1 2 Previous Next 66 Replies Latest reply on Dec 14, 2017 8:01 AM by CreeDeaux
    Photoshop CC - Slight lag
    xdigirolamox
      I've never had a problem with the performance of any Adobe program to date. I've been using CS6 since it was released and on my current computer, Photoshop CS6 was very responsive. I just installed Photoshop CC and was immediately shocked at the slight lag that's present with absolutely everything I do. I've heard reports with previous versions that there was a lag with the brush tool, never personally experienced it but I am seeing it now.
      Besides the brush tool, I've also noticed the same 1/2 - 1 second lag when making a selection, zooming, erasing or pretty much any other tool. The odd thing is that it seems to be happening for non-intensive things as well. Even on small documents, if I hold the spacebar and drag with my mouse to pan, there's a 1/2 second delay before the pan starts, then once it gets going it's business as usual.
      It seems like a dumb little issue, but when you're trying to work quickly and you're moving around a lot, having a delay before any/every action gets annoying really quickly.
        • 1. Re: Photoshop CC - Slight lag
          Trevor.Dennis Adobe Community Professional
          It definitely sounds like a glitch.  What OS are you using?  Did you import your CS6 settings when you first opened CC.  I'm thinking of your GPU settings in the preferences > performance tab.
          • 2. Re: Photoshop CC - Slight lag
            xdigirolamox Level 1
            I'm guessing it's a glitch as well but I can't get to the bottom of it. If it did import my CS6 settings, I didn't realize it. Either way I compared the performance settings of my two versions and the only difference was that Photoshop CC had GPU enabled and CS6 did not. Changing it does not really make a difference. Going to try and uninstall and reinstall the program now.
            • 3. Re: Photoshop CC - Slight lag
              dentonich ar Level 1
              I have same problem with photoshop. And Indesign lags to.
              GPU settings is same on both versions
              OS - Windows 7
              • 4. Re: Photoshop CC - Slight lag
                Level 7
                If both programs show the same problem, it is most likely related to activation or fonts (because that's about all they have in common).
                I'd check your system for corrupt fonts, or a corrupt OS font cache.
                • 5. Re: Photoshop CC - Slight lag
                  Nope. Photosop and Indesign is trial. And no problems with fonts.
                  My Photoshop and Indesign CS6 work fine.
                  When i start Photoshop CC my videocard becomes very hot in 5 seconds.
                  Photoshop CS 6 work fine.
                  • 6. Re: Photoshop CC - Slight lag
                    Level 7
                    We've had reports of some video cards heating up or consuming excess CPU time - we are investigating, but it sounds like a bug in the OpenCL driver code for that particular family of GPUs.
                    But InDesign doesn't use the GPU.
                    So the one thing left in common between ID and PS is fonts or the OS font cache.
                    • 7. Re: Photoshop CC - Slight lag
                      Indesign CC works slowly than indesign CS6.
                      Photoshop heating up my video card about 1 minut. And then works with lags
                      • 8. Re: Photoshop CC - Slight lag
                        Dr.Romano
                        20 years ago I use PS 2.x on 100MGz 486 processor. And common operations
                        took as much time as now. Maybe less. The interface works much faster.
                        Versions were replaced and at some point I stopped on PS 4.x. My computer
                        at the time was the 500MHz Pentium III. The PS 5.0, 5,5, 6.0 was released,
                        I still use the PS4. Bro, that was something. With a gigabyte of RAM and a
                        RAID0 (2x Quantum Fireball) PS4 was just like a bullet. These were the
                        best years of my life. Then I updated the version and everything was like
                        a bad horror movie: getting worse and worse. Something similar to the old
                        days when I felt just before the release CS3 bought a new computer for
                        6000 bucks. For a while it was like comfortable work. Before CS4. So
                        here's a secret: every time when Adobe updates products line, you have to
                        buy a new computer for 6 grand. No cheating, I'm mean it. The latest
                        graphics card, the latest disk array, the latest CPU. Adobe will gobble up
                        everything. Welcome to the modern world, bro. It's way, how it working now.
