4 Replies Latest reply on Aug 10, 2006 1:32 PM by Newsgroup_User
    Dynamic Form to Dynamic Action Page
    Mikelaskowski
      I am trying to build a simple form which includes 4 fields:
      2 Text fields: FirstName, LastName, 1 select field: Role, and one dynamic hidden field
      I am looking to accomplish 2 things:
      1. I want the value of the hidden field to by dynamic from the data of firstname and lastname and reformated to "lastname, firstname".
      2. The name of the in the hidden field must also be dynamic where the name would equal the value of the selected role
      FYI, In my database I do not have a field called "role" but i do have a field for every item in the role field.
      Any ideas or sample code to share?
      All help is greatly appreciated.
      Thanks!
        • 1. Re: Dynamic Form to Dynamic Action Page
          Level 7
          That is not a very good database design for future development.
          But to do what you want, if I understand your question correctly, you do
          not need to create a hidden form field.
          I can imagine two possible solutions on the action page. If you really
          want it to be a form value for some reason. This should work:
          <cfset form[form.role] = true> <!--- OR whatever value you want this
          field to be. --->
          OR if you are writing your own queries, you should be able to just do this.
          <cfquery ....>
          INSERT INTO aTable
          (firstName, lastName, #form.role#)
          VALUES
          ('#form.firstName#, #form.lastName#, true)
          </cfquery>
          Mikelaskowski wrote:
          > Hi,
          > I am trying to build a simple form which includes 3 fields:
          > 2 Text fileds: FirstName, LastName, and 1 secet field: Role
          > 1. I want the form to take the data from the firstname and last name fields
          > and create a hidden field where the name of the the hiddden fields is named
          > after the selected Role.
          > for every item in the role.
          > Any ideas or same code to share?
          > Thanks!
          • 2. Dynamic Form to Dynamic Action Page
            jdeline Level 1
            To accomplish exactly what you describe, you would have to use JavaScript. But why not simplify it. See code below.
            • 3. Re: Dynamic Form to Dynamic Action Page
              Mikelaskowski Level 1
              I really like your solution. It definatly sounds a lot easier.
              I am still having a little trouble though. I am probably missing something silly (especially in my cfupdate tag) as I am a little new at this stil.
              When I used your code in my action page I get the following error:
              Error Occurred While Processing Request
              Variable PRESIDENT is undefined. <--when president is selected in the role field. It changes nicely when another is selected.
              Here is my current code on my action page:
              Thanks Again!!!
              • 4. Re: Dynamic Form to Dynamic Action Page
                Level 7
                <cfupdate> process data from the form scope. You are not putting your
                role datum into the form scope. You need to scope the variable in your
                cfset(s).
                <cfset form.roleColumn = form.role=>
                But I am not sure this would work well. It is probably better if you
                write your own SQL. <cfinsert> and <cfupdate> are for very basic
                database operations. Once you start putting other processing
                requirements in, such as this, they quickly become inadequate.
                Try replacing your <cfupdate> with a <cfquery> tag something like this.
                <cfquery datasource="my_DSN">
                UPDATE my_table
                SET lastName = '#form.lastName#',
                firstName = '#form.firstName#',
                #form.role# = true
                WHERE key = value
                </cfquery>
                I made my best guesses at how this SQL would look based on the examples
                you have provided. You'll have to finish it off based on your actual
                requirements.
                > Thanks,
                > Thanks Again!!!
                > <CFSET lastFirst = lastName & ", " & firstName>
                > <CFSET roleColumn = Evaluate(role)>
                > <cfupdate datasource="my_DSN" tablename="my_table">
                > <html>
                > <head>
                > <title>Title</title>
                > </head>
                > <body>
                > <cfoutput>The role is #roleColumn#<br>
                > The value is #lastFirst#</cfoutput>
                > </body>
                > </html>
