3 Replies Latest reply on Jun 23, 2013 10:25 AM by CopyPixels
    Big problem with SWF
    anjemalo Level 1
      Hello:
      I have a swf file imported to Director. the swf has a button in it. I have put on SWF a transparent sprite with a behavior, the problem is that I need to push the button in the SWF but I can't because the code over my transparent sprite.
      Do you know a way to get this?
      I need to use a sprite over the swf because I have to drag and throw multiples swf at a time.
      Can you help me , please?
      many thanks
        • 1. Re: Big problem with SWF
          CopyPixels Level 1
          There is a trick that I have used with bitmap sprites that may work with a swf.
          Just add the swf sprite to the scriptInstanceList of the the Transparent sprite.
          -- Transparent sprite behavior
          on beginSprite me
            SwfSpriteNum = 10
            sprite(me.spriteNum).scriptInstanceList.add(sprite(SwfSpriteNum))
          end
          • 2. Re: Big problem with SWF
            anjemalo Level 1
            I have try it but does not work
            • 3. Re: Big problem with SWF
              CopyPixels Level 1
              Hmmmm...
              If your transparent sprite has opaque parts then you can set the ink property to "matte" and then mouse clicks will pass through.
              If your transparent sprite is a completely transparent rectangle then I suggest deleting it and using some lingo code to determine if a mouse click is inside the drag area.
              on prepareMovie
                the mouseDownScript = "checkMouse()"
              end
              on checkMouse
                put "checking mouse loc"
                TransparentRect = rect(150,80,470,320)
                if _mouse.mouseLoc.inside(TransparentRect) then
                  put "mouse click inside transparent Rect"
                  -- add drag code here
                end if
              end checkMouse
