0 Replies Latest reply on Jun 20, 2013 8:53 AM by Haiko Oosterbaan
    Multiple dependent dropdown lists with the same content on one page
    Haiko Oosterbaan Level 1
      I've read the different discussions so far about dependent dropdown lists.
      I've got it to work with one list, but need about 18 of these dropdown lists, all with the same content, on one page which all can be used separately and I can't figure out how to do it, if even possible.
      (It's part of a bigger form.)
      My script is based on this discussion:
      http://forums.adobe.com/message/3012567
      keystroke script box 1:
      if( event.willCommit )
         if(event.value == "")
           //if nothing is chosen in box1 then box2 will be cleared
           this.getField("box2").clearItems();
         else
          SetFieldValues(event.value);
      keystroke script box 3:
           //if nothing is chosen in box3 then box4 will be cleared
           this.getField("box4").clearItems();
         else
      and adjusted the document Javascript:
      //First you make the values for box1.
      myBox1Values = ["", "a", "b"];
      myBox3Values = ["", "g", "h"];
        //Then you populate the values to box1.
      this.getField("box1").setItems(myBox1Values);
      this.getField("box3").setItems(myBox1Values);
      // Then you define what has to be shown in box2 when value is selected
      var DeptData = { a: ["C","D"],
                       b: ["E","F"],
                       g: ["I","J"],
                       h: ["K","L"]
      //Finally you set the values of box2
      function SetFieldValues(cDeptName)
        this.getField("box2").setItems(DeptData[cDeptName]);
        this.getField("box4").setItems(DeptData[cDeptName]);
      This doesn't work. When changing the value in box1 or box3, both box2 and box4 change.
      Has anyone got an idea how to solve this?
      Thanks, Haiko.