                        Recently I meet CC, by the way. On CPU with resulting frequency almost
                        8GHz (80 times faster than my first PC) and a video card with a gigabyte
                        of video memory (god, my first PC has five times less disk space) it
                        like... zombie nightmare.
                        • 9. Re: Photoshop CC - Slight lag
                          Tzach Implisit
                          I'm having the same problems.. Windows 8 and activated Photoshop CC.
                          Any solution?
                          • 10. Re: Photoshop CC - Slight lag
                            pinkbunkadoo
                            Getting this problem too. Everything works fine for a bit after launching Photoshop CC, however, after a few minutes things start to lag badly - zooming especially.
                            Windows 7 64-bit
                            16 GB ram
                            Nvidia GeForce GTX 560 Ti
                            256GB Samsung SSD 840 PRO Series
                            • 11. Re: Photoshop CC - Slight lag
                              joedeagnon
                              In terms of lag the only tool that acts wonky for me is the Lasso tool. I'll open a new document and want to select something. The marquee tool is no problem, but as soon as I try to lasso something in any of the three modes, nothing happens. It sits on the tool for a very long time. To get out of this I have to hit the escape key - then it's back to normal. This only happens on opening a new document - both when Photoshop CC is running for a while and when it first starts up. (Closing the doc and reopening it also works) but this happens every day, literally.
                              • 12. Re: Photoshop CC - Slight lag
                                pinkbunkadoo Level 1
                                I think this may actually be Wacom tablet related. This behaviour only seems to exhibit itself when I am using my Wacom Intuos 3 with Photoshop. Perhaps a driver issue?
                                • 13. Re: Photoshop CC - Slight lag
                                  DavidRobot Level 1
                                  I'm having the same issue..Windows 8.1. I've unchecked GPU settings in Photoshop and I'm still experiencing this strange lag. It's very annoying.
                                  I will add that I did not experience this before installing new Wacom drivers (which I installed last night) so there may be a conflict there?
                                  • 14. Re: Photoshop CC - Slight lag
                                    ColbyFulton Level 1
                                    Yep, my lasso has lag too. I do have a Wacom tablet driver installed by am using the keyboard and mouse when I notice this issue.
                                    • 15. Re: Photoshop CC - Slight lag
                                      RAM-Studio Level 1
                                      Hi!
                                      Has anoyne found solution for this problem ?
                                      I have 2 GPUs in my machine
                                      1. Gigabyte 660GTX OC 2GB
                                      2. Asus 780 GTX STRIX OC Edition 6GB
                                      Both cards ar earoudn 37-38 degree Celsious when using compute rin windows. As soon as i start Photoshop CC my GTX 780 starts to heat up slowly (like 1 degree every 3-4 seconds) and it goes up to 70-75 celsious even if i just leave machien idle or put Photoshop in background. As soon as i QUIT PhotoShop then teperature slowly goes back to normal. IT happens only at 780GTX (660GTX stays fine aroudn 38C) and i've tried 3 different cards and no difference but problem happens ONLY in Photoshop CC (CS6 works fine no GPU heating up) so it has to be some Adobe Glitch/BUG ?
                                      HELP
                                      • 16. Re: Photoshop CC - Slight lag
                                        Level 7
                                        Or it could be another bug in the video card drivers.
                                        Try updating the drivers from NVidia's website.
                                        • 17. Re: Photoshop CC - Slight lag
                                          RAM-Studio Level 1
                                          Hardly unlikely 'coz like i said it happens ONLY in Photoshop CC, all other programs (3D and 2D) work fine, even photoshop CS6 work fine.
                                          Also i have latest Nvidia drivers "GeForce 337.88 Game Ready WHQL drivers" for windows 8 64bit
                                          There is some BUG in PshopCC for sure and it's serious one 'coz if i go away from machien and leave PShop open it'll heat like crazy
                                          Please FIX it ASAP, Thanks.
                                          P.S. I can save video if you want to see how it's manifesting.
