I created one Directory watcher through admin and I found that it is executing more than once. Is there anything that I am missing?
The configuration file is as below
# DirectoryWatcherGateway configuration file
# The directory you want to watch. If you are entering a Windows path
# either use forward slashes (C:/mydir) or escape the back slashes (C:\\mydir).
directory=D:\\Balu\\changes\\9786\\Codeset\\OpportunityDirectoryWatcher\\FTPFolder
# Should we watch the directory and all subdirectories too
# Default is no. Set to 'yes' to do the recursion.
recurse=no
# The interval between checks, in miliseconds
# Default is 60 seconds
# interval=180
# The comma separated list of extensions to match.
# Default is * - all files
extensions=*
# CFC Function for file Change events
# Default is onChange, set to nothing if you don't want to see these events
changeFunction=onChange
# CFC Function for file Add events
# Default is onAdd, set to nothing if you don't want to see these events
addFunction=onAdd
# CFC Function for file Delete events
# Default is onDelete, set to nothing if you don't want to see these events
deleteFunction=onDelete
<cfcomponent>
<cfset
variables.filepath = "D:\Balu\changes\9786\Codeset\OpportunityDirectoryWatcher\FTPFolder\userdetail.txt">
<cffunction
name="onAdd" output="false" returnType="void">
<cfargument name="CFEvent" type="struct" required="true">
<cfset var fileData = "">
<cfset var firstName="">
<cfset var lastName = "">
<cfset var age = "">
<cfset var school = "">
<cftry>
<cffile action="read" file="#variables.filepath#" variable="fileData">
<cffile action="write" output="#createuuid()#" file="D:\Balu\changes\9786\Codeset\OpportunityDirectoryWatcher\#createUUID()#.txt">
<cfloop index="eachrow" list="#fileData#" delimiters="#chr(10)##chr(13)#">
<cfquery name="insertData" datasource="testsb">
INSERT INTO[testsb].[dbo].[usertable]
([firstname]
,[lastname]
,[age]
,[school])
VALUES
<cfloop index="eachColumn" list="#eachrow#" delimiters="#chr(9)#">
'#eachColumn#'
<cfif ListLast(eachrow,chr(9)) eq eachColumn>
<cfelse>,
</cfif>
</cfloop>
</cfquery>
</cfloop><cfabort>
<cfcatch type="any">
<cfdocument format="pdf" overwrite="true" filename="D:\Balu\changes\9786\Codeset\OpportunityDirectoryWatcher\error.pdf"><cfdump var="#cfcatch#"></cfdocument>
</cfcatch>
</cftry>
</cffunction>
<cffunction
name="onChange" output="false" returnType="void">
</cffunction>
</cfcomponent>
Have something to add?
