3 Replies Latest reply on Jun 20, 2013 8:15 PM by Jim_Simon
    CC7 - Seeing source videos on timeline for multicam
    SMG720 Level 1
      Hey fellas -
      For those who've worked with CC7 multicam, how you found a way to see your source video on the timeline while you're doing your cuts?  More specifically, once I create a Multicam Source Sequence and sync by audio, that source sequence contains all the properly aligned video.  However, to start making multicam cuts, you must create another sequence using that Multicam Source Sequence.  With this new sequence, you only see the single Source sequence on the timeline and none of the original clips in the source sequence.  Where this helps is to know when you need to make a cut, if your currently-selected clip will run out.
      Any info you'd offer is much appreciated.
