5 Replies Latest reply on Jun 26, 2013 5:15 PM by elainecc
    tween max with a child
    oliverS Level 1
      Hello everybody,
      I asked a few weeks ago, but the last step is missing,
      so I could realy need some help:
      I placed a symol on stage with:
      sym.stop();
      var eins = sym.createChildSymbol("eins", "Stage");
      eins.getSymbolElement().css({
                'position': 'absolute',
                'left': 100,
                'top': 0
      Now I want to move this symbol with tweenMax with a button
      So thanks for reply, I know it has to work whith:
      Try to use this:
      var  mySymbol = sym.getComposition().getStage().$("eins");
      TweenMax.to(mySymbol,2,{css:{y:120, scale:1, opacity: 1}, delay:0, ease:Expo.easeOut});
      But it does not. It must be my fault but I dont know how to fix it.
      maybe somebody could have a look at it:
      http://go-motion.net//upload/examples/04/test.zip
      Thank you in advance
      Oll
        • 1. Re: tween max with a child
          BigMucho Level 1
          Im away from my laptop, but try this:
          var moveEins = eins.getSymbolElement();
          TweenMax.set(moveEins, {position:'absolute', left:100, top:0});
          TweenMax.to(moveEins, 2, {y:120, scale:1, opacity:1, delay:0, ease:Expo.easeOut});
          A couple of GreenSock  points:
          * update to the latest version, or use the CDN, you then dont need to specify that a parameter is CSS (GS now just "gets it")
          * Try playing with the "TweenMax.set" as an alternative to setting parameters with JQ, it a little faster, and it works well when using GS timelines.
          • 2. Re: tween max with a child
            oliverS Level 1
            Thanks for quick response.
            It´s close to.
            Now it moves the new second createt child "eins"on the stage,
            but I placed the "eins" Symbol already on the stage whit the code
            on the first frame:
            sym.stop();
                      'left': 100,
                      'top': 0
            I want to move it (whith a klick on a button) after I placed it .
            Thank you
            • 3. Re: tween max with a child
              sarhunt Adobe Employee
              Hey Oliver,
              I downloaded your .zip - did you get this working? The eins symbol moves when I click the button.
              Sarah
              • 4. Re: tween max with a child
                oliverS Level 1
                There are two "eins" symbols. One is placed manually on the stage per drag and drop
                from the library and the second is placed with a trigger (var eins = sym.createChildSymbol("eins", "Stage");
                The first one moves the second not. I want to move the symbol which is placed with the trigger.
                • 5. Re: tween max with a child
                  elainecc Adobe Employee
                  Hi, Oliver-
                  Did you still need help with this issue?  I believe we resolved the issue in this thread, right?
                  http://forums.adobe.com/message/5438239#5438239
                  -Elaine