                                          • 18. Re: Photoshop CC - Slight lag
                                            Noel Carboni Level 8
                                            Bear in mind Photoshop CC certainly uses different features and stresses your GPU differently than any other software.  The realm of graphics software is incredibly complex.
                                            "Game Ready" means very little in the realm of professional tool operation.  In fact the features games need are almost certainly not the same things Photoshop needs.  I develop graphics software myself, so I have some insights into display driver implementation.
                                            Nor does "WHQL" carry much weight.  Ask yourself:  How much in general does Microsoft appear to care about quality?
                                            Display driver development is driven first and foremost by people spending money on toys, and it's a very cutthroat business with major players trying to one-up each other constantly.  We're kind of lucky "gamer" GPUs can be used with Photoshop at all.  There have always been driver releases that are better or worse.
                                            -Noel
                                            P.S., Traditionally I've had about 50% more trouble with nVidia drivers than ATI drivers.  And about 300% more trouble with Intel drivers than nVidia drivers.
                                            • 19. Re: Photoshop CC - Slight lag
                                              RAM-Studio Level 1
                                              Thanks for reply Noel, I appreaciate your participation. BUT bear in mind that GPU temperature rises when NOTHIG is being done/worked on in Pshop (it just sits in backgorund empty wiht no canvas), it just Idle so it can't use GPU if is nothing been done and also Photoshop CS6 has same performance/GPU settings and yet it has no such problem. Also I'm using very stressfull programs for GPU (Octane GPU rendering) and it's not heating GPU unless i hit render which is normal and expected behaviour. Heating GPU while is idle in PShopCC definitely is not good or proper work so it's surely PhotoshopCC specific issue (I tiread Premiere CC and it behaves same probelmatic whiel AE CC has no such overheating GPU issues so it's easily weird). So what could be it that PhotoshopCC and PremiereCC are sharing/have in common to expose that BUG whiel AE CC is NOT ?
                                              • 20. Re: Photoshop CC - Slight lag
                                                Something's kicking the GPU into high performance mode.  Perhaps it's a program Adobe has loaded there.
                                                I don't presume to know what Photoshop is doing to maintain its display, but I do know it doesn't kick every GPU up into fast clocks and high heat output just by being running.  So something to look for is:  What's specific to your setup that's not true in the general case?
                                                That brings to mind a possibility...  Photoshop has been known to balk in a setup where multiple different GPUs are present.  In your case the same driver is providing access to both GPUs.  Anticipating what Adobe engineers might find interesting, could you copy the information the GPU sniffer puts in your Help - System Info dialog?  Who knows, it might reveal something.
                                                -Noel
                                                • 21. Re: Photoshop CC - Slight lag
                                                  RAM-Studio Level 1
                                                  GPU sniffer ? Is tha tsomethign MAC specific or we hav eit on Windows also ?
                                                  Funny thing is that Photoshop Dont' even SEE 780GTX in preferences, it sees only 600GTX which drives displays. 780GTX has no displays connected ('coz i use it specificalyl just for GPU rendering so i need all the RAM free)
                                                  check the screengrab of Pshop preferences:
                                                  and screengrab of Device manager
                                                  plus system screengrab:
                                                  • 22. Re: Photoshop CC - Slight lag
                                                    It's in Photoshop for both Mac and PC (I'm a PC user like you by the way).
                                                    In Photoshop, choose Help - System Info.  There's a bunch of info in there about what Photoshop has detected in your system.
                                                    -Noel
                                                    • 23. Re: Photoshop CC - Slight lag
                                                      RAM-Studio Level 1
                                                      Ahh yes I found Sniffer but in my cuda enabled cards i see 780 GTX listed so it should not be an issue then.
