1. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
try67 Jun 20, 2013 12:11 PM (in response to lmphil)Just set the format string of the field to "mm/dd/yyyy" and it will happen
by itself.
2. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
MarkWalsh Jun 20, 2013 12:18 PM (in response to lmphil)edit - beat me to it.
3. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
lmphil Jun 25, 2013 6:54 AM (in response to try67)Thanks for your help! The format string is "mm/dd/yyyy". If the date is not entered just like that, an alert appears that the date is not in the correct format. (No validation) What am I missing? Please advise...
4. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
try67 Jun 25, 2013 6:59 AM (in response to lmphil)I don't follow... Even if the format string is set to "mm/dd/yyyy" the field will accept something like "6/1/2012" and will display it as "06/01/2012".
5. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
lmphil Jun 25, 2013 11:02 AM (in response to try67)Thanks for your response! I'm not exactly sure why this isn't working... The format string is "mm/dd/yyyy" with no validation, just format... When I enter a date as "5/1/2013", an alert appears "Invalid date/time: please ensure that the date/time exists. Field [xxxxxxxxxx] should match format mm/dd/yyyy". If I enter the date as "05/01/2013", no alert appears. Am I missing something? Thanks for your help.
6. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
try67 Jun 25, 2013 1:24 PM (in response to lmphil)Don't know what to tell you... It works for me.
7. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
lmphil Jun 25, 2013 2:09 PM (in response to try67)Thanks for your input. I'm not really sure why this format is working differently for me, but will continue to investigate.
Thank again!
Sent from my iPhone
8. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
weezie1070 Jun 26, 2013 11:33 AM (in response to lmphil)I also have the same issue and it doesn't seem that Adobe will convert a date format if the user enters it incorrectly. In my case, I would like the date set to European date format, but some users may use the US format, but like with Word forms I would like Adobe to convert to EU format automatically without the user having to retype. Will Adobe do this?
9. Re: Is it possible to create a script that would convert 1/1/2013 (m/d/yy) to 01/01/2013 (mm/dd/yyyy)?
try67 Jun 26, 2013 12:16 PM (in response to weezie1070)No. You'll need to write your own format script to achieve that.
