7 Replies Latest reply on Jun 24, 2013 8:51 AM by HiTopp
    Coldfusion Service will not start after reboot
    HiTopp Level 1
      I am having trouble getting the coldfusion service to start after a server reboot.  The service was working prior to the reboot and the only thing that changed was an update to the application hosted on the server.
      The server setup:
      • Windows Server 2008 R2
      • Coldfusion 9.0.1 (multiserver)
      • Java 7 update 13
      • Jrun 4
      The error message I am seeing in all the log files is 'Error loading: C:/Program Files/Java/jre7\bin\server\jvm.dll'.
      Nothing has changed with Java or Jrun since the reboot, so I can't quite put my finger on the actual issue.
      We have tried rebooting the server, updating Java with no success.
      Any thoughts on what it might be?
        • 1. Re: Coldfusion Service will not start after reboot
          Anit_Kumar Adobe Employee
          Hello HiTop,
          Can you share your jvm.config file?
          Regards,
          Anit Kumar
          • 2. Re: Coldfusion Service will not start after reboot
            HiTopp Level 1
            # VM configuration
            # Where to find JVM, if {java.home}/jre exists then that JVM is used
            # if not then it must be the path to the JRE itself
            #java.home=C:/JRun4/jre
            java.home=C:/Program Files/Java/jre7
            # If no java.home is specified a VM is located by looking in these places in this
            # order:
            #  1) bin directory for java.dll (windows) or lib/<ARCH>/libjava.so (unix)
            #  2) ../jre
            #  3) registry (windows only)
            #  4) JAVA_HOME env var plus jre (ie $JAVA_HOME/jre)
            # Arguments to VM
            java.args=-server -Xmx2048m -Dsun.io.useCanonCaches=false -XX:MaxPermSize=192m -XX:+UseParallelGC -Xbatch -Dcoldfusion.rootDir={application.home}/ -Djava.security.policy={application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF /cfusion/lib/coldfusion.policy -Djava.security.auth.policy={application.home}/servers/cfusion/cfusion-ear/cfusion-war/WE B-INF/cfusion/lib/neo_jaas.policy
            # commas will be converted to platform specific separator and the result will be passed
            # as -Djava.ext.dirs= to the VM
            java.ext.dirs={jre.home}/lib/ext
            # where to find shared libraries
            java.library.path={application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusi on/lib,{application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/jintegra /bin,{application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusion/jintegra/b in/international,{application.home}/servers/cfusion/cfusion-ear/cfusion-war/WEB-INF/cfusio n/lib/oosdk/classes/win
            system.path.first=false
            # set the current working directory - useful for Windows to control
            # the default search path used when loading DLLs since it comes
            # before system directory, windows directory and PATH
            java.user.dir={application.home}/../lib
            # JVM classpath
            java.class.path={application.home}/servers/lib,{application.home}/servers/cfusion/cfusion- ear/cfusion-war/WEB-INF/cfusion/lib/oosdk/classes,{application.home}/servers/cfusion/cfusi on-ear/cfusion-war/WEB-INF/cfusion/lib/oosdk/lib,{application.home}/lib,c:/inetpub/v4/java lib
            This does point to an existing jvm.
            • 3. Re: Coldfusion Service will not start after reboot
              Hello HiTop,
              Please try the following:-
              1. Launch Command prompt as Administrator
              2. Browse to C:\JRun4\bin and run the following command jrun.exe -start cfusion
              3. Try to access the CF admin, once the services are started.
              In case it gives an error message, please share the same.
              Regards,
              Anit Kumar
              • 4. Re: Coldfusion Service will not start after reboot
                HiTopp Level 1
                Upon attempting #2, I receive the following error:
                     The program can't start because MSVCR100.dll is missing from your computer.  Try reinstalling the program to fix this problem.
                I did see posts about this, but they related to cumulative hotfix 4 for Coldfusion.  Do you believe this missing .dll file to be the culprit?
                • 5. Re: Coldfusion Service will not start after reboot
                  Yes, that seems to be the issue.
                  Please copy the msvcr100.dll from C:\Program Files\Java\jre7\bin\ to C:\JRun4\bin\ and then try to start the service.
                  Regards,
                  Anit Kumar
                  • 6. Re: Coldfusion Service will not start after reboot
                    HiTopp Level 1
                    Copying the msvcr100.dll to c:/jrun4/bin/ seemed to work.  However, I am wondering why coldfusion isn't looking to the first location for that file.  Do you know why I had to copy the file to the other directory?  I was hoping to keep that .dll in one spot so that future updates occur on the same Java.
                    • 7. Re: Coldfusion Service will not start after reboot
                      HiTopp Level 1
                      @Anit_Kumar,
                      Would you happen to know why this is a desired solution?  Why did I have to copy that file?  Why did the JVM not see it in the original directory?
