3 Replies Latest reply on Jun 23, 2013 4:25 AM by Janaaaaa
    applescript 2 scripts to one (grep+add hyperlink)
    Janaaaaa
      Hi.
      I try to combine two scripts. First one greps 7 digits numbers in indesign
      and another makes hyperlink that is same numbers as that selection(grep)'
      Does anyone have  idea how to do that. thanks -Jan
      This  greps 7 digits numbers in indesign with this script
      tell application "Adobe InDesign CS5.5"
        activate
                set find grep preferences to nothing
                set change grep preferences to nothing
                set find what of find grep preferences to "\\d{7}"
                tell active document
                          set myFoundItems to find grep
                end tell
      end tell
      and this one makes hyperlink:
                tell document 1
                          set mySelection to selection
                          set LinkID to contents of mySelection as string
                          set LinkIDURL to LinkID as string
                          try
                                    set URL_L to make hyperlink URL destination with properties {name:LinkID, destination URL:LinkIDURL}
                          on error
                                    set URL_L to hyperlink URL destination LinkID
                          end try
                          set URL_La to make hyperlink text source with properties {source text: (item 1 of mySelection), hidden:false}
                          set myHyperlink to make new hyperlink with properties {destination:URL_L, source:URL_La, visible:false}
                end tell
      end tell
      end
        • 1. Re: applescript 2 scripts to one (grep+add hyperlink)
          Janaaaaa Level 1
          well. I have been searching from this forum and almost I figured this one out.
          But it only copies one item of many 7 digit number from indesign and makes that one hyperlink.
          other ones are not made. this is difficult Any ideas?
            activate
                              repeat with i from 1 to count of myFoundItems
                                        set FileName to (contents of item 1 of myFoundItems) as string
                                        if not (exists hyperlink URL destination FileName) then
                                                  set TheH to make hyperlink URL destination with properties {name:FileName, destination URL:TheURL}
                                        else
                                                  set TheH to hyperlink URL destination FileName
                                        end if
                                        set TheHSName to FileName
                                        set TheHS to make hyperlink text source with properties {name:TheHSName, source text:  (item i of myFoundItems), hidden:false}
            make new hyperlink with properties {destination:TheH, source:TheHS, visible:false}
                              end repeat
                    end tell
          end tell
          • 2. Re: applescript 2 scripts to one (grep+add hyperlink)
            Larry G. Schneider Adobe Community Professional & MVP
            You may need to run the loop backwards to not ruin the index.
            • 3. Re: applescript 2 scripts to one (grep+add hyperlink)
              Janaaaaa Level 1
              YES! I got it with help of Indesign scripting quide.
              Here is the applescript. Feel free to use if you need. This only works if no hyperlinks are not assignet to those 7 digits you are grepping with this script
                activate
                -- resetoi grep opitonit ettei edelliset haut vaikuta
                --Asettaa haku parametrit
                        set include hidden layers of find change grep options to false
                        set include locked layers for find of find change grep options to true
                -- 7 numero perakkain hakuaehto
                -- etsii jokaisen sivulla oleva mallikoodin nimen
                -- ottaa ylos jokaisen mallikoodin numerosarjan
                                  repeat with i from 1 to (count myFoundItems)
                                            set FileName to contents of item i of myFoundItems
                                                      set TheH to make hyperlink URL destination with properties {name:FileName, destination URL:FileName}
                                            else
                                            end if
                -- lisaa hyperlinkin
                                  end repeat
                        end tell
              end tell
