1 Reply Latest reply on Jun 21, 2013 6:36 AM by AMULI
    Javascript coding issues (if else statements)
    Mike Dubbzz
      Hello to all,
      I am posting for help for problems I am having with javascript. The website is www.goshowpro.com. Right now on the website it is connected by multiple html files but I would like to have it all on one single page with the animations responding. I would like the animation to be seamless but I am relatively new to javascript and am having issues with my syntax I believe. Below is the code for my new home page/index button. Thank you for your help in advance.
      -Michael
      if (mymovie == "hporstop"){
      // play the timeline from the given position (ms or label)
      sym.play("phomstart");
      else if (mymovie == "por1.1stop"){
      else if (mymovie == "por1.2stop"){
      else if (mymovie == "por1.3stop"){
      else if (mymovie == "sporstop"){
      else if (mymovie == "cporstop"){
      else if (mymovie == "hconstop"){
      sym.play("chomstart");
      else if (mymovie == "sconstop"){
      else if (mymovie == "pconstop"){
      else if (mymovie == "cserstop"){
      sym.play("shomstart");
      else if (mymovie == "hserstop"){
      else (mymovie == "pserstop"){
        • 1. Re: Javascript coding issues (if else statements)
          AMULI Level 4
          Hi Mike,
          When you test the different possible values of a variable mymovie, you are better off using a switch.
          See : http://www.w3schools.com/js/js_switch.asp
          Then you could avoid repeating statements by regrouping cases :
          switch( mymovie)
            case "hporstop":
            case "por1.1stop":
            case "por1.2stop":
            case "por1.3stop":
            case "sporstop":
            case "cporstop":
               break;
            case "hconstop":
            case "sconstop":
            case "pconstop":
               break;
            case "cserstop":
            case "hserstop":
            case "pserstop":
               break;
          What is important to grasp to understand the flow of execution is that the break; statement prevents from testing the following cases.
          Gil