                                                      Here is paste from system info in PshopCC
                                                      Adobe Photoshop Version: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
                                                      Operating System: Windows 8 64-bit
                                                      Version: 6.2
                                                      System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                                                      Physical processor count: 16
                                                      Logical processor count: 32
                                                      Processor speed: 2900 MHz
                                                      Built-in memory: 65486 MB
                                                      Free memory: 57214 MB
                                                      Memory available to Photoshop: 59621 MB
                                                      Memory used by Photoshop: 59 %
                                                      Image tile size: 1024K
                                                      Image cache levels: 6
                                                      Font Preview: Medium
                                                      TextComposer: Latin
                                                      Display: 1
                                                      Display Bounds: top=0, left=0, bottom=1600, right=2560
                                                      Display: 2
                                                      Display Bounds: top=0, left=2560, bottom=1600, right=3760
                                                      Display: 3
                                                      Display Bounds: top=0, left=-1200, bottom=1600, right=0
                                                      OpenGL Drawing: Enabled.
                                                      OpenGL Allow Old GPUs: Not Detected.
                                                      OpenGL Drawing Mode: Advanced
                                                      OpenGL Allow Normal Mode: True.
                                                      OpenGL Allow Advanced Mode: True.
                                                      AIFCoreInitialized=1
                                                      AIFOGLInitialized=1
                                                      OGLContextCreated=1
                                                      NumGPUs=1
                                                      gpu[0].OGLVersion="3.0"
                                                      gpu[0].MemoryMB=2048
                                                      gpu[0].RectTextureSize=16384
                                                      gpu[0].Renderer="GeForce GTX 660/PCIe/SSE2"
                                                      gpu[0].RendererID=4103
                                                      gpu[0].Vendor="NVIDIA Corporation"
                                                      gpu[0].VendorID=4318
                                                      gpu[0].HasNPOTSupport=1
                                                      gpu[0].DriverVersion="9.18.13.3788"
                                                      gpu[0].Driver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                                                      gpu[0].DriverDate="20140519000000.000000-000"
                                                      gpu[0].CompileProgramGLSL=1
                                                      gpu[0].TestFrameBuffer=1
                                                      gpu[0].OCLPresent=1
                                                      gpu[0].OCLVersion="1.1"
                                                      gpu[0].CUDASupported=1
                                                      gpu[0].CUDAVersion="6.0.1"
                                                      gpu[0].OCLBandwidth=2.20809e+011
                                                      gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.40 NVIDIA via Cg compiler"
                                                      gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
                                                      gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                                                      gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                                                      gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                                                      gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                                                      gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                                                      gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                                                      gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
                                                      gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                                                      gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                                                      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                                                      gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                                                      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                                                      gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                                                      gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                                                      gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                                                      gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                                                      gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                                                      gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                                                      gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                                                      • 24. Re: Photoshop CC - Slight lag
                                                        Photoshop only sees the GeForce GTX 660.
                                                        I don't see any problems in that listing but an Adobe person would have to say for sure whether a dual GPU configuration with two different cards is well-supported.
                                                        Nice workstation, by the way.  You have your monitors set up just like I do - 2560 x 1600 panel in the middle, with two 1200 x 1600 ears on the sides.
                                                        -Noel
                                                        • 25. Re: Photoshop CC - Slight lag
                                                          Oh, and one other question:  Have you tried running Photoshop CC (2014)?  I see you're running 14.2.1, the older version.
                                                          -Noel
                                                          • 26. Re: Photoshop CC - Slight lag
                                                            RAM-Studio Level 1
                                                            Hmm i have no idea why does it say 14.2.1. I installed it just 2 months ago form AdobeCC application so it is version from 2014 . What's the latest version (i'll go try update it on my AdobeCC account if there is something newer - what version should it be ?).
                                                            As for machine Yes It's Dual Xeons with 3 monitors 20" pivot +30" + 20" pivot which gives 4960*1600 in total.
                                                            • 27. Re: Photoshop CC - Slight lag
                                                              RAM-Studio Level 1
                                                              Update - i just installed PhotoshopCC 2014 version but sadly and no difference, my secondary GPU still heats on unnecesary
                                                              • 29. Re: Photoshop CC - Slight lag
        cmachanic
        CC 2014 is a very disappointing upgrade. Drag and zoom have a 1-2 second delay. Does anyone have a solution?
