1. Re: Bridge 6.3 and Bridge CC incompatibility (bug?)
grampus45 Jun 19, 2013 10:45 AM (in response to grampus45)Here is the crash as reported by the CS6 Problem Report: It clearly has to do with Switchboard.
Thread 6 Crashed:
0 SwitchBoardClient 0x000000011428126e adobe::switchboard::ConnectionQueue::processOneRequest() + 236
1 SwitchBoardClient 0x0000000114281c31 adobe::switchboard::ConnectionQueue::run() + 149
2 SwitchBoardClient 0x00000001142868a3 boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>::operator()(adobe::switchboard::ConnectionQueue*) const + 97
3 SwitchBoardClient 0x0000000114286911 void boost::_bi::list1<boost::_bi::value<adobe::switchboard::ConnectionQueue*> >::operator()<boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>, boost::_bi::list0>(boost::_bi::type<void>, boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>&, boost::_bi::list0&, int) + 65
4 SwitchBoardClient 0x000000011428694e boost::_bi::bind_t<void, boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>, boost::_bi::list1<boost::_bi::value<adobe::switchboard::ConnectionQueue*> > >::operator()() + 54
5 SwitchBoardClient 0x000000011428696c boost::detail::thread_data<boost::_bi::bind_t<void, boost::_mfi::mf0<void, adobe::switchboard::ConnectionQueue>, boost::_bi::list1<boost::_bi::value<adobe::switchboard::ConnectionQueue*> > > >::run() + 28
6 SwitchBoardClient 0x00000001142222be thread_proxy + 89
7 libsystem_c.dylib 0x00007fff8c0a97a2 _pthread_start + 327
8 libsystem_c.dylib 0x00007fff8c0961e1 thread_start + 13
Thread 6 crashed with X86 Thread State (64-bit):
rax: 0x0003000000000000 rbx: 0x0000000114083f50 rcx: 0x00000001145d5b20 rdx: 0x0000000114083fc0
rdi: 0x0000210000002203 rsi: 0x0000220000002200 rbp: 0x00000001145d5d80 rsp: 0x00000001145d5b90
r8: 0x0000000000002060 r9: 0x00000001145d5b20 r10: 0xffffffffffffffff r11: 0x0000000000000206
r12: 0x0000000000008903 r13: 0x0000000000000000 r14: 0x0000000114086d00 r15: 0x0000000114222265
rip: 0x000000011428126e rfl: 0x0000000000010202 cr2: 0x000000010d2a1000
Logical CPU: 1
2. Re: Bridge 6.3 and Bridge CC incompatibility (bug?)
grampus45 Jun 19, 2013 11:57 AM (in response to grampus45)Well, at the risk of jinxing things, the above crash report seems to have provided a hint that has led to a fix. The issue seemed to be with Switchboard, which is not something with which I am familiar. However, a quick Google search determined that Adobe Switchboard is used to communicate among various ancillary items, such as Mini Bridge. So, I opened Mini Bridge in CS6, and, sure enough, it posted a message saying that "the item could not be found."
So I massaged it a bit, closing and reopening, and, lo!, it began to work. Then went back to close out Bridge 6.3, and, at least so far, all has worked well – no further crashing. So apparenly the switchboard was shut down, quite likely due to whatever mucking about took place during the install of CC, but was able to reestablish itself.
At least I can hope.
3. Re: Bridge 6.3 and Bridge CC incompatibility (bug?)
grampus45 Jun 20, 2013 5:17 AM (in response to grampus45)Welll, it seems my optimisim is a bit overblown. The "fix" I described above does indeed seem to correct things for a while, but the issue returns after the computer has gone into a good night's sleep.
Reopening CS6 and MiniBridge seems to re-establish communications for another session, but it appears the fix is not permanent.
Has anyone any idea why this might be happening?
thanks,
grampus45
4. Re: Bridge 6.3 and Bridge CC incompatibility (bug?)
CameraAnn Jun 20, 2013 3:52 PM (in response to grampus45)I think that if we have two versions of Bridge on a computer its probably advisable to give each its own Bridge Cache Folder?
The problem with the screw-up over Bridge CC not yet having AOM is that we have to keep two versions of Bridge on the same System and I can't believe that this is a good idea.
But, until we get AOM restored to Bridge CC, I don't see any alternative.
And Lr is absolutely NOT an acceptable alternative to AOM!!!!
5. Re: Bridge 6.3 and Bridge CC incompatibility (bug?)
station_two Jun 22, 2013 6:36 AM (in response to CameraAnn)CameraAnn wrote:
…until we get AOM restored to Bridge CC…
AOM??? As in "Adobe Output Module"?
You mean they actually took it out in the CC (Cash Cow) version? ??? !!
Honestly, I am of the opinion that those who climbed aboard the CC model have failed to read the Terms of Service of the contract published by Adobe.
82. http://forums.adobe.com/message/5328232
and
