2 Replies Latest reply on Jun 21, 2013 9:12 AM by talon16
    Form Calc
    talon16 Level 1
      I have some fields that total, I want the the field to show no more that 50 even if it is higher.  How do I write the if the totals of the 4 fields is greater that 49 then show 50 in this field?
        • 1. Re: Form Calc
          SaketSidana Adobe Employee
          Let's say you have got the value of total in a variable say numTotal. You want to display it in a field named numField1. You can write a formCalc or javascript to do that. Below is an example of how to do it through formCalc script:
          if (numTotal > 49) then
          form1.sf1.NumField1.rawValue = 50
          else
          form1.sf1.NumField1.rawValue = numTotal;
          endif
          • 2. Re: Form Calc
            talon16 Level 1
            Hi thanks for your response,  here is what I ended up with and works perfectly
            this = DropDownList1 + DropDownList2 + DropDownList3
            if (this>49) then
            this = 50
            else
            this = this
            endif
            Thanks again