        • 30. Re: Photoshop CC - Slight lag
        Have you made sure your system software is up to date?
        Choose Help - System Info, copy the data, and post it here.  Perhaps someone will be able to spot something amiss and give you specific things to try to correct it.
        Do you have a tablet?  I've been starting to develop a theory that maybe tablet-mouse interaction may cause sluggishness.  I only have a mouse and find Photoshop CC 2014 quite fast.
        -Noel
        • 31. Re: Photoshop CC - Slight lag
        cmachanic Level 1
        Hi Noel,
        Thanks for the reply... I just reverted back to CS6, and everything is back to normal. Bummer! I always prefer to use the latest and greatest, so I'd love to get CC 2014 working.  Anyway, here's my system info coming out of CS6 (this was clean install), and no, I'm not using a tablet. I disabled that a long time ago. However, I don't know if my update to CC 2014 carried over my my Canon scanner plug-in (i.e. an installed TWAIN device).
        Adobe Photoshop Version: 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00) x64
        Operating System: Mac OS 10.9.3
        System architecture: Intel CPU Family:6, Model:70, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
        Physical processor count: 4
        Logical processor count: 8
        Processor speed: 2600 MHz
        Built-in memory: 16384 MB
        Free memory: 6097 MB
        Memory available to Photoshop: 14937 MB
        Memory used by Photoshop: 80 %
        Image tile size: 128K
        Image cache levels: 4
        OpenGL Drawing Mode: Basic
        OpenCL Version: 1.2 (Apr 25 2014 22:04:25)
        OpenGL Version: 2.1
        Video Rect Texture Size: 16384
        OpenGL Memory: 2047 MB
        Video Card Vendor: NVIDIA Corporation
        Video Card Renderer: NVIDIA GeForce GT 750M OpenGL Engine
        Display: 1
        Main Display
        Display Depth: 32
        Display Bounds: top=0, left=0, bottom=1440, right=2560
        Video Renderer ID: 16918311
        Video Card Memory: 2048 MB
        Serial number: 90970971054589426833
        Application folder: /Applications/Adobe Photoshop CS6/
        Photoshop scratch has async I/O enabled
        Scratch volume(s):
        Macintosh HD, 931.0G, 98.2G free
        Required Plug-ins folder: /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/
        Primary Plug-ins folder: /Applications/Adobe Photoshop CS6/Plug-ins/
        Additional Plug-ins folder: not set
        Installed components:
        adbeape.framework   adbeape   3.3.8.19346   66.1025012
        AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
        adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
        AdobeACE.framework   AdobeACE   2.19.18.20743   66.507768
        AdobeAGM.framework   AdobeAGM   4.26.20.20743   66.507768
        AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
        AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
        AdobeBIB.framework   AdobeBIB   1.2.02.20743   66.507768
        AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.507768
        AdobeCoolType.framework   AdobeCoolType   5.10.33.20743   66.507768
        AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120720
        AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
        AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
        AdobeLinguistic.framework      17206
        AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
        AdobeOwl.framework   AdobeOwl   5.0.4   79.517869
        AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
        AdobePDFSettings.framework   AdobePDFSettings   1.4
        AdobePIP.framework   AdobePIP   7.0.0.1686
        AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
        AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
        AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
        AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
        AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
        ahclient.framework   ahclient   1.7.0.56
        aif_core.framework   AdobeAIF   3.0.00   62.490293
        aif_ocl.framework   AdobeAIF   3.0.00   62.490293
        aif_ogl.framework   AdobeAIF   3.0.00   62.490293
        AlignmentLib.framework   xcode   1.0.0.1
        amtlib.framework   amtlib   6.0.0.75
        boost_date_time.framework   boost_date_time   6.0.0.0
        boost_signals.framework   boost_signals   6.0.0.0
        boost_system.framework   boost_system   6.0.0.0
        boost_threads.framework   boost_threads   6.0.0.0
        Cg.framework   NVIDIA Cg
        CIT.framework   CIT   2.1.0.20577   146758
        data_flow.framework   AdobeAIF   3.0.00   62.490293
        dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
        dvacore.framework   dvacore   6.0.0.0
        dvamarshal.framework   dvamarshal   6.0.0.0
        dvamediatypes.framework   dvamediatypes   6.0.0.0
        dvaplayer.framework   dvaplayer   6.0.0.0
        dvatransport.framework   dvatransport   6.0.0.0
        dvaunittesting.framework   dvaunittesting   6.0.0.0
        dynamiclink.framework   dynamiclink   6.0.0.0
        FileInfo.framework   FileInfo   66.145433   66.145433
        filter_graph.framework   AdobeAIF   3.0.00   62.490293
        hydra_filters.framework   AdobeAIF   3.0.00   62.490293
        ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
        ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
        image_compiler.framework   AdobeAIF   3.0.00   62.490293
        image_flow.framework   AdobeAIF   3.0.00   62.490293
        image_runtime.framework   AdobeAIF   3.0.00   62.490293
        LogSession.framework   LogSession   2.1.2.1681
        mediacoreif.framework   mediacoreif   6.0.0.0
        PlugPlug.framework   PlugPlug   3.0.0.383
        UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
        wrservices.framework
        Required plug-ins:
        3D Studio 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
        Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
        Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Average 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
        Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Camera Raw 8.5 (236), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
        Camera Raw Filter 8.5 (236), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
        Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Cineon 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
        Clouds 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
        Collada DAE 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
        Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Crop and Straighten Photos 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
        Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
        Difference Clouds 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
        Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Eazel Acquire 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
        Embed Watermark NO VERSION - from the file “DigiSign.plugin”
        Entropy 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        FastCore Routines 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
        Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Flash 3D 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
        Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Google Earth 4 KMZ 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
        Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
        IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        JPEG 2000 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
        Kurtosis 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
        Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
        Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
        Matlab Operation 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
        Maximum 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Mean 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Measurement Core 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
        Median 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Minimum 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        MMXCore Routines 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
        Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Multiprocessor Support 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
        Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        NTSC Colors 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
        Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
        OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        PCX 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
        Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Photoshop 3D Engine 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
        Picture Package Filter 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
        Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Pixar 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
        Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Portable Bit Map 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
        Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Radiance 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
        Range 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Read Watermark NO VERSION - from the file “DigiRead.plugin”
        Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
        ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
        Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Skewness 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Solarize 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
        Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Standard Deviation 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        STL 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
        Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Summation 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
        Variance 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
        Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
        Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Wavefront|OBJ 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
        Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Wireless Bitmap 13.1.2 20130105.r.224 2013/01/05:23:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
        ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
        Optional and third party plug-ins: NONE
        Plug-ins that failed to load: NONE
        Flash:
        Mini Bridge
        Kuler
        Extensis
        Installed TWAIN devices: NONE
        • 32. Re: Photoshop CC - Slight lag
        The System Info from the malfunctioning version might have been more useful.
        Do you still have both of them installed?
        -Noel
        • 33. Re: Photoshop CC - Slight lag
        Mellosa Level 1
        Really I have the same delays and cursor freezing effects using all the UI elements and operating with layers (menus, tools, ALL movements) in PS CC 2014. Really annoying and slowing all the work process.
        PS CC 2014 is completely unsuitable for fast working
        Already tried to make some changes in Preferences > Performance. Nothing helped.
        Also tried to turn off the new fast guides and extras. That had a small effect on performance. But still the last PS update is too slow comparing with previous versions. =(
        I've got Win8, 24GB, 3.22GHz x 4, SSD, 64-bit.
        Can I solve the problem or downgrade to last PS CC version?
        • 34. Re: Photoshop CC - Slight lag
        Johannes Bergcrantz
        I've had the exact same issues with Ps CC since I bought it with a slight lag on everything from zooming to lasso-tool, updating my videocard drivers this morning seems to have fixed it though.
        WIn7, 16 Gb ram, Geforce GTX 560 Ti
        • 35. Re: Photoshop CC - Slight lag
        Johannes Bergcrantz Level 1
        Well, that was premature
        lag is back.
