7 Replies Latest reply: Jun 19, 2013 6:01 PM by Cyberbob RSS
    Not enough space available on disk untitled
    apldaasdsda
      Every time when I trie to install any application from creative cloud I do get an error "Not enough space available on disk untitles (-30)". There is no drive called untitled and there is enought space available (50GB).
      It happens on both my Mac Mini and Mac Book Pro. The only similarity I can find is that they both have a custom Kingston 60GB SSD.
      Does anyone have a solution to this problem, I've already tried to change the install location to an HDD.
        • 1. Re: Not enough space available on disk untitled
          Cyberbob
          Same issue here,
          Not enough diskspace available on untitled (-30).
          I have an Vertex 4 - 512 SSD with 150Gb Free..
          Issue on both my mini and my macbook pro.
          The strange thing is, I don't have a disk named untitled.
          Both systems run mountain lion,
          Both have an SSD.
          Both systems have 16Gb of memmory.
          Both systems do not have the OSX recovery partition.
          Both systems have only 1 disk and both have enough diskspace.
          Both systems have trimm enabler running.
          Installation of bridge, dreamweaver and other small applications, i can install, but as soon as i try to install
          AI, PS, or any other large application I cannot download. It aborts before the download starts!.
          Both systems give the same error.
          This error occurred on the CS6 online installer and on the new CC installer.
          • 2. Re: Not enough space available on disk untitled
            shughey3
            Same here, OWC SSD as my boot. Over 80GB free. No recovery. Rotational HDDs in other drive slots.
            • 3. Re: Not enough space available on disk untitled
              Cyberbob Community Member
              Same as me.. no recovery partition.
              Its not the recovery partition.
              I have recovered the recover partition. But does not help.
              • 4. Re: Not enough space available on disk untitled
                shughey3 Community Member
                Logs:
                06/19/13 15:44:22:440 | [ERROR] | [someID?] |  |  |  |  |  | 35318 | startDownload: Failed to start the download. The DLE status is -1
                I think servers are just overloaded. Which is great when all your products now have 'Cloud' in the name. Ahem.
                • 5. Re: Not enough space available on disk untitled
                  @shugey3  .. Its not the download server!
                  I have this problem now for 6 weeks.
                  I have spend more than 2 hours on the phone today alone with second line support of Adobe to figure out this problem.
                  They have recordered, and recogniced this issue.
                  For people who think they have the same issue . My case nr @ Adobe is ; 0184289129
                  The strange thing is I can download dreamweaver.
                  It looks like when a download is larger than my SSD cache, the download will not initiate and fail with error -30 without initializing the download at all..
                  I don't have a disk Untitled, there is something strange going on.
                  This case is already escalated @ Adobe.
                  • 6. Re: Not enough space available on disk untitled
                    You're right, it's not a download issue.
                    It's a lack of space in /tmp (or /private/tmp). This is a dumb place to stash huge download files, but moving on.. it's an easy fix.
                    If you're set up with a SSD a popular "longetivity" tip is to put tmp in RAM or elsewhere to save some wear and tear.
                    In term type "df -kh", if you see /private/tmp anywhere under "Mounted on" and the "Avail" isn't large (several gigs I'm assuming), there's your problem.
                    The more popular of the ramdisk tips (can't find the link right now) is to place a startup item to do this work and name it "RamFS" or /System/Library/StartupItems/RamFS. Move it out of the way or chmod 000 it temporarily, reboot, and then install. You can replace the StartupItem afterward (then reboot).
                    • 7. Re: Not enough space available on disk untitled
                      @Shughey,
                      Thnx..!!
                      That did the trick..
                      I opened the location you mentioned, moved ramFS to somewhere else. After reboot, installation runs.!
                      Thanks.. Ill submit it at adobe aswell.
