6 Replies Latest reply on Jun 23, 2013 12:15 PM by heathrowe
    Animate symbols
    Rafael Zuma
      Hi, Guys!
      I'm trying to animate a symbol into another symbol, but it is not working.
      The code is this:
      sym.getSymbol ("father"). getSymbol ("child"). animate ({top: 0}, 500, 'linear');
      Can i apply the function. "Animate ()" on a symbol or am I doing something wrong?
        • 1. Re: Animate symbols
          resdesign Adobe Community Professional & MVP
          Using jQuery-UI I have this working. The symbol name is father and the symbol inside father is called child.
          Note: I added a folder named js with the 2 files below.
          // insert code to be run when the composition is fully loaded here
          yepnope(
              nope:[
                  'js/jquery-ui-1.9.2.custom.min.js',
                  'js/jquery.ui.touch-punch.min.js',
              complete: init
          function init() {
                    var father = sym.getSymbol('father');
                    sym.$('father').click(function() {
                                         father.$('child').animate({
                                        opacity: 0.25,
                                        left: '+=50',
                                        height: 'toggle'
                              }, 5000, function() {
              // Animation complete.
          Sample:
          https://www.box.com/s/d4xtjsk8205evmmqfopx
          If you want the click event to be on the red dot (child) change the line sym.$('father').click(function() {  to:
               father.$('child').click(function() {
               same code here
          • 2. Re: Animate symbols
            YOSHIOKA Ume Level 3
            Hi.
            I guess, we can use getSymbolElement() to access an element associated with a symbol.
            sym.getSymbol("father").getSymbol("child").getSymbolElement().animate ({top: 0}, 500, 'linear');
            • 3. Re: Animate symbols
              Rafael Zuma Level 1
              Hi, redesign and YOSHICA!Thanks for the help of both!
              I concluded that to animate a "symbol" (MovieClip in Flash), we can not simply put ".animate" after ".getSymbol", we must have ".getSymbolElement" before ".animate".
              Does not work:
              sym.getSymbol("test").animate ({top: -50}, 2000, 'linear');
              works:
              sym.getSymbol("test").getSymbolElement().animate ({top: -50}, 2000, 'linear');
              • 4. Re: Animate symbols
                heathrowe Most Valuable Participant
                Rafael, try this. Note the direct jquery handler reference $("child"). I just tested this and it works.
                sym.getSymbol("father").$("child").animate ({top: -50}, 2000, 'linear');
                Darrell
                • 5. Re: Animate symbols
                  Rafael Zuma Level 1
                  Yes, it works when I want to animate an "element" within a "symbol". But what I wanted was to animate a "symbol".
                  So if you try the way down, you will not get:
                  sym.getSymbol ("father"). animate ({top: -50}, 2000, 'linear');
                  • 6. Re: Animate symbols
                    It works, I am animating a symbol.
                    I have
                    Symbol called 'father'
                        within this symbol (father) I have another symbol called 'child'.
                    Using the above notation I reference you can use the jquery 'animate' method.
                    See capture.
