1 Reply Latest reply on Jun 19, 2013 5:56 AM by Abhishek Kapoor
    Problems recording VoiceOver with USB-Device
      I am using a Behringer UCA200 USB Control unit to record voice over. Premiere 6 does not seem to recognize it ("device has no input channels").
      Recording Voice Over with my buit in mic is no problem . What can I do?
      Note: Final Cut Pro has no problems recording voice over with the device.
        • 1. Re: Problems recording VoiceOver with USB-Device
          Abhishek Kapoor Adobe Employee
          If you are working on MAC OS setup USB device as Aggreate Device
          1. In the Audio Midi Setup application in Utilities, go to Audio > Open Aggregate Device Editor.
          2. Check each of the following:
            • Your USB microphone.
            • An additional input device, for example, Line In.
            • An output device
          3. Select this new aggregate device within Premiere Pro's Audio Hardware Preference panel.
          Also try adding a Mono track in sequence and try to record on it
