5 Replies Latest reply: Sep 15, 2013 9:55 PM by deepak k. RSS
    Add new fonts to CM
    jwe@livecycle Community Member
      Hi everyone,
      I'd like to add a new font in CM & use it in the CM's Editor.
      What I did so far:
      • installed the font on the server -> right click on font file & install
      • copied font file to custom font directory at D:/Adobe/font
      • add Font name "Frutiger LT Com 4 Light" to in CRX in file /content/cm/tbxeditor-config.xml
      • restartet LC 4 jboss server
      snippet:
      <fonts>
           <font>Frutiger LT Com 45 Light</font>
      </fonts>
      The Server log just says:
      2013-06-19 12:20:28,186 INFO  [com.adobe.fontmanager.FontManager] (main) FontManager: Loading Customer fonts from directory: D:\Adobe\Fonts
      2013-06-19 12:20:28,451 INFO  [com.adobe.fontmanager.FontManager] (main) FontManager: Loading Adobe Server fonts from directory: D:\Adobe\Adobe LiveCycle ES4\fonts
      2013-06-19 12:20:34,972 INFO  [com.adobe.fontmanager.FontManager] (main) FontManager: Loading System fonts from directory: C:\Windows\Fonts
      I couldn't find any errors in error.log/server.log.
      Any hints?
      Thanks in advance
      jwe
        • 1. Re: Add new fonts to CM
          N Santosh Kumar techies
          Please perform the steps as mentioned @ http://help.adobe.com/en_US/livecycle/11.0/CorrespondenceManagementDeveloper/WSa19c1f2d88a fc1f2e859c0b1314608cb7a-8000.2.html
          You mentioned that you copied the font file to D:/Adobe/font but the log says loading customer fonts from D:\Adobe\Fonts (notice an extra s in the log) - Can you check if you need to correct the configuration to point to correct folder location ?
          --Santosh
          • 2. Re: Add new fonts to CM
            deepak k. Community Member
            Along with server, these fonts should also be installed on each client desktop machine from where you are opening CM UI, in case to want to use them in Text Editor.
            Also, what is the extact thing that is not working as per your expectation. I could not find that in original question. Is it not showing in CM Text Editor font drop down or something else?
            -Deepak
            • 3. Re: Add new fonts to CM
              N Santosh Kumar wrote:
              Please perform the steps as mentioned @ http://help.adobe.com/en_US/livecycle/11.0/CorrespondenceManagementDev eloper/WSa19c1f2d88afc1f2e859c0b1314608cb7a-8000.2.html
              --Santosh
              Hi Santosh, hi Deepak ,
              thx for your replies. I'm sorry I haven't found that resource. I'll give it a try. The customer font folder is right, but I missed the 's' in my post above only.
              "Also, what is the extact thing that is not working as per your expectation. I could not find that in original question. Is it not showing in CM Text Editor font drop down or something else?"
              What I meant is, after I installed the font & added the font label to CM Editor Font drop down, I'm not able to switch e.g. from Times New Roman to my custom font.
              Greetings
              jwe
              • 4. Re: Add new fonts to CM
                Thomas_Chongruk Community Member
                I'm not completely sure how it is in CM, but going from Designer, if you want the end-user to have the exact same font that you loaded up on the originating system, you need to embed the fonts in the PDF output.  Otherwise, the client / end-user's system will make a font substitution if it doesn't have the exact font on their system, and the LC server can't control how or what substitution is made.
                • 5. Re: Add new fonts to CM
                  In Correspondence Management, If you are talking about fonts while authoring text in Text Editor authoring UI, the font needs to be present on the client machine. If a font in not present on the client machine, the Flex UI would show a fallback font when you are previewing/editing text.
                  Now, if we look at the fonts experience in Letter PDF generated as output from Correspondence Management, what you observed below about designer and PDF output still holds true.
