or open and old one and it crashes. Now what??
        • 117. Re: indesign cc does not work properly
        Not sure if the installer is currently at 9.0 or 9.1, so be sure you are running 9.1 (update if necessary). And did you uninstall Suitcase?
        • 118. Re: indesign cc does not work properly
        cherylart2 Level 1
        Yes I uninstalled Suitcase. This is the version of InDesign I installed yesterday 9.1.0.33
        • 119. Re: indesign cc does not work properly
        Do you have a crash report? If so, maybe it will give us a clue. Please post it on Pastebin.com and put a link to it here.
