3 Replies Latest reply on Jun 24, 2013 9:02 AM by GangamStyle
    Object move question
    GangamStyle
      Hi.
      I think the whole day on this thing: In this example http://www.stanko-b.com/heelbopps/ (project https://www.dropbox.com/s/dr41wme9uqnm0a9/heelbopps4.zip) when you press the "down" button, the screen scrolls down to a particular object.
      Сode assigned to the button "down" is:
      var element = sym.$("object1");
      $('html,body').animate({scrollTop: element.offset().top}, "slow");
      My question. How to make itself the "down" button to move to the  "object1"?
      In other words, what would I need one object, wherever it was (on click), moved to other objects on the Y axis?
      Thank you.
        • 1. Re: Object move question
          heathrowe Most Valuable Participant
          In your Stage > compositionReady event handler, add the following code block just before your yepnope.
          If I assume correctly, you will only need one of the arrowDown elements to move when the page scrolls or when the arrow is clicked. In this case I used your 'arrowDown_Products' element; then remove the remaining three since they will no longer be needed.
          /////------- Copy Start ---------- //////
          $(window).scroll(function(){
                 var element = sym.$("arrowDown_products");
                       element
                      .stop()
                      .animate({"marginTop": ($(window).scrollTop() -45) + "px"}, 100 );
          /////--------- End Copy --------- ///////
          Hope this helps. - I havn't tackled the click event but its going to require some conditional logic to function 100%.
          Darrell
          • 2. Re: Object move question
            Zaxist Level 4
            mabe this work, try this
            sym.$("Your button Name Here").animate({scrollTop: element.offset().top}, "slow");
            Zaxist
            • 3. Re: Object move question
              GangamStyle Level 1
              Hi, Darrel!
              I'll explain everything properly. I'll try.
              I'm trying to make a website for my sister. She is an artist, so the site is not big, and I think that is quite able to do it in the Adge.
              https://www.dropbox.com/s/hetaduqmm1ywvc8/site_tst.zip
              The big images are of different height. I want a group of small pictures has always been one and the distance from the big picture. In the example I did this, but it's just "stop the timeline at the given position," and I wont to slide preview pic's group to the specified positions. Aw really do this? I'm sure you'll be able to give a good idea.
              Alex.