        Interesting observation though, when I first start Photoshop CC everything works, when I've been doing stuff on my secondary monitor for a while and/or in another window on my primary seem to be when the lagging starts.
        Edit: Restarting PS removes the lag again, for a while.
        • 36. Re: Photoshop CC - Slight lag
        JC B
        "Slight lag" is the understatement of the century. Ever since CC 2014 was installed, Photoshop is unusable. I'm on Windows 7 x64 running on a top-tier i7 CPU w/ 16 Go RAM and a discrete GPU. It's become impossible to perform even the most basic image manipulation.
        I'm actually experiencing two issues that could easily be conflated:
        1) Lag when performing most operations. When the tools do work, they exhibit a slight delay. It takes half a second to for a marquee selection to become visible, or for a paint brush click to show, etc.
        2) What some have described as a "freezing effect": Mouse clicks are getting "interrupted" so most operations never get executed. If I start a paint brush operation by clicking the mouse, holding down the mouse button and moving the cursor, Photoshop cancels the operation almost instantly. Instead of seeing a line where I drew one, I just see a dot where I started the operation. If I perform a rectangular marquee selection, it never completes (and there is no selection) unless I do "mouse down - move cursor - mouse up" all within a fraction of a second. Finally, this problem is not limited to the tools, but is reproducible all over the UI. For instance, it's no longer possible to browse the application menus while holding the left button clicked. Usually you can click down on say "File" (File menu opens), hold the mouse button pressed, move the cursor over to "Edit", "Image", "Layer" etc which would cause those menus to open. Now, the File menu remains open just as if I had released the mouse button after having clicked on it.
        That's about as good of a description as I can give, but you can contact me by email if your engineers need additional details.
        Honestly guys, this is unacceptable. I'm paying good money for this software and I expect it to work when I need it to. There's no excuse for pushing out automatic updates that completely break all functionality.
        • 37. Re: Photoshop CC - Slight lag
        What's interesting is the complete lack of a pattern with this issue...  I've never seen anything on my system that could remotely be called lag with this version.  Others have seen it come and go, and still others can't get rid of it.
        I can't help but think that the current implementation triggers something in only some display or mouse drivers that causes the delay.  JC B, what video card do you have?  What display driver version?  Do you have a tablet?
        At this point, though a fair number of folks are reporting these sluggishness / lag type issues here on the forum, it's possible Adobe feels it's only a minority of users overall who have them.  Thus, those of you who do have the issue need to be especially specific and thorough in your reports, in order to make it as likely as possible for an engineer to reproduce it.  That may include posting all your System Info, and describing in detail very specific timing descriptions of particular operations, such as JC B has done above.
        -Noel
        • 38. Re: Photoshop CC - Slight lag
        Also, some of the above descriptions make me wonder whether disk I/O operations may be affecting the interactivity of the display.
        For those of you experiencing sluggishness / lag, do you see any correlation to the disk activity light on your system?  Note that Photoshop opens some fairly large temporary files even before they're needed to support going virtual.
        -Noel
        • 39. Re: Photoshop CC - Slight lag
        JC B Level 1
        Hi Noel, I'm running a Radeon HD 5450 with the latest official driver from AMD (14.100.0.0). I uninstalled the driver to revert back to the Windows 7 defaults, and the problem persisted. Additionally, I unchecked "Use Graphics Processor" in Photoshop Settings > Performance to no avail.
        A couple more details that may be pertinent:
        1) My system is running on a 256 GB Samsung 840 Pro SSD so it's doubtful that disk activity is part of the issue, at least for me.
        2) Photoshop CC (pre-2014, v14.2.1) is still installed, and now exhibits the exact same behavior as Photoshop CC 2014.
        3) Sometimes the issue disappears entirely for a few seconds. Tools work correctly (albeit with a slight lag) and mouse input is responsive. After I switch tools a couple of times though, the bad behavior reappears and Photoshop becomes unusable again. This has happened once on application start, and twice after I had it minimized for about a minute or so.
        Hope this helps.
        1 2 Previous Next
