1. Re: ColdFusion 10 Session Replication problem
damonw1977 May 8, 2015 11:10 AM (in response to another_admin)We are experiencing this exact problem using ColdFusion 11. I wrote a test page that makes 100 ajax requests at a given interval, alternating between a post and a get. You can reduce the interval setting in the java-script and eventually the ajax calls will start returning different session ids.
We are using latest CF11 running on windows 2012 R2 Standard with an IIS front end site. All current updates applied. Clustering and instancing have been set up per ColdFusion documentation to use session replication but not sticky sessions.
Any suggestions would be great!
ColdFusion 11,0,05,293506
Java 1.8.0_25
OS 6.2
2. Re: ColdFusion 10 Session Replication problem
Vestige Jun 24, 2016 4:43 PM (in response to damonw1977)i also have a similar situation, brand new install, 2 servers, 2 instances on each (cfusion and cluster_member)
a cluster set up on each server with the local member and the remote member.
session replication doesn't seem to work at all on CF11 with multiple servers, unfortunately i see nothing in any logs indicating any issues and obviously am not alone.
3. Re: ColdFusion 10 Session Replication problem
BKBK Jun 27, 2016 10:40 AM (in response to another_admin)Vestige mentioned what first came to my mind: logs. Perform a test where you log te session cookies. Then the question is, are the newly generated sessions emerging from multiple instances in the cluster or from just one?
