Greetings!
I don't really do any Javascripting, so I could really use some help.
First - and most importantly:
I have a Acrobat Pro X PDF form with a Submit a Form button that is being routed to a specific email address.
The originates in Sharepoint, and is generating a long pdf filename filled with "%" characters.
Is there a way to specify the name generated for the PDF?
I'd be thrilled if I can get the above scenario working...
But I know the next question will then be...
Is there anyway to attach a field from the form to that PDF file name?
Like so:
SpecificFileName_EmployeenameField.PDF
Again - I'm not a javascript person, otherwise I'd know if any of this was possible.
And yes, I'd love some recommendations on books / resources for scripting with Javascript.
Thank you to anyone that can help shed some light on this.
- You can't specify the name of the file that is being submitted.
- You can save the file using the value of a field, but that requires a folder-level script installed on the computer of each user using this file.
