2 Replies Latest reply on Oct 17, 2007 12:53 PM by SonOfGerale
    Non visual components and the component palette
    SonOfGerale
      Greetings
      I have not found a way to place a non-visual component on the component palette. If I derive from canvas or uicomponent it pulls in unneeded overhead, but that is the only way it seems to have a component show up in the custom components node in the component palette. Is there a trick to force a descendant of Validator, Manager or any non-visual base class onto the component palette so properties can be set at design time?
        • 1. Re: Non visual components and the component palette
          Greg (Adobe)
          Putting a non-visual component in the Components Panel is not the real issue. Even if you could put a non-visual component in the Components Panel (you can't), it wouldn't do you any good because Design Mode only draws items that are visual components.
          When you say you want to set the properties of a non-visual component at design time, do you mean you'd like to set values in the Property Inspector? A feature that we have considered for a future version of Flex Builder is to enable the Property Inspector to work in Code Mode and for non-visual items. You could select the tag in the code view or in the Outline view and its properties would be editable in the Property Inspector.
          Or do you want to have some kind of iconic representation of the non-visual item on the design surface that you could select and manipulate? This is tricky from a user interface perspective.
          -- Greg Dow
          -- Adobe Flex Builder Team
          • 2. Non visual components and the component palette
            SonOfGerale Level 1
            Thanks for your reply.
            For UI issues it would be nice to have the ability to link components to components (visual/non visual) at design time on the design surface via a bindable property of some sort.
            Thanks for the heads up.
